Old 12-11-2004, 06:27 PM   #1
My2ndS4
Account #: 46878
Default For those of you who haven't gotten Lemmiwinks to work with a serial emulator,
put the latency timer to 1ms. To do this, plug in your vag-com cable to the usb port you setup to use with lemmiwinks, then open up device manager. Click on ports, and you should see the port that you setup for lemmiwinks. Double click on it, and go to the options tab. Click on the advanced options tab, then put the latency timer to 1ms. This is all from my memory, but it should work.
Specifically, if you get the following error, this procedure should correct it: "ECU uses unknown protocol (KW: 01/8A)"
Thanks to Uwe at Ross-tech for the help!
My2ndS4 is offline   Reply With Quote
Old 12-11-2004, 06:44 PM   #2
mtmOla'
Account #: 63720
Default how do I get Lemmiwinks to work period?
i cant get the thing to connect. I connect through com3 and lemmiwinks says something like bad connection 055 or something like that.
AIM:crypsatir
mtmOla' is offline   Reply With Quote
Old 12-12-2004, 12:17 PM   #3
My2ndS4
Account #: 46878
Default Try the procedure I used in the link in my sig
Old 03-31-2005, 05:12 PM   #4
PSmalls::DoggieStyle
Account #: 69223
Default Damn, I was all excited until I read the end and see it doesn't address the error message I get.
ecu, lemmiwinks, port, protocol, unknown
