Old 07-12-2004, 09:05 PM   #1
808Guy
Default MBC install help.
I'm installng the MBC in place of the N75. After searching the archives all I found was diagrams, but no pics of an actual MBC installed. From what I understand the MBC plugs right place using the wastegate and boost hoses that go to the N75. The ambient hose remains plugged into the N75. From my pic can someone confirm that it's installed correctly? Also when adjusting the MBC do you guys start with the screw all the way out and work your way down or start it at some point like 1/2 way?
TIA
808Guy is offline   Reply With Quote
Old 07-12-2004, 10:55 PM   #2
Mike2kS4
Default Looks good.
When I adjusted it I blew into the MBC and screwed it down until I had some resistance. That should be safe.
Watch your boost gauge very carefully. The first few turns you're gonna say "wtf?" and think it's not working, but it will start making big changes in pressure quickly so be careful. 1/4 turn can make a readable difference in pressure.
Old 07-12-2004, 11:14 PM   #3
PsychoS4
Default Are you running your MBC by itself or with N75 too?
X Chip / ASP DP’s / Borla / H&amp;R CO's / Neuspeed 19mm / Toy Guy SS / AWE DTS / APR Snub / More...
PsychoS4 is offline   Reply With Quote
Old 07-12-2004, 11:16 PM   #4
FatFreeVW
Default you will get a CEL without the N75 hooked up, how do people do it the right way?
97 VW Gti 12v turbo VR6 Dynoed 409whp on 100 octane gas
98 VW Gti 24v VR6 3.1 liter syncro
2000 Nogaro Blue S4 w/ FULL stage 3 from AWE-TUNING installed by ME
FatFreeVW is offline   Reply With Quote
Old 07-12-2004, 11:16 PM   #5
JBear::FATS
Default By looking at his picture, he is running by itself. To run
them in parallel you must SPLIT the boost and vacuum hoses.
________________________________________
2001 S4 6-Speed Santorin
Engine/Drivetrain: ASP Custom Tuned Stage III Fueling, RS4 Y-Pipe/Clutch/Fuel Pump/IC's, X1 Intake, Samco F-Hose, APR Bi-Pipe, Piggie Pipes, Miltek Single, AWE DTS, APR Snub, TG SS, VAST Water/Meth Kit.
Suspension/Brakes: Vogtland GT, Neuspeed Rear Swaybar (Med), Stoptech 332 BBK.
Exterior: 18" BBS CH, M3 Lip Spoiler, SPP Foglight Bulbs, RS4 Grill, E-Codes.
Interior: UUC Alcantata Boot, TwinData
EFU, Strat S4 Logo Floor Mats, HW V1, PhatBox.
JBear::FATS is offline   Reply With Quote
Old 07-13-2004, 12:29 AM   #6
808Guy
Default hmm...I had the screw all the way out and had resistance...
could it be a bad spring in the MBC? couldn't really blow anything out of it. also do I need to put in the TCD now or can I do some runs to set the boost to proper levels first?
Old 07-13-2004, 12:30 AM   #7
808Guy
Default the N75 is still electronically plugged in.
we just removed the pressure hoses and transfered them to the MBC.
Old 07-13-2004, 06:08 AM   #8
lemieux@curbside
Default another pic here.i hope it helps..
check my pic poster..
"it's a B5 S4 ,it may break down, but its far enough ahead, by the time its fixed, you still haven't caught up." -best line i've heard
AUDI B5 S4 detail info (pdf file) that everyone should read and have saved on his computer
AUDI B5 RS4 study guide detail info (pdf file)
FATS database
VAG-COM LOCATOR
ASP Hands down the "BESTEST" tuner out there.
lemieux@curbside is offline   Reply With Quote
Old 07-13-2004, 06:36 AM   #9
Audi2ptzero
Default If your going to leave the N75 in like that
you want to loop a hose betwen the 2 open ends of the N75.
Audi2ptzero is offline   Reply With Quote
Old 07-13-2004, 06:58 AM   #10
DAP@EPL
Audiworld Sponsor
Default That's in parallel with the N75.
He asked about the N75 by itself.
As Audi2ptzero suggested, loop a peice of hose between the open ends of the N75.
As for adjusting, back it all the way out and slowly tighten and test until you reach the desired boost pressure.
-Dave Pramanik
DAP@EPL is offline   Reply With Quote
05, 18t, audi, b5, boost, controller, gti, hooked, install, installation, installing, mbc, s4, vast, vr6
