Go Back   AudiWorld Forums » Audi Models » Audi Q5 & Q7 » Q7 Discussion
Old 03-23-2008, 07:49 PM   #1
nebalt
Account #: 70685
nebalt's Avatar
Send a message via AIM to nebalt Send a message via Skype™ to nebalt
Default Detailed Dension Gateway 500 Installation instructions w/ lots of pictures...
First of all, many thanks to Christian from Enfig Car Stereo who helped me with this install. But to be honest, it is fairly straight forward and even a dummy like me can do this, especially after having installed bunch of Dice and Icelink units in all kinds of Audis.
Parts needed:
Plastic pry tools (panel poppers) from Zdmak $25
Dension Gateway 500 for Audi Enfig Car Stereo $450
T25 Torx
Radio Removal Keys (2)
45 minutes of time
Make sure the car is turned off and the key is off the ignition before you start this installation. First we take out the CD changer (make sure it is empty) with radio removal tools as the Dension will go behind it. Next you will need to remove the hazard switch module by prying that out in order to get the CD changer out. This is needed in order to gently push up the vent housing so the CD changer can slide out.
Next we take out the glove box. I decided to keep the iPod inside the glovebox for stealth look. To take down the glovebox, five screws need to be removed. Three on top and two at the bottom. Sorry no pictures of the actual screws but they are simple enough to find.
We then ran the iPod cable through the chiller vent hole in the back of the glovebox.
And then snaked it through the side opening of the center upright console to the back of the CD changer area where the Dension Gateway will be housed.
Next we popped open the passenger side fuse box using a pry tool.
We ran the power and ground cables (harness) from the Gateway through the back of the glovebox housing to here. Using a Torx 25, we unscrewed the bottom of the fuse box to tighten the black Ground wire. The red, constant 12V, wire was hooked to empty slot # 8. We checked with a voltmeter to make sure the intended slot was 12V, and it was. In fact, any empty slot in the top row will be constant. I recommend utilizing a fuse here. I will be adding an actual fuse this weekend.
Next we ran the USB and AV (Aux) cables back through the side opening to get them to the back of the Gateway.
We successfully made these connections as well. Next we dropped the panel underneath the glovebox. When prying this out, be very careful as clips may fly out to parts unknown never to be found again. Do this gently!
I dropped this kick panel in order to screw the housing for the USB and AV (Aux) connections.
After successfully screwing the housing and popping in the USB and AV switch, I popped the panel back in its place. A lost clip was later replaced.
Next came the fiber optic connections. When handling fiber cabling, be very careful not to tweak or pinch the cables. Use extreme caution. In order to release the provided fiber cables from their respective adapters, you will need to release them from their protective adapters by pushing in the blue locking tab in the middle. The adapters will be released allowing the fiber cables for connection.
First make the connection for the car side.
And then the CDC side. Afterwards simply plug the other ends into the Gateway.
Once all the connections are made, check to make sure you have the correct DIP switch settings. For Q7 with high MMI, only #3 should be in the up (on) position with all others in down (off) position. Refer to your manual for A6 and A8 settings as those are different.
Before we put everything back together, we tested the unit to make sure it worked. AND IT WORKS!!!
This was a fun and easy install. The Gateway is very easy to use as you can control all of iPod's functions from the MMI's wheel. Incoming or outgoing phone calls pause and resume the Gateway after calls are completed. I highly recommend this mod for all music lovers.
I have not utilized Aux or USB cables as of yet to tell you how they work, but I understand, those are magic as well. I have since added an OEM XM module as well and that was five minutes of plug-and-play.
MY SIGNATURE BEGINS HERE!
'01 A6 4.2 / Premium / Cold Weather / Sun Shades / H-Sport Sway Bars (F&R) / Koni Adjustables w/Eibachs / OEM M5 Spoiler / OEM S6 Upper and Lower Grilles / OEM RS6 Side Mirrors / OEM RS6 SE Exhaust / OEM RS6 Carbon Fiber / OEM RS6 Wheels / RNS-E w/OEM BT / iPod DICE / OEM XM / Window and Tip Recode / "nene" Fog mod w/Hoen Xenonmatch H3 bulbs / OEM Winter Mats
'07 Q7 4.2 (wife's) / 20" / NAV / OEM XM / OEM BT Integration / Dension Gateway 500 / OEM Winter Mats / Tow Package / Hoen H7 Xenonmatch Fogs
nebalt is offline   Reply With Quote
Old 03-23-2008, 08:06 PM   #2
Jusforfun
Account #: 109306
Default Excellent. Where did you position the unit itself?
Did you get a good solid fixing?
I have seen it done slightly different whereby only the connection wires were passed in to CD player (which still required removal) everything else done from behind Glovebox.
The USB looks as if it could do with a cap!
Thanks for taking the time to make such a professional post.
Jusforfun is offline   Reply With Quote
Old 03-23-2008, 08:09 PM   #3
nebalt
Account #: 70685
nebalt's Avatar
Default Yes, the unit is solidly behind the CD changer, the reason is...
if I need to take out the CD changer for any reason, it will readily slide out with ample fiber cable slack back there. Plus, I did not want to take a chance of pinching the fiber optics from behind the glovebox. The Gateway is snug in there.
Old 03-24-2008, 03:38 AM   #4
beltsander TKO
Member
Account #: 19943
Default Thanks for the post... it looks easy enough!
<<A4Q7>>
beltsander TKO is offline   Reply With Quote
Old 03-24-2008, 03:57 AM   #5
RAD2
Account #: 105273
Default I love my GW 500
USB port works very well, I just have a USB Flash Drive. I have the rear DVD (vizualogic 1250) sound connected to the aux.
RAD2 is offline   Reply With Quote
Old 03-24-2008, 04:21 AM   #6
Jusforfun
Account #: 109306
Default That makes sense...but what did you bolt it to?
I would be concerned about rattles.
Old 03-24-2008, 07:10 AM   #7
nebalt
Account #: 70685
nebalt's Avatar
Default No bolting necessary...it is snug in there. No rattles whatsoever.
Old 03-24-2008, 11:22 AM   #8
Ginseng Sniper™
Junior Member
Account #: 79295
Default Do you have more information on the XM installation? (part#'s etc...)
BbSrS4rNsES4oEm+UsPGOODNESS
Ginseng Sniper™ is offline   Reply With Quote
Old 03-24-2008, 11:28 AM   #9
nebalt
Account #: 70685
nebalt's Avatar
Default XM part number is 4E0-035-593A....(updated)
all the wiring was in place for the car so this was truly plug-and-play. The unit is housed in rear passenger side. Pry/pop open the panel on the right side where the 12V power outlet is. All of the cabling is in there. Remove the fiber-optic protective adapter and plug into unit. The rest of the cables are color coded.
Bought it from eBay brand new/sealed for $212. Good luck.
Old 03-24-2008, 01:07 PM   #10
Chitown Q7
Junior Member
Account #: 121988
Default Did you have to pull down the roof panel....
...to connect the unit to the shark fin? I had to do this for my Nav install, and there was one more plug up there waiting for the Sat radio.
Chitown Q7 is offline   Reply With Quote
Tags
09, 500, a6, audi, dension, forum, gateway, installation, installers, jersey, ny, panels, philadelphia, remove, special
