| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Account #: 432
I did manage to have my dealer VAG my bluetooth connector so that my voice activation now works perfectly in the roadster. Then I tried the iPod. Now, I've read that the adapter really sucks and I'm believing it. I have an iPod Classic 80G - and of course, none of the adapters fit - so I just inserted the thing into the slot. It worked - for about 5 minutes. Then the system didn't recogize CDs 7-12 and just gave me the "NO CD" reading and defaulted to AUX. Even when it was working, it didn't read my playlists properly - but I was able to get songs to play from the unit. Now, I'm just getting the error message. Two questions - is there an adapter I should be using for this iPod that isn't supplied with the car? And second, any thoughts as to why the unit's not working? It's a new iPod that does work fine with headphones, so I'm stumped. Back to the dealer - what's everyone's experience. I haven't tried the AUX input, but shouldn't have to with the adapter.
Thanks for any suggestions.
Phil G. Maple Glen, PA 2008 Audi TT Roadster, 3.2, 6MT, Ice Silver, Black Nappa Leather, S-line, Magetic Ride, Xenons, 19" RS4 style wheels, Audio package, Bluetooth, and iPod adapter. 2009 BMW 328i (x-Drive) sedan, Space Gray, Oyster Leather, Steptronic, Sport Package, Logic7, Sirius, Cold Weather Package, Xenons, iPod adapter. 2004 Carrera 4S Coupe, 6MT, Atlas Grey, Black Full/Supple Leather, Bi-Xenons, Technic Package, Stainless Exhaust, Heated Seats, Wheel Caps with Colored Crests, Bose High End Sound, 6 disc CD, Rear Center Console Alu-Look, OEM SSK, Clear Side Markers, 3M ClearBra, 3100 miles!! |
#2 |
AudiWorld Uber User
Account #: 33185
I thibnk the unit is not seated properly and is disconnecting when you hit a bump in the road.
My Nano also doesnt fit any of the adapters but is much lighter in weight and rarely comes unseated. Still, Ive been burning "Data" MP3 CD's and they are superior to the iPod in that they actually display my playlist and track names on the head unit as I wanted from the iPod to begin with. Im wanting a software update to make the iPod work like a Data CD does, but we'll see. HTH |
#3 |
Member
Account #: 13742
With the 160GB classic I think I'm using shim #4 (I can double check when I leave work), but if the thickest shim still isn't tall enough you could probably add some tape or something to fill the gap. The main concern is to try to keep the bottom of the ipod resting on something so as to not put pressure on the dock connector or have it bounce loose while driving. As for CD7-12, I'm pretty sure those aren't supported. I think you just get 5 playlists on CD1-5 with CD6 playing the full library. It will also continue playing whatever happens to be playing when you dock the ipod, so what I typically do it keep it on CD6 and get whatever I want queued up manually before docking.
#4 |
Account #: 432
or do they clip onto the inside of the glovebox door??
#5 |
Member
Account #: 13742
which is about 3/4" or so wide. If you're holding the shim, the end with the small indented circle should face away from you and slide in first. The end with the the two flanges and the elongated oval indententation faces out and the raised part should look like a little ramp leading into the dock. It might take a little trial and error, but ideally you'll find one that is just tall enough so that the back of the ipod sits on it when it's level in the dock.
#6 |
Junior Member
Account #: 132613
I gave up and moved all my music to SD cards, which provide the playlist, not as conveniant but it's an improvement on a fake ipod integration system.
#7 |
Member
Account #: 65980
If you don't make a playlist, then it will find the first album and start playing it. Any attempt to scan to other albums or even other tracks within the first album will all fail. It just resets back to CD1, track 1 on the ipod. What an incredibly weak implementation.
