Old 07-21-2005, 12:23 PM   #11
Tomasz@Startup
Account #: 683
Default Ughh. I have 8" - 600 and 800.
I would be happy to order you some Eibachs. $75 each. (And on Trackports you should really run helper springs in the rear. These would also be $75 each including the spacer.)
If you decide for 500/600, the 600 springs are on e-bay.
Tomasz@Startup is offline   Reply With Quote
Old 07-21-2005, 12:31 PM   #12
übertek
Account #: 90395
Default i have a set of used ones in my living room, supposedly with 5K miles on them...
i've never used them, anyway to tell what the rate is on them? they are just painted dark blue, that's all.
2007 VW Passat Wagon 2.0t
the t is for turd!
übertek is offline   Reply With Quote
Old 07-21-2005, 12:38 PM   #13
tweaked_blueberry
Account #: 21318
Default I live in LA and the road here is terrible especially driving down sunset
I took this chick out last night and my cpp's were squeeking at me and the suspension was way too tight to just cruise...
ASP CUstom Tuned Stage 3 Featuring Virgin K04's
Ported 2.7 Heads w/ Match Ported 01.5+ Manifold
MTM Headgaskets
RS4 Cams
034 Fuel Pump
RS4 Y-pipe
DUH FMIC & Oil Cooler
DUH / Labree Split DP's & Dual 2.5'' Exhaust
Forge DVR
RS4 MM & TM
Vogtland GT's
ECS Stage 4 / 6 Piston Cross Drilled / Slotted, Stasis 298mm
358 Dyno Dynamics Wheel HP on 91, 420 Wheel on 109.
tweaked_blueberry is offline   Reply With Quote
Old 07-21-2005, 12:41 PM   #14
tweaked_blueberry
Account #: 21318
Default What exactly do the helper springs help?
I'm assuming I would need a 6'' rear spring and a 8'' front spring?
MTM Headgaskets
RS4 Cams
034 Fuel Pump
RS4 Y-pipe
Forge DVR
RS4 MM & TM
Vogtland GT's
Old 07-21-2005, 12:41 PM   #15
Tomasz@Startup
Account #: 683
Default Look on the bottom/top. That is where they are marked, though thay may have rusted over.
Old 07-21-2005, 12:43 PM   #16
Tomasz@Startup
Account #: 683
Default They keep your rear 8" spring from being loose when you raise your car.
Spring lengths would be the same. Though you could - if you wanted to go little shorter. 9 and 7 for example.
Also, take a look here.
Old 07-21-2005, 12:44 PM   #17
übertek
Account #: 90395
Default thanks, i'll look on them when i get home.
the t is for turd!
Old 07-21-2005, 12:54 PM   #18
tweaked_blueberry
Account #: 21318
Default Let me know =;
MTM Headgaskets
RS4 Cams
034 Fuel Pump
RS4 Y-pipe
Forge DVR
RS4 MM & TM
Vogtland GT's
Old 07-21-2005, 12:58 PM   #19
tweaked_blueberry
Account #: 21318
Default I remember I had a tall 800 spring and I couldn't lower the car to 25''
I had to trade it in for a shorter one is all.. i'm at 26 and 3/8's right now but would want to be able to go to 25 if i wanted to.. Ideally a 550 9'' spring in the front and a 650 7'' spring in the rear would fit my needs I think..
MTM Headgaskets
RS4 Cams
034 Fuel Pump
RS4 Y-pipe
Forge DVR
RS4 MM & TM
Vogtland GT's
Old 07-21-2005, 01:05 PM   #20
übertek
Account #: 90395
Default i will email you when i get home take it the marking is still there.
the t is for turd!
