Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 04-05-2006, 10:04 AM   #1
BLKPERL
Senior Member
Account #: 17918
Default Got results from Leakdown test
Compression test:
1-190
2-195
3-200
4-200
Leakdown test:
1-5%
2-9%
3-5%
4-5%
My mechanic told me <3 0% leakdown is OK
Is this good?
If APR doesn't find this engine as healthy for Stage 3+ tuning, then I'll be ordering the GT2871R eliminator turbo kit with unitronic software from Renn-art
2001 B5 A4 1.8TQMS CH Ecu
Performance:
APR Stage 3+, APR FMIC, Carbonio Intake, APR Exhaust, Cryo Southbend SS w/Unorthodox flywheel, Autospeed DTS, Forge BPV, SPAL EFK w/180 degree thermostat, S4 engine mounts, S4 fender liners
Suspension:
Vogtland Coilovers,H-sports, CPP Rear sway bar links
Brakes:
Stoptech 332mm,S4 rear brakes, Ferodo DS2500 all around
Exterior:
Reiger RS4 bumper (summer),S4 bumper(winter),S4 skirts,S4 rear, Tint: 35% front, 20% rear
Street: 18" Silver OZ SLs,225/40 Kumho SPT
Winter: 17" Flik Lex, 225/45 Dunlop Wintersport 3D
Interior:
S4 Silver Beltline trim,Landspeed Aluminum Shifter Plate,UUC Rob Knob w/Custom insert,Tycoon Alcantara Shift boot,LLTEK M&amp;S mats,Beetle Sunglass holder, Valentine 1 hardwired w/LI-S4 display, Awe-Tuning pedals
Sounds:
RNS-E Navplus, Phatnoise Phatbox
My Dyno Chart: 295 whp 277lbs
My Compression &amp; Leadown tests
B5 1/4 mile database
B6 1/4 mile database
B7 1/4 mile database
B7 Carbonio Intake Log
Vag Com Data Log
Vag Com Tech Section
Edy Jun's FAQ
BLKPERL is offline   Reply With Quote
Old 04-05-2006, 10:06 AM   #2
Kris Hansen
Chief of Goat control
Account #: 20
Kris Hansen's Avatar
Send a message via MSN to Kris Hansen
Default Why did they do a leakdown test with nice compression numbers like those?
Kris Hansen is offline   Reply With Quote
Old 04-05-2006, 10:09 AM   #3
mAd1(gt3071r)
Member
Account #: 57175
Default 2nd. I' wouldn't waste time or money doing a leak down since the compression numbers are that good
mAd1(gt3071r) is offline   Reply With Quote
Old 04-05-2006, 10:09 AM   #4
BLKPERL
Senior Member
Account #: 17918
Default APR Stage 3+
2001's don't have software yet, so I might be the test car. APR told me to get a leakdown to make sure the engine is good
Performance:
Suspension:
Brakes:
Exterior:
Interior:
Sounds:
Vag Com Data Log
Edy Jun's FAQ
Old 04-05-2006, 10:10 AM   #5
BLKPERL
Senior Member
Account #: 17918
Default Thanks
Performance:
Suspension:
Brakes:
Exterior:
Interior:
Sounds:
Vag Com Data Log
Edy Jun's FAQ
Old 04-05-2006, 10:11 AM   #6
mAd1(gt3071r)
Member
Account #: 57175
Default Valve failure?
Old 04-05-2006, 10:14 AM   #7
wolfpack5
New Member
Account #: 105896
Default 30% leakdown is too much
I think the limit is closer to 15% (BMW anyway). Your numbers look good, tho.
wolfpack5
2000 A4 Quattro 1.8T
97,100 miles
wolfpack5 is offline   Reply With Quote
Old 04-05-2006, 10:22 AM   #8
Kris Hansen
Account #: 20
Default Sure they do! If all cylinders are high, and close to each other, you are sure that the engine ...
seals internally well. it's when you have 2 or 3 relly good, and the rest not so good that you start doing leakdown tests on the bad holes.
Old 04-05-2006, 10:22 AM   #9
BSCA4
Senior Member
Account #: 34916
Default Actually, leak down #s is more important than compression #s IIRC
Cheer,
Ryan
1.8TM traded!!! Future 1.8TAQMS (I WILL BE BACK)
BSCA4 is offline   Reply With Quote
Old 04-05-2006, 10:30 AM   #10
Kris Hansen
Account #: 20
Default not really.... They are just different. A compression test is easier to run...
A leakdown test can help you pinpoint a more severe problem.
While a compression test is a dynamic test (engine moving), a cylinder leakdown test (C.L.T.) is a static test (engine at rest). The compression test measures how much pressure the engine can produce while cranking; in contrast to the C.L.T., which measures how much pressure is lost in the engine. In a C.L.T. the engine is placed on TDC of the cylinder in question and using a similar type of connector as the compression test, we fill the cylinder with pressure. The tester then measures the volume of air needed to maintain a predetermined pressure in the cylinder. This reading is expressed in a percentage. Good cylinder leakdown readings should be below 5-8%.
The great thing about C.L.T. is that it deals with how well the cylinder is sealing and nothing else. The readings are not affected by carbon deposits, cam timing, or even engine cranking speed.
Another great feature of the C.L.T. is the fact that you can hear where the air is leaking out of the cylinder. When a cylinder has high percentage of leakage, first check the oil filler cap. Do you hear a hissing sound? If so, you may have pressure leaking by the rings. Is there air escaping out the exhaust? Is it escaping out the intake system? Then a burned valve may be the problem. If two adjoining cylinders have similar low readings and you hear leakage out the other cylinder, then a failed head gasket may be the problem.
Being able to pinpoint the exact source of the compression loss will tell you where the problem is; and not just that you have one. This knowledge will greatly assist you in the next step... the repair.
