Go Back   AudiWorld Forums » Technical Discussion » Suspension Tuning Discussion
Old 09-04-2006, 03:31 PM   #1
Tomasz@Startup
Senior Member
Account #: 683
Default Bilstein PSS9 (B5 S4) dyno results, and suspension ramblings.
I posted few days ago about the single Bilstein PSS9 I dynoed. At that time I warned that the results may not be representative, as I was still waiting for results of the second shock. Now that I dynoed both, I can speak more openly.
I believe that this problem is affecting all B5 PSS9s and potentially all PSS9s.
Here are the dyno results for the front and rear shocks:
As you can see these shocks only offer two adjustment settings, not the 9 that are commonly advertised. There is no difference in the shock performance in the middle settings, only the two extremes matter. I also believe (and this can only be proven by track testing) that these shocks will deliver harsher ride and sharper response at the stiff setting, but with that much rebound less traction and ultimately slower cornering speeds.
I was hoping that with the PSS9s we had a good offering in the sub $2,000 range, but I am confident now that Penskes and Ohlins deliver quite a bit more value.
Until proven otherwise I believe that there are two generic categories of coilovers there: low cost, high durability street optimized twin tube coilovers like Vogtlands (my preference) or Konis, and high cost, rebuild able, race track optimized mono tube coilovers like Penske and Ohlins. Both will deliver lots of value per dollar. Unfortunately the middle ground seems to be a compromised solution... acceptable to many, but still a compromise.
To get the above results I had to spend little over $200. If you are interested in having any other shocks dynoed, please e-mail me. Maybe we could get small donations from a group of enthusiasts and dyno few more offerings. To kick this off I want to share the results from dynoing the B5 S4 Vogtlands:
Tomasz@Startup is offline   Reply With Quote
Old 09-04-2006, 04:02 PM   #2
akula-ssh
Member
Account #: 70933
Default Interesting finding; thanks for sharing!
List of 3.0 owners on AW compiled by A4AdMan
<big>2002 Audi A4 Avant 3.0 Quattro Tiptronic</big>
Premium package, sport package, xenon headlights
Modifications to date:
Neuspeed Sport springs
Koni shocks (50% all around)
H-Sport anti-roll bars
custom stainless steel rear upper spring seat spacer
Silver OZ Superleggera 18x8
Sumitomo HTR Z III 235/40-18 95Y XL (current summer)
Toyo T1R 235/40-18 95Y (previous summer)
Falken GRB FK-451 235/40-18 91Y (previous summer)
Dunlop SP WinterSport M2 235/45-17 94H (winter)
Supersprint resonator and mufflers (quick video clip here)
BMC CDA intake
Alcon B Type calipers
Coleman Racing 13x1.25" 2-piece rotors
Carbotech XP8 brake pads
aluminum interior trim
black bumper grill
opened driver side foglight grill (from 1.8T)
auto-dimming blind-spot Euro side mirrors
bi-xenon E-code headlights
Ultraleds (ultraleds.co.uk) 1W LED H6W bulbs
Sylvania SilverStar H7 (high beams)
Stealth blinker bulbs 7507 (front and rear)
Hüper Optik Ceramic 60 and Sech (metal) tint
My alignment specs
Writeup on load equalizers mounted inside e-code housing
akula-ssh is offline   Reply With Quote
Old 09-04-2006, 04:19 PM   #3
bhvrdr
Member
Account #: 57072
Default While I agree you can tell from feel there are really two setting extremes, it is an awesome value..
compared to the street coilovers you mentioned IMO. Sure you dont get perhaps a full range of 9 settings but as you can see on the stiffest setting the valving is doing exactly as it should. It is easily able to surpase the street setup like the vogtlands dynod there as it should with its slightly higher spring rates making it not pogo like most of the street setups I have tried that rely on much smaller dampers. The handling is fantastic for track duty and the street feel is only slightly more harsh than the OEM S4 suspension as those members will report and I have seen (quite a bit stiffer than the OEM non sport suspension of an A4 though). Then if you prefer the feel of a soft spongier ride for the inlaws when in town you just crank them down while still on the car and you have an almost non sport suspension feel. For $1450 (the price now Autozone and many other sites are carrying them for) it really was the only way for me to get a performance level similar to what I wanted but not having to pay almost 4 grand. Would I prefer a motorsport kit? Sure I would. Would I prefer street coilovers? Not at all. Even for confort I find the PSS9 is fantastic and it really does perform well on more harsh tracks.
cheers! Mike
Cheers! Mike
________________________________________
A4 S4 and RS4 Official Timeslip Databases
MJB Motorsport
Click for S4 at Play VIDEO!!!
