Go Back   AudiWorld Forums » Technical Discussion » Wheels & Tires Discussion
Old 03-26-2004, 01:08 AM   #1
pcordeiro
New Member
Account #: 72703
Default A4 Avant b5 225/45/R17 Tires Pression information
I 've recently changed my a4 avant b5 tires to 225/45/R17. I dont find the tires pression information anyware. The tires are Firestone SZ80.
thanks in advnace,
Pedro Cordeiro
pcordeiro is offline   Reply With Quote
Old 03-26-2004, 02:18 AM   #2
ex-quattro PETE
AudiWorld Expert
Account #: 16447
Default This is for a B5 sedan...
If you're running with minimal load, you can probably use these figures. If you're running full load, you can probably bump up the rear PSI a little more, since the avant can carry more load (right?).
In any case, don't ever go above the max. PSI listed on your tires.
ex-quattro PETE is offline   Reply With Quote
Old 03-26-2004, 03:30 AM   #3
pcordeiro
New Member
Account #: 72703
Default Re: This is for a B5 sedan...
Thanks a lot!
Old 03-26-2004, 08:09 AM   #4
Silver 2.7tt
Junior Member
Account #: 37216
Default I see that as well; the recommanded tire psi is insanely high
compared to other cars. My wife's C230 light load recommandadtion is 28f and 31r. ours is 36psi and for A6 with M+S rating the psi is even higher. even higher than BMWs
Silver 2.7tt is offline   Reply With Quote
Old 03-26-2004, 01:17 PM   #5
ex-quattro PETE
AudiWorld Expert
Account #: 16447
Default It probably has to do with the weight of the car
Audis are generally pretty heavy, especially when equipped with quattro, auto trannies, etc.
Old 03-29-2004, 07:26 AM   #6
TristanP
Member
Account #: 20538
Default IIRC, my '01 Avant has the same info on the sticker
TristanP is offline   Reply With Quote
HTML code is Off
