Account #: 46878
NOTE: This was updated 10/15/2006 and worked as of then.
How to get Lemmiwinks to work on windows XP: 1.) Go to http://www.ross-tech.net/vag-com/dow...l-COM-Port.zip and click OPEN. When prompted, save it to a location you can find easily just in case, and extract the files to this location. 2.) Now plug the vag com in to the usb that you want to use the lemmiwinks on. 3.) It will go through the found new hardware wizard thingy. 4.) Let the computer search for the software to go with it, but no need to search online (it will find it), and then click yes and such to install it. [NOTE: If the computer chooses the vag-com driver, trying manually selecting the emulator drivers.] 5.) It will go through the found new hardware wizard thingy again. 6.) Let the computer search for the software to go with it, but no need to search online (it will find it), and then click yes and such to install it. [NOTE: If the computer chooses the vag-com driver, trying manually selecting the emulator drivers.] (this is same as before) 7.) You can find lemmiwinks here: http://www.ecodetuning.com/revo/Lemmiwinks.exe 8.) The default for the virtual com port is port 4, so use that. If you get a protocal error, follow the link below:
Thinking about changing your cv boot? Read this first. OEM Pressure Plate part numbers Dead Battery? My FATS Tests How to install usb to serial converter for lemmiwinks on windows xp (UPDATED!) Adjust the latency timer to 1ms if Lemmiwinks still doesn't work Fuel Pressure Regulator Seal Kit There is a second fuse on the back of the radio *I am not a mechanic nor an expert in Audi repair/tuning. In no way are my posts meant to replace professional consultation.*
Account #: 33927
Account #: 69223
Nowhere in Device Manager does it list PORTS (COM&LPT). I tried plugging the USB cable into both USB ports and it didn't appear when plugged into either.
Account #: 33927
Account #: 33927
Account #: 69223
Once you click Hardware, you should see Device Manager.
Account #: 69223
Account #: 69223
I finally got VAG and Lemmi to work. However, I totally didn't follow those instructions and I came out with a somewhat unique result (I think). I have 2 USB ports, but I now can use VAG and Lemmi on the same port by setting VAG and Lemmi to read off of com port 4.