-Fred 08 TT 3.2 coupe, 1k miles |
#8 |
Account #: 145858
Hey Phil,
Other than the Audi iPod adapter grief, I hope the car is treating you well. As my thread reads, this is the second time I have fallen for buying this ridiculous option and the second time I am kicking my own a$$ for doing so. (Actually its the third time if you include my girlfriend's Golf.) To go along with what the other guys are saying, here are a few tips on making your USD $250 / CAD $300 option worth something. First off you have to think of the Audi iPod adapter as a CD changer emulator. It uses the CD changer controller functions in the head unit and thinks of the iPod playlists as CD's in the changer. It allocates CD positions 7 to 11 on the head unit to the first five playlists on your iPod and uses CD position 12 to play your entire iPod. (CD positions 1 to 6 on the head unit remain allocated to the in-dash CD changer.) If you want to take advantage of this, the next best thing to do is create five playlists in iTunes specifically for your Audi. Since the iPod adapter will play the first five playlists on your iPod and both iTunes and your iPod will sort them alphabetically, I suggest using the numbers "1", "2", "3", "4" and "5" as your playlist names. You can add descriptive names after the numbers if you so choose. This helps in remembering what is in the playlists, since the head unit does not display that information. Some examples: 1 2 3 4 5 1 Pop 2 Rock 3 Rap 4 Country 5 Soundtracks 1 Madonna 2 Foo Fighters 3 Run DMC 4 Willy Nelson 5 Ironman Soundtrack Now you can associate those playlists and the music you placed in them with the appropriate CD position on the head unit. Installing your iPod should be relatively easy. Your car should have come with a small plastic bag full of different sized plastic adapters and rubber shims to help fit the different sized iPods into the Audi iPod Adapter. Mine was in the glove box when I took delivery of the car. I have the older, larger 60GB iPod photo and it fits the adapter perfectly without any other plastic adapter pieces or shims. My 8GB Nano (as CL has pointed out) doesn't fit any of the adapters...well. I did manage to make it slide very tightly into one of the adapters, but it is difficult to get out. There should be a specific sized adapter for your iPod. If not, have a go with slipping the different sized shims underneath (as ebusch suggested) until you find the one that supports your iPod the best. CL is likely right about your iPod coming unseated and causing the head unit not to see it. The slightest gap will cause this. ebusch also has another great tip from a glitch in the Audi iPod adapter: If you have been listening to your iPod before plugging it in to the Audi iPod adapter, the head unit will begin playing where you left off listening previous to plugging it in. Just pick whatever playlist you like on your iPod, (if you prefer something other than playlists 1 to 5,) press play on your iPod and then plug it in to the iPod adapter. Something else to note (if you haven't already read it here) is that sometimes the iPod will keep playing after you have shut the car off. There's been mixed feedback from different members and their various iPods but I am personally relating it to charge and/or age of the iPod and therefore it's battery strength. I leave my 8GB Nano plugged into the Audi iPod adapter almost all of the time. On a few occasions I had turned on the head unit and it has displayed the same "NO CD" message. At first I thought it was a connection, but later realized it was because my iPod was flat. When the iPod is completely flat it requires a certain amount of charge before it can play again. Just running the car with iPod plugged into the Audi iPod adapter hasn't been enough in my experience. Pulling the iPod out and fully charging the unit has since remedied the problem. My Nano hasn't run flat since. Now for the good part: After dealing with all of this crap with my Audi iPod adapter I have just recently ordered and received a Dension Gateway 100 iPod controller. It plugs right into the head unit and will replace my Audi iPod adapter. According to their website it will emulate the iPod (not a CD changer) and give you access to all playlists and other means of organizing your music. It will also display track information on your head unit and DIS. If you navigate around their site there's another unit with more options and other accessories to allow for more functionality, but the Gateway 100 seemed nice and simple. Oh yeah, and for about CAD $180. Once I have it installed later this week, I'll let you know how it goes. Other than that, enjoy your new car and don't let your Audi iPod adapter get you down. Just turn off the head unit, put the top down and listen to that sweet sounding 3.2! That's better music than you will get from any stereo...
Tony Regina, Canada DONE with the Q5 forum... |
#9 |
Account #: 121042
I was looking up Dension 100 as you post. I found this list
http://www.automobilitydistribution....list%20New.pdf The unit is not text capable in our TT.... I wish it does too, i just hope to get to you before you purchase it |
#10 |
Account #: 145858
Well if it doesn't work I'll just return it. Thanks for the heads up! Going to pass that on to the dealer as well.
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
