Old 09-03-2004, 01:44 PM   #1
Woland
Account #: 39771
Default Lemmiwinks access with USB VAG
After all the posts asking how to do this, here is a post on how to do it with link to the correct software.
First, If your laptop has more than 1 usb port, things are very easy. If your laptop has ONLY 1 usb port, its kind of annoying because you have to switch drivers every time you go back and forth from VAG to lemmiwinks. I will describe how to do it with at least 2 ports...
Designate 1 port for lemmiwinks and another port for VAG. For example, right port for VAG, left port for Lemmiwinks. If you are already using VAG, Keep the port that you have now for VAG and just assign a new one for lemmiwinks.
Unplug the VAG cable and plug it in the "lemmiwinks" port.
Go to your device manager in your computer and click to "update driver" for the Vag and select the one provided in the zip file from the link. Once you do this, check which COM port gets created and set lemmiwinks to that port. Lemmiwinks *should* work now.
If you want to use Vag functions, just unplug the cable and plug it in the USB port that you designated for VAG and it should work too. You can now only switch the cable from port to port depending on what you want to use.
If you have only 1 port, you have to uninstall the serial port emulator with the uninstall program in the zip file and reinstall VAG drivers EVERY time you want to switch. Once you get tired of doing this, buy a USB hub and follow the other instructions.
Woland is offline   Reply With Quote
Old 09-03-2004, 01:50 PM   #2
PSmalls::DoggieStyle
Account #: 69223
Default You rock my world, Diego.
Thanks again for answering all my stupid questions via e-mail when I was trying to get this to work.
Old 09-03-2004, 02:24 PM   #3
Hal_TT::CBP
Account #: 3027
Default Nice Diego. Thx. Maybe my inbasket will empty sometime soon =-)
Hal.
Whoops...
I wanna ride...
APR Stg3 (and then some) Sold.
Hal_TT::CBP is offline   Reply With Quote
Old 09-03-2004, 02:25 PM   #4
Hal_TT::CBP
Account #: 3027
Default Do you even have it working yet? lol, too busy posing =-p
Hal.
Whoops...
I wanna ride...
Old 09-03-2004, 02:26 PM   #5
Account #: 69223
Default I don't care to try. My turbos suck and I don't go WOT anymore so who cares :P
Old 09-03-2004, 03:09 PM   #6
LosGatosS4
Account #: 9108
Default Great... thanks! I'll give it a try this evening and see if I can get it to work now
2001.5 S4 Silver/Onyx 6mt
K04's/Piggies/Milltek 3"/ER IC's
Vogtland Coilovers
Volk LE37t
Vast SS
Previous:
'00 S4 Silver/Onyx 6mt
AWE/GIAC Stage III
LosGatosS4 is offline   Reply With Quote
Old 06-13-2005, 04:48 PM   #7
nywidebodys4
Account #: 93177
Default Re: Lemmiwinks access with USB VAG
that didn't work for me the same thing keeps poping up time out accured 0-55 bad ecu respouns man this sucks i have been trieing to get this right for 4 days now and still nothing if any can call me up so i can tell them what i see over the phone i think that will be the best or if anyone has a # i can call
nywidebodys4 is offline   Reply With Quote
Old 06-28-2005, 10:32 PM   #8
Imola_Tip_Soul-Ja
Account #: 56250
Default Read My Post About Lemmiwinks/VAG USB..It Should Help U...
Imola_Tip_Soul-Ja is offline   Reply With Quote
2000, a8, audi, b5, cable, engine, forum, lemiwinks, lemmiwinks, lemmiwinkscom, port, s4, tt, usb, vag
