Go Back   AudiWorld Forums » Technical Discussion » Wheels & Tires Discussion
Old 06-24-2004, 01:25 PM   #1
stormchaser
New Member
Account #: 54769
Default Wheel Help? RS 4 replicas from Wheel Exchange/AAA? Are these lighter than OEM RS4 wheels? pros/cons
looking to buy 4 RS replicas made in Italy from Wheel Exchange. AAA seem to have the same ones and I also have a seller of some RS4 ORIGINAL equipment 17's for $1200. The replicas from wheel exchange are $589. Do you think I should spend the extra money and get the used OEM's? The replicas are 21 pounds. Is that heavier or lighter than the OEM's?
Thinking about Conti contact extreme tires. Need good rain performance and grip. Also the Potenza 750's but might not be available with 17's. My car is a 1995 S6 Avant
stormchaser is offline   Reply With Quote
Old 06-24-2004, 01:41 PM   #2
jprice@CPS
Member
Account #: 8422
Default if the replicas are 21 lbs, they are lighter than OEM.
Minnesota Audi Club
2001.5 Audi A4 1.8TQMS
APR Stage 3+, APR Exhaust, Eibach Pro Street Coilovers, Neuspeed 19mm rear sway.
jprice@CPS is offline   Reply With Quote
Old 06-24-2004, 02:11 PM   #3
EB_1920
Account #: 27549
Default FWIW, I like the conti extremes. I also have a 95 S6 Avant.
Adam
95.5 S6 Avant w/ mods
FrugalMechanic.com
EB_1920 is offline   Reply With Quote
Old 06-24-2004, 08:45 PM   #4
stormchaser
New Member
Account #: 54769
Default How do you like the Bilsteen set up? I had HD's without lowering and found them too stiff?
I have Boge Gas struts now and they felt great for a few days but have softened up too much.
Old 06-25-2004, 01:37 PM   #5
EB_1920
Account #: 27549
Default I like the current set up, but.......
I haven't tried out any other shocks/springs, so I don't have a lot to compare it to.
Adam
FrugalMechanic.com
Old 06-25-2004, 10:04 PM   #6
353/s/
Senior Member
Account #: 34226
Default I would go with Hartmann
As from what I've heard they are higher quality than AAA.
353S / www.quattive.com
353/s/ is offline   Reply With Quote
Old 06-26-2004, 04:57 AM   #7
Hartmann/Achtuning
Account #: 29370
Default I think someone is not telling the truth, 21lbs?
I have seen just about all the reps out there and 21 lbs I would question. Our wheel is 24.5lbs and others I have samples of are 25-26.
Bill
Bill
WWW.Hartmannwheels.com
WWW.Achtuning.com
WWW.Getapr.com
Bill@Hartmannwheels.com
Bill@Achtuning.com
425 895-OOOO
2001 S4 Avant
2003 Allroad
1999 A6 Avant
Hartmann/Achtuning is offline   Reply With Quote
Old 06-28-2004, 12:33 AM   #8
ex-quattro PETE
AudiWorld Expert
Account #: 16447
Default Which RS4 OEM rims are you talking about?
The 17x7.5 RS4-style celebration wheels are 19.5 lbs.
But lighter is not necessarily better for cast wheels. Cast + light generally equals soft. The celebrations wheels bend very easily because they're so light.
ex-quattro PETE is offline   Reply With Quote
Tags
aaa, exchange, wheel
HTML code is Off
