Old 07-24-2005, 07:58 PM   #1
PSmalls::DoggieStyle
Default For the Monday morning crew, please post logs of injector duty cycle and list mods.....
As some of you know, I recently upgraded injectors and MAF housing for homebrew stage 3. Before this, I was running a stage 3- setup on stock injectors and MAF. With stage 3- running slightly over 1bar at redline, my injector duty cycle was in the 130-140% range:
I recently logged injector fuel on time again to compare injector duty cycles before/after upgrading injectors and I'm still over 100% (~110%) near redline:
I only increased boost 3 psi, but stock injectors at 5 bar fuel pressure supposedly flow less than 400cc/min whereas the Bluetops I have in there now should flow almost 490cc/min at 5 bar fuel pressure.
Old 07-24-2005, 08:03 PM   #2
sj6sp
Default I don't have any logs on my PC but should get some this week...question though
Are you O2 voltages looking good?
<A HREF="http://www.marsavius.net/qclub" target="_blank">
sj6sp is offline   Reply With Quote
Old 07-24-2005, 08:05 PM   #3
Default That's the thing, 02 voltages are awesome. I am actually a bit rich on the top end now.
It makes no sense to me, totally stumped. I'm hoping people of all different mod stages, even stock, will post so I can see the progression of duty cycle. This could turn into a really informative thread, but people need to gather info. If anyone local to me has some time so I can log their car's fuel injector on time for this, I'd be very grateful.
Old 07-24-2005, 08:32 PM   #4
O.W. Kenobi
Rest In Peace
Default Are you on Zurich time or something? It's not Monday yet!
O.W. Kenobi is offline   Reply With Quote
Old 07-24-2005, 08:33 PM   #5
Default I am posting this late tonight in order to get Monday morning people to respond.
I don't actually expect many responses this late, but I wanted this to be posted before I wake up.
Old 07-24-2005, 11:41 PM   #6
VerrÜckt
Default Of course you're rich. You've hardly pulled back any fuel...
and X chip software is designed to run really rich.
Quit diddling around with narrowband sensors and tune with a wideband.
I'll try to get you some logs sometime. My primary fuel is -12.1% and I know I'm still pretty rich.
VerrÜckt is offline   Reply With Quote
Old 07-25-2005, 05:44 AM   #7
Flyboy
Default APR Stage3 Graph
www.MyAudiS4.com/vast-sucks (Updated: 20 Jan 2012)
Stock -> APR Stg1/2 -> GIAC Stg2 -> APR K04 Stg3 -> EPL TiAL 605 -> V̶A̶S̶T̶ EPL/Frankenturbo F4H
Flyboy is offline   Reply With Quote
Old 07-25-2005, 06:27 AM   #8
k04/rs6north
Default ygm with data
2001.5 Nogaro S4
2002 Black Allroad 6spd
RIP Matthew Ammon aka O.W. Kenobi
k04/rs6north is offline   Reply With Quote
Old 07-25-2005, 06:33 AM   #9
DAP@EPL
Audiworld Sponsor
Default Greentops. :P
Seriously, I'd recommend some wideband datalogging. Its probably not ideal to max out the injectors, but as long as they are providing sufficient fuel to prevent you from running lean (where the wideband comes in... I still have a hard time relying on the narrowband sensors), then you should be ok.
Who knows... maybe your car is running really rich at the top end. And I'd suggest posting injector duty graphs instead of injector on-time... makes it much easier to read (and its not that hard to calculate).
-Dave Pramanik
DAP@EPL is offline   Reply With Quote
Old 07-25-2005, 07:03 AM   #10
VerrÜckt
Default 2nd.
httpwwwstealth316com2calcidchtm
