Old 08-24-2005, 06:00 PM   #1
EdyJun
Account #: 48484
Default Stock vs. 10% added to primary on Stock ECU to solve the High EGT problem. *EDITED*
ALL PARTS IN CAPS LOCK ARE ADDED PARTS (EDITED)
As some of you may know I was getting high EGT when doing a few WOT.
It was recommended to add 10% to Primary and log it again. Well here it is.
Click me to see…
(Side note)
IMO - With 10% primary car is very much happier I would recommend adding to the primary for those who are running 91 octane gas and those who are in traffic a lot (TRY THIS ONLY IF YOU HAVE A COMPLETE UNDERSTANDING OF HOW IT WORKS - DO NOT TRY THIS IF YOU ARE NOT SURE). I have noticed that in ~70 deg weather the car runs a lot smoother and cooler. The oil never passed 200 deg and the coolant would toggle between center and the 2 left mark on it's left during the 2 days that I was testing it.
In 90 deg weather with the A/C ON. The car also runs nicer and cooler.
The added primary acts a bit like having better IC the IAT is cooler quicker and the car's temp is generally kept lower.* (better FATS)
I personally add some % to the primary for day to day driving. (TRY THIS ONLY IF YOU HAVE A COMPLETE UNDERSTANDING OF HOW IT WORKS - THIS WAS ONLY DONE ON MY CAR) (there is no noticeable extra gas usage to my knowledge.)
It appears that a Stock S4 would need to have some tweaks for it to run safe (IMO). Remember I was getting High EGT after doing 3-4 WOT or when I was driving on the freeway and pushing the car. W/ 10% added it lower the EGT greatly.
It should also be said that outside air temperature and IAT play a major role in high EGT, on a Stock ECU more than running on the lean side (IMO).
Next - Log w/ out MAF and try 8% primary + 5% secondary.
Pressure test was done and NO Boost leek that I could detect was found.
Any Comments?
Edy
*EDIT*
I HAVE DONE THIS ONLY ON MY CAR. PLESE MAKE SURE THAT YOU HAVE A COMPLETE UNDERSTAND OF WHAT YOU ARE ABOUT TO DO.
I HAVE GOTEN THIS RESULT ON MY CAR AND ONLY MY CAR.
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-24-2005, 06:28 PM   #2
EdyJun
Account #: 48484
Default Wow, 33 views and no comments....
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-24-2005, 06:46 PM   #3
Mike2kS4
Account #: 38083
Default Looks good x33.
You can spend an unreasonable amount of time tweaking it up and down to find your fastest combo, but it looks good.
Old 08-24-2005, 06:49 PM   #4
EdyJun
Account #: 48484
Default Should I be shooting for 0.88-0.89v for O2 on Stock ECU and 91 or will that be a waste?
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-24-2005, 06:52 PM   #5
PSmalls::DoggieStyle
Account #: 69223
Default Try only +5% and see how it compares. I don't see why you should be that rich at such low boost.
Stock is programmed that lean for a reason.
Old 08-24-2005, 06:54 PM   #6
Mike2kS4
Account #: 38083
Default Hell no. That's fuel o plenty Adjust it down in 2% increments and see if you get any faster.
Old 08-24-2005, 06:55 PM   #7
Mike2kS4
Account #: 38083
Default And that reason being: to spool the turbos quicker :p
Old 08-24-2005, 06:56 PM   #8
EdyJun
Account #: 48484
Default Stock is programmed that lean for a reason. - What is the reason sir?
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-24-2005, 06:57 PM   #9
EdyJun
Account #: 48484
Default Maybe i should be asking what O2 v should i shoot for?
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</font>
Old 08-24-2005, 06:59 PM   #10
Account #: 69223
Default And better gas mileage.
