Go Back   AudiWorld Forums » Audi Models » Audi A5 / S5 Coupe
Old 09-18-2008, 01:14 PM   #1
snow day
Account #: 8574
Default Wheel fitment tip
There's been a number of posts about wheels that fit prior Audi models will no longer fit the B8 chassis used on the A5/S5 (and new A4).
The main issue is the B8 hub diameter is larger (67 mm) than its predecessor (57 mm) so the older wheels won't fit over the larger hub.
If the wheels have interchangeable centering rings, you may be able to obtain new rings for the new hub size, depending on the wheel manufacturer.
I've got some BBS wheels I've used on past Audis that I'm considering using on my S5 (if it ever shows up). I confirmed with BBS-USA (770-967-9848 ext 3027, Michael Cox) that new rings are available for $4 each.
Of course I will need to check for caliper clearance and offset, but the point is many existing wheels may be able to be converted to fit the B8. Just a friendly tip.
Current Quattro fleet:
2009 S5 6-spd Stick/Phantom/Blk Alcantara/SS Trim/Drive Select/Tech/Nav/B&O/Quattro
2005 A4 2.0T Quattro
2003 A4 1.8T Avant Quattro
2001 911 Turbo Quattro
1994 Silverado Quattro
snow day is offline   Reply With Quote
Old 09-18-2008, 01:59 PM   #2
rferni
Junior Member
Account #: 91492
Default Good info ... thanks very much
2008 A5 3.2 6MT, Ice Silver, Black, Premium, B&O, Nav
Gone, but never forgotten: 2005.5 A4 2.0T FSI Quattro/Tip/Dolphin Gray/Light Gray
rferni is offline   Reply With Quote
Old 09-18-2008, 03:37 PM   #3
Quattrings
Account #: 14368
Default That is true, but you may find that the offset (usually 35 ET of past Audis) doesn't have the
same look (fitment) on our wider setup. Spacers can cure that though.
Quattrings is offline   Reply With Quote
