Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 06-28-2008, 05:14 PM   #1
Maini
Account #: 38404
Default Auto HVAC - Not able to read
I have a 409XX and it works great with all modules and i have done the recoding etc... However when I try the Auto HVAC module I get the following Any ideas on this???
I have 2001 A6 2.7T
Address 08: Auto HVAC
Controller: 4B0 820 043 AH
Component: A6-Klimavoll
Coding: 00160
Shop #: WSC 02325
Note: Excessive Comm Errors
2001 A6 2.7T Black/Black 89,000 miles
Previous faithful Audi
1996 A6 quattro Sold 95,000 miles 01/05
Maini is offline   Reply With Quote
Old 06-28-2008, 05:17 PM   #2
Uwe@Ross-Tech.com
Account #: 9886
Default What type of interface are you using?
Uwe@Ross-Tech.com is offline   Reply With Quote
Old 06-28-2008, 06:21 PM   #3
Maini
Account #: 38404
Default "Too many communication errors" to different Modules ..Found the fix... works perfectly now.... :)
For anyone having issues with VAG talking to any one or more modules in the car.. the fix is very very easy.. this is for Windows XP other OS it may vary..
1)Plug your VAG cable to the correct USB port
2)Right Click on My computer and select properties
3)Click on Hardware Tab and then click on Device Manager
4)Open up the Ports (COM & LPT) and then right click on USB Serial Port (COM X) and select properties
5) Select Port Settings TAB Click on Advanced Button
6)Change Latency Timer (msec) from 16 to 12
7) Click Apply & OK on all windows and close them.
Old 06-30-2008, 01:45 PM   #4
Neo1130
Junior Member
Account #: 90528
Default I too get that on my 01 A4 with cheap and genuine VAGCOM cables...
2001 Audi A4 1.8tqm
GIAC-X
3" ATP Test Pipe
Borla Exhaust/downpipe
AND a mod that blows about 4-5 MAFs a year!!
Neo1130 is offline   Reply With Quote
Old 06-30-2008, 05:35 PM   #5
Maini
Account #: 38404
Default Try the fix I used below... works beautifully with ebay cables too..
Tags
1996, audi, black
HTML code is Off
