Old 08-04-2002, 02:01 PM   #1
donistook
Account #: 1510
Default In response to K04 turbo reliability versus K03
You've got to realize that the K03s are still well known to take a dump when only run at stock boost levels which is only about .6 to .7 bar.
The stock RS4 runs more boost than that.
I would venture to bet that every single person here in the US that has switched to K04s will be running higher levels of boost than the stock K03 original figure.
If you want to make things even, talk to someone that has switched to K04s into lowering their boost to stock S4 boost for a year or two and then look at the results....I don't think that you will find anyone willing to do that....because why have they switched if it wasn't to gain higher horsepower...and they are going to be running at least .8 bar or greater. We have raced with K04s for two years and we run consistently with 1.2-1.4 bar and have NEVER had a K04 problem....
Don Istook
donistook is offline   Reply With Quote
Old 08-04-2002, 02:06 PM   #2
Bryce
Account #: 1414
Default Curious.. what oil do you use also.. TIA
'01.5 S4 Avant gone but still have '82 4000S
AWOT Braintrust #180 n00b index = 2.848507031
A.S.S. = Association of S4's in Sacramento
Pics of long ago Audi Events and Track/Auto-X days
In a world filled with clueless sheep buying SUVs, minivans, and bland automotive appliances, I figure I must be doing something right if my car disturbs their delicate sensibilities. It's like a bright yellow one-finger salute as I pass and they become tiny specs in my rear view mirror. :)
Bryce is offline   Reply With Quote
Old 08-04-2002, 02:08 PM   #3
Jeremy Clarkson
Account #: 25679
Default Out of curiosity, how do you guys let the turbos cool after a race?
Jeremy Clarkson is offline   Reply With Quote
Old 08-04-2002, 02:28 PM   #4
jyoteen
Account #: 439
Default I do believe Don mentioned that they have a manually operated cooling fan thingamabob.
jyoteen is offline   Reply With Quote
Old 08-04-2002, 03:15 PM   #5
poopeter-el sigthief
Account #: 36951
Default a thingamabob huh? where can I buy on of those?
poopeter-el sigthief is offline   Reply With Quote
Old 08-04-2002, 03:18 PM   #6
DanosS4
Account #: 33628
Default I sell you one
DanosS4 is offline   Reply With Quote
Old 08-04-2002, 03:54 PM   #7
donistook
Account #: 1510
Default We just let the coolant pump run for about 3-4 minutes
Old 08-04-2002, 03:55 PM   #8
donistook
Account #: 1510
Default Royal Purple Racing Oil-Racing 21 (about 10W30)
Old 08-04-2002, 04:22 PM   #9
Kent L
Account #: 19404
Default Did you attach a seperate switch to the coolant pump?
Stock afterrun coolant pump correct? Thanks.
Kent L is offline   Reply With Quote
Old 08-04-2002, 04:49 PM   #10
donistook
Account #: 1510
Default Yes...we just put in a toggle switch with direct 12V...very simple
20t, a4, audi, b7, fsi, k03, k03s, k04, ko3, ko4, reliability, s4, sale, turbo, turbos
