Old 07-21-2005, 09:13 AM   #1
Tomasz@Startup
Account #: 683
Default What fender height are you running?
I want it to look good, but also to have plenty of clearance. (My wifes car, and she is not going to pay special attention.)
Today mine is at 26F and 26 1/8R - little high.
Tomasz@Startup is offline   Reply With Quote
Old 07-21-2005, 09:17 AM   #2
BlackS4tt (Josh)
Account #: 68919
Default 25.25R/25.5F
Email: blacks4tt AT yahoo.com
VAST Tuned Stage III, Blouch 997 KO4s, Custom FMIC, Stoptech, OZ
BlackS4tt (Josh) is offline   Reply With Quote
Old 07-21-2005, 09:26 AM   #3
Gator Al (Al)
Account #: 67457
Default 25.875F/26R-- Stasis "Conservative Street Setup".
I'm with you-- I'd like it looks-wise just a little bit lower, but it's nice to be able to better clear speedbumps, etc. Cornering is very good, as opposed to <great!> when lower...
Gator Al (Al) is offline   Reply With Quote
Old 07-21-2005, 09:33 AM   #4
PSmalls::DoggieStyle
Account #: 69223
Default ~25.5" all around
Old 07-21-2005, 09:39 AM   #5
Tomasz@Startup
Account #: 683
Default Thank you. I see there are many people runnign conservative settings. Cool.
Old 07-21-2005, 09:42 AM   #6
spyda head
Account #: 46336
Default question about fender height
is'nt fender height subject to the wheel/tire combo you are running? shouldn't you measure from the center of the hub to the fender lip? when i went from 17's to 19's if i put my fender height the same as with the 17's(ground to fender)i look so slamed it's stupid,had to raise it up about 1/2 inch,and it still looks lower than the stock wheels.
spyda head is offline   Reply With Quote
Old 07-21-2005, 09:43 AM   #7
Tomasz@Startup
Account #: 683
Default I will be lowering it in the next few minutes. 25.875/26.000 Thanks.
Old 07-21-2005, 09:49 AM   #8
Tomasz@Startup
Account #: 683
Default Yes it is, but many of us run the same O.D. wheels/tires.
Your recommendation is valid, but ground to fender has stuck...
I can also tell you that if your fender is bent (as after hitting a tire wall) it is hard to get an accurate reading as well.
Old 07-21-2005, 09:52 AM   #9
ryans4
Account #: 4359
Default 24 Front / 24.375 Rear...
ryans4 is offline   Reply With Quote
Old 07-21-2005, 09:53 AM   #10
Tomasz@Startup
Account #: 683
Default Wow, that is low. I like it.