Current vehicle:
2004 Audi S4, APR, Milltek, Bilstein, AP Racing.
Over 323whp and 312tq on pump 93
13.20 at 103mph on pump 93
Past Project Vehicles:
2006 Audi A4 2.0t FSI with APR K04 Turbo
2003 Audi A4 1.8t with MTM Stage 3
2000 Audi A4 1.8t with MTM Stage 2
"There are only three sports: bullfighting, mountain climbing, and auto-racing. Everything else is just a game" -Ernest Hemingway
bhvrdr is offline   Reply With Quote
Old 09-04-2006, 04:25 PM   #4
Ray Khan
Account #: 4477
Send a message via AIM to Ray Khan
Default good points
Ray Khan
00 1.8T QM
APR stage 3+
APR Exhaust
APR Intake
DUH FMIC
Southbend OFE Stage 4 clutch
SPEC 12 lb flywheel
Greddy Profec B electronic boost controller
Porshe Boxster calipers
BIRA stage I brackets
Hawk HPS brake pads
A8 rotors, SS lines
V&amp;S Short Shifter
Vogtland Coilovers
Neuspeed 19mm rear sway
18x8 Flik Lex
235/40/18 Falken GRB 451
17x7.5 B5 S4 Avus
205/50/17 Dunlop Wintersport 3D
Sony XM 7554 amp with 5.25" and 6.5" Infinity kappas
MTX 801D amp with 2x10" kenwood sub enclosure
Xenons
Fog light relay mod
VDO boost gauge in custom vent pod
Clear corner mod
S4 wheel well liner
RS-4 grill
AIM and MSN messenger:rakha77
Ray Khan is offline   Reply With Quote
Old 09-04-2006, 04:37 PM   #5
Tomasz@Startup
Senior Member
Account #: 683
Default I agree that PSS9s are still a good value, and I am still selling them.
Just wanted people know what I knew though.
Old 09-04-2006, 04:59 PM   #6
Mike@StartupRacing
Member
Account #: 107699
Default You have to Dyno the Penske's!
<a href="http://www.startupracing.com/" target="_blank">
</a>
Mike@StartupRacing is offline   Reply With Quote
Old 09-04-2006, 05:10 PM   #7
bhvrdr
Member
Account #: 57072
Default It's great info and thanks for doing that research. Cant wait to see your projects.
Cheers! Mike
MJB Motorsport
Current vehicle:
Old 09-04-2006, 05:23 PM   #8
Tomasz@Startup
Senior Member
Account #: 683
Default Every single one is dynoed... stop by and you will see my library.
Old 09-04-2006, 07:31 PM   #9
Pie4Foo
Member
Account #: 57452
Default How do I read these graphs? How does one "dyno" a shock setting with variable dampening?
FWIW, today I changed my PSS9s from "3" to "9" and noted a difference. Significant? No, but it did come out in road undulations and freeway expansion joints.
I don't fully understand the technical discussion here, but I would like to understand what was done and how changing the dampening would have an affect on spring rates.
Can a Bilstein representative be contacted to comment on this as well?
Car for driving in circles: Lotus Exige
Car for driving to the airport: AWE/GIAC Stage 3 S4
Car for the weekday: Hertz rental
Pie4Foo is offline   Reply With Quote
Old 09-04-2006, 08:06 PM   #10
Tomasz@Startup
Senior Member
Account #: 683
Default To dyno variable dampening shock: take a reading, adjust, take another reading, repeat.
Graph shows the force in lbs. that the shock excerts at different speeds.
Key here is that PSS9 does not change between most settings. It is what it is. Not judging here.
Tags
2006, a4, apr, audi, b5, b6, bilstein, bistein, coilovers, dyno, forum, pss9, purchase, s4, shock, suspension
HTML code is Off
