| A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present |
#1 |
#2 |
looks awesome
2008 BMW M5 2007 A6 4.2 Sold 2002 A6 2.7t GIAC+ other mods 2006 Corvette C6 Convertible 2007 Corvette Z06 1966 Olds Toronado 2000 BMW R1100RS livetoride63@aol.com |
#3 |
Junior Member
are they light weight for 20's???
and how are the cornering dynamics at speed??? Again wheels look really sharp...congrats. |
#4 |
Car handles and corners close to stock. Barely noticeable increase in understeer at high speeds. Wheels are about 27-28lbs each
#5 |
Junior Member
i like staggered rims on audis, but i am hesitant due to factory-like durability issues with the all wheel drive torsen system.....is there anything to be concerned about? facts, not hearsay...
#6 |
AudiWorld Uber User
![]() Join Date: Mar 2000
6% of one another, the Torsen will be fine.
ABS and ESP should also be ok within this tolerance. However, a smaller spare tire may present a problem to the Torsen, and safety systems if driven very far at all. Since the front tires wear faster than the rears, you won't be able to rotate them. Also, the car will understeer even more than it presently does, so this is purely a cosmetic upgrade at the expense of handling. Quattro Audi race cars run wider wheels up front whenever allowed by sanctioning bodies. The ideal solution if you want the look, is to run wheels with the same width but with different offsets to create the bumped out rwd look without the downsides. After all, wider rear wheels are first and foremost an attempt to harness power that might not otherwise get to the ground in a 2wd car, or to correct for handling flaws that might make a car tail happy. Neither are issues for streetbound Quattros :-)
#7 |
Junior Member
I am leaning towards same width....still not sure about getting offset wheels. Most likely going to go with sportec or neuspeed wheels, unless mtm makes something asthetically appealing anytime soon
| Tags |
| 20, 2006, 2007, a6, c4, c6, corvette, inch, mtm, offset, rims, sport, staggered, wheel, wheels |
