Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 02-15-2008, 07:43 AM   #1
Santos@Ross-Tech
Account #: 104837
Default Testers Wanted!! Guided Readiness Scripts
The Readiness Code is a set of 8 bits, each of which corresponds to one monitored emissions "system" in an OBD-II car. When all readiness bits show "Passed", it means that all systems have been checked and have passed the on-board tests.
Whenever you clear DTC's or remove power from the ECU, all readiness bits will be set to "fail".
It takes a variety of specific driving conditions to "test" all the systems. It can be done in a short time using a very specific and complicated procedure.
http://www.ross-tech.com/vag-com/tour/readiness.html
Since Release 704, Vag-Com has had the ability to guide the user through the process of setting Readiness on those engines which support it. The current coverage is nowhere near complete.
We are currently working our way through the Vw/Audi US engine code list from 96-08 and are looking for testers for the newly created scripts.
Please send me an email (santos@ross-tech.com)if you are interested in testing a script for your car.
The Following scripts are Available for testing:
VWUPDATED 2-22-08)
AEG New Beetle (98-01), Jetta(99.5-01), Golf (99.5-01)
AEB Passat\Passat Wagon (98-99)
AHA Passat\Passat Wagon (98-99)
AFP GTI(99.5-02), Jetta(99.5-02), Jetta Wagon (01-02)
APH New Beetle (99-01)
AUG Passat\Passat Wagon (00-01)
ATW Passat\Passat Wagon (00-01)
ATQ Passat\Passat Wagon (00-04)
AWD Golf\Jetta\Gti (00)
AWM Passat \Passat Wagon (01-05)
AVH Golf (01-06), Jetta (01-03), Jetta Wagon (01-04) New Beetle(01-05)
AWP GTI (02-06), Jetta (02-05), Jetta Wagon (02-06), New Beetle (01-05)
BDF Gti (02-05) Jetta (02-03)
BGP Jetta (05-07), Rabbit (06-07)
BGQ Jetta (05-07), Rabbit (06-07)
BPR New Beetle (06-08), Beetle Convertible (06-08)
BPS New Beetle (06-08), Beetle Convertible (06-08)
Audi: (UPDATED 2-22-08)
AEB A4(97-99) A4 Avant (99)
AEW A8 (97-99)
ABZ A8 (97-99)
AWN A6 (01-04)
AWM A4 (01) A4 Avant (01)
AUX A8l (01-03) S8 (00)
AYS A8l (01-03) S8 (02-03)
AHA A4 (98-99) A4 Avant (98-99) A6 (98-99) A6 Avant (99)
ART A6 (99-00)
ATQ A4(00-01) A4 Avant (00-01) A6 (00-02) A6 Avant (00-01)
ATW A4 (00) A4 Avant (00) A6 (00)
APB A4(01) A4 avant (00-01) A6 (00-02) S4(00-02) S4 AVANT (01-02) ALLROAD (02-03)
AKB A8 (00)
ATC TT (00)
AWP TT (01-06)
BEA TT (02-06)
Santos@Ross-Tech.com
Santos@Ross-Tech is offline   Reply With Quote
Old 02-18-2008, 04:57 AM   #2
Bracketracer
Elder Member
Account #: 1718
Default ygm
Bracketracer is offline   Reply With Quote
Old 09-04-2008, 08:33 PM   #4
cparke
Junior Member
Account #: 148128
Default Why does the "Set Readiness" button sometimes gray out?
I have an '98 Audi A4 V6 30V (AHA engine) and VCDS 804.1. I used the guided script once before recently, but when I wanted to use it this time, it was always greyed out. Some of my readiness bits are already set. What are the conditions for the button to un-gray out.
Also, is it normal that even after cleared fault codes, some of my readiness bits remain set to passed, even if the engine has never been started?
cparke is offline   Reply With Quote
Old 09-05-2008, 11:18 AM   #5
Santos@Ross-Tech
Account #: 104837
Default We are currently looking into the issue, The script is included with VCDS but is not loading.
Old 09-05-2008, 11:25 AM   #6
cparke
Junior Member
Account #: 148128
Default This worked in 805.0, but I just upgraded to 805.1 and it stopped
How does it know what car I have?
Can I get 805.0 back to try again there?
Old 09-08-2008, 05:14 AM   #7
Santos@Ross-Tech
Account #: 104837
Default Please contact me via email
HTML code is Off
