Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B7 Platform) Discussion
Old 11-17-2005, 06:06 PM   #1
Jestapilot
Member
Account #: 67348
Default 2.0T oil change how to plus ECS Tuning snub install and review.
Well I finally got around to changing my oil for the first time. I must say it was a lot more difficult than on my old 2.8. Lets get started...
Filter:
4.8 quarts Castrol Syntec 5W-40:
First remove all of the hardware required to remove the two underbelly pans.
There's a lot of those suckers!
Open the oil filler cap in the engine bay next.
On the underside of the engine is the oil drain plug.
After you have the oil drained, now comes the fun part. Audi decided to change the oil filter to a canister style setup. I guess they have a special tool to drain the oil out of the bottom of the canister, but it's optional really. I got by just fine without it. There is a little dust cover that reveals the valve an Audi tech would use to drain the oil out of the bottom of the canister. I suppose I'll invest in the tool eventually. It does cut down on the mess.
Next I removed the canister by getting a very large adjustable wrench around the end of the canister. There is very little room to do this, but it works best to do it from the top of the engine bay reaching down.
Canister valve:
Canister removed:
Next replace the gasket inside with the one provided in your new oil filter. It fits in the groove on the inside.
Old filter:
The rest of the process is pretty much the reverse. Install the new filter media and canister and tighten it down.
After the filter canister is installed refill your oil.
Next up is the ECS Tuning snub mount.
Here's a pic of the OEM Audi mount:
It's very spongy and soft. I can see why my car would shift kind of sloppy. The install was very easy since the panels were already removed from the oil change.
Here's the new snub. I had to use a little white lithium grease to get it onto it's post. I also used a vise to coax it over the post's hump.
It's really only 3 bolts to remove and three hex heads as you can see. Once I had the bolts threaded I started the car and let the mount settle in. I then tightened them down. No vibrations that people complain about with the APR snubs. I wasn't certain if I would be able to tell the difference. But I can tell you that I do. The OEM snub is much to soft. Now when I shift I feel more connected to the car and shifts are smoother and less soft feeling. It's hard to explain. All in all I think it was worth the price.
Anyway sorry this is so long. Hope it helps someone.
2004 Touareg V8
2005.5 A4 2.0T (sold)
1997 A4 2.8 (sold)
B7 Oil Change
B7 Snub Mount Install
Neuspeed Short Shifter Install
Votex Rear Diffuser Install
Jestapilot is offline   Reply With Quote
Old 11-17-2005, 06:34 PM   #2
USP
Member
Account #: 66483
Default Nice writeup J. How's the XM?
I'm lovin the Sirius so far!
Steve
NYC
Chicks dig teh grillage!
My B6/B7 Photo Gallery
<a href="http://www.nerdtests.com/ft_nq.php?im">
</a>
2006 A4 S-Line 2.0TQ
-Brilliant Red/Ebony Interior
-6 speed Tiptronic w/paddle shift
-SLine Package
-Premium Package
-Technology Package
-RNS-E
-40% Tint Front/Side/Rear
-Debadged
-Hoen XenonMatch Fog Lights
-10 inch Alpine Type-R Subwoofer
-Rockford Fosgate Power Series Amp.
-Lightning Audio Digital Capacitor
-Custom Fiberglass Enclosure
-Wiring by Stinger
Car on Order:
-2008 TT 2.0T
Cars Retired:
-2004 A4 1.8TQ Ultrasport
(gone but not forgotten)
-2001 Jetta GLS 1.8T (college ride)
-1995 Jetta GL 2.0 (college ride)
-1992 Cutlass Supreme (Saved my Life)
USP is offline   Reply With Quote
Old 11-17-2005, 06:39 PM   #3
Jestapilot
Member
Account #: 67348
Default Thanks. XM has been treating me well!
2004 Touareg V8
1997 A4 2.8 (sold)
B7 Oil Change
Old 11-17-2005, 08:28 PM   #4
chaotic
New Member
Account #: 95063
Default can you use a regular floor jack or do you need an adaptor?
chaotic is offline   Reply With Quote
Old 11-17-2005, 09:26 PM   #5
jsamans
Junior Member
Account #: 92024
Default Great write-up!!
Even though I would personally never attempt that sort of thing, thanks for the contribution!
2005.5 A4 3.2 FSI quattro
Sport/Premium/Cold Weather/Lighting/Sun
Navigation Plus/Bose/Sirius
Quartz Grey Metallic w/ Ebony
jsamans is offline   Reply With Quote
Old 11-17-2005, 11:40 PM   #6
SoCalB7
New Member
Account #: 93672
Default Excellent, informative writeup, thanks very much. (Any thoughts on adding a short shift kit?)
SoCalB7 is offline   Reply With Quote
Old 11-18-2005, 01:21 AM   #7
Jestapilot
Member
Account #: 67348
Default I already have a Neuspeed short shifter (it's in my sig).
2004 Touareg V8
1997 A4 2.8 (sold)
B7 Oil Change
Old 11-18-2005, 06:32 AM   #8
cpurick
Member
Account #: 96094
Default Hmm. I've often heard it's better to keep the old O-ring.
The key to reliable German car ownership is to own at least two. Fortunately, German car enthusiasts see this as a plus.
cpurick is offline   Reply With Quote
Old 11-18-2005, 08:45 AM   #9
A4in_tha206
New Member
Account #: 98084
Default Do you have any torque wrench specs for the snub mount install?
A4in_tha206 is offline   Reply With Quote
Old 11-18-2005, 11:45 AM   #10
Jestapilot
Member
Account #: 67348
Default Nope just tightened it down good. None of them were on there very tight from the factory.
2004 Touareg V8
1997 A4 2.8 (sold)
B7 Oil Change
Tags
20, 2006, 20t, a4, audi, b7, change, filter, howto, mount, oil, q5, size, snub, wrench
