Go Back   AudiWorld Forums » Audi Models » Audi A6 / S6 / RS 6 » A6 / S6 (C6 Platform) Discussion
Old 07-28-2007, 09:49 AM   #1
pierreb
Cat Herder
Account #: 97649
pierreb's Avatar
Default Of chrome, airbag lights and customer service <rant removed due to inaccuracy>
I returned the A8 loaner and picked up my car today.
The car was brought in for its 45k service, as well as to try and resolve the airbag light once and for all. As some may know, the 2k5 C6 suffers from a defect in the rear middle seat that fires off a code whenever someone of significant weight sits there (i.e. not a small child).
I also wanted to have them replace the chrome around the windows if possible as it was significantly cloudy and stained.
First, the airbag light was corrected via a call to Audi Technical Assist. The code registered was for Center Rear Belt Tensioner. They sent the following parts:
qty:1 Part# 4F0-857-807-D-V04 Seat Belt Igniter
qty:1 Part# 4F1-971-259 Seat Belt Igniter Piggie Harness
This took the tech 3 hrs to troubleshoot and install according to the paperwork.
Next up was the trim. As luck would have it, the Service Manager was on vacation, so my SA called the Audi Warranty line directly. The work was ok'd over the phone quickly, was told to reference a 'Jeff Bon K.' and that the claim should be a 'W2 claim'. The parts list follows:
qty:1 Part# 4F5-853-703-D-2ZZ Molding
qty:1 Part# 4F5-853-704-D-2ZZ Molding
qty:1 Part# 4F5-853-345-A-2ZZ Molding 0
qty:1 Part# 4F5-853-346-A-2ZZ Molding
qty:44 Part# N-910-197-01 Pop-Rivet 10
qty:4 Part# 8L3-837-199-B Clip 6
qty:16 Part# N-900-978-02 Pop-Rivet 14
Took 2 techs 10 hrs to do, including bodyshop work.
Although the Service Manager questioned the work being covered upon his return, it turned out as planned and AoA fully covered the repair.
Kudos to Tim and Dover Audi for the effort and work.
p.s. I don't get my way for everything though. One of the door blades I feel needs repainting, but they couldn't get that covered, so I'll get it done at the next Spring respray.
And soon you will be gone
And we will all move on
You never mattered anyhow
And you're not so pretty now
T.R. 2k9
CAR-RELATED:
MMI Update Warning!
MMI 'upgrade' and other C6/D3 TSBs Updated 1/26/09 | VAG-COM upon request | Wheel Scuff Repair | Tire Size Calculator | C6 NAV retrofit |
North Atlantic Audi Club | ACNA Northeast Chapter | Winter Driving School is fun! | Voice Command button activation | Airbag Light and Chrome Fixes
Her car: 2007 Audi A4 Avant Quartz/Plat. 2.0T 6M w/everything
OTHER:
xbl: pierrebnh | Bernese Mountain Dog Rescue | How Not to buy a BMD | Scaler FAQ &amp; more | Panasonic Plasma FAQ
pierreb is offline   Reply With Quote
Old 07-28-2007, 11:51 AM   #2
schnellmb
Member
Account #: 45563
Default yes Pierre, it is quite irritating....
Have a nice day.
schnellmb is offline   Reply With Quote
Old 07-29-2007, 06:08 AM   #3
05whtaudia6
Account #: 108260
Default Good for you, i have had no luck at riverside and paul miller to change the chrome around the window
2005 Artic White A6 3.2
05whtaudia6 is offline   Reply With Quote
Old 07-29-2007, 06:22 AM   #4
pierreb
Cat Herder
Account #: 97649
pierreb's Avatar
Default try giving them the info and tell them to call again.
tell them you can give them VINs of cars that have had it done, and I'll give you mine as proof.
T.R. 2k9
CAR-RELATED:
MMI Update Warning!
OTHER:
Old 08-01-2007, 08:06 PM   #5
philm35
Account #: 96406
Default I got my chrome trim replaced today
I had corrosion that looked like permanent water spots on all of the bright trim surrounding the side windows and the trunk lid. The dealer took care of it under warranty, no questions asked, and did a fine job. Thanks to Audi Connection in Cincinnati.
--Phil
2005 A6 3.2 (Gone but not forgotten)
2004 BMW R1150R
philm35 is offline   Reply With Quote
Tags
a6, airbag, allroad, audi, chrome, cloudy, light, trim
