Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 02-09-2008, 11:05 PM   #1
nasonov
New Member
Account #: 140713
Default Alarm not working.
Any comments?
Control Module Part Number: 8L0 862 257 G
Component and/or Version: ZV-Pumpe, DWA, Funk D05
Software Coding: 13130
Work Shop Code: WSC 06335
2 Faults Found:
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
Regards
nasonov is offline   Reply With Quote
Old 02-10-2008, 04:07 PM   #2
diagnosticator1
Account #: 98458
Default The two DTCs indicate that both sides of the "ZV Pumpe" Anti Theft alarm Switch" are grounded...
The ground fault can exist anywhere in the circuit from the control module, to the switch, and from the switch back to the control module. One wire circuit for each. Or, the switch itself is faulty. With the switch removed, check each wire, one wire from the controller to the switch, the other wire from the swithc to the controller, for continuity to ground. There should be no continutiy, or infinite high resistance in ohms from each wire, measured between the switch circuit and chassis ground. Any measured value in ohms, lower than infinite, is the reason for the DTCs. Find and fix the location of the bad wire insulation, or run a seperate new wire, or replace the switch depending on the test results.
I'll say it first, before Ross-Tech does,
"Post a complete Auto scan", maybe other info that provides will be helpful regarding the DTCs you are asking about.
diagnosticator1 is offline   Reply With Quote
Old 02-11-2008, 08:34 AM   #3
nasonov
New Member
Account #: 140713
Default Thank You very much. ll try this tonight
Old 02-11-2008, 10:25 AM   #4
nasonov
New Member
Account #: 140713
Default Found problem
Priveous owner had another keyless entry system installed and he left wireless block connected to central locking wires, that was a problem. I had removed block and cleared the dtc.
Central locking working now with maual key but it doesnt activate the alarm.
Can i wake alarm up somehow using vag com?
Any another idias?
Regards
Old 02-15-2008, 04:25 PM   #5
diagnosticator1
Account #: 98458
Default If there are no DTCs, then confirm that the alarm is enabled in the Central Convienience module, ...
When the alarm "armed" confirmation fails to occur on lock up, then there is something "not ready" or in a state to lock, or other aspect
of the central locking system status prevents arming, either a door is partially open/not latched tight, or some other device of the system prevents the complete locking of all locks, therefore the systme won't arm the alarm.
Old 02-17-2008, 04:33 AM   #6
nasonov
New Member
Account #: 140713
Default How to check what alarm is enable?
I have Central Locking module instead of conv.
I did output test on codding 1386 1392 1390 1391 and everything was working fine(alarm sound, one beep sound, warning lights and ultrasonic sensors)
My original cooding for pump 8lo862257g was 13130 try ross tech codes same story
Old 02-17-2008, 09:00 AM   #7
diagnosticator1
Account #: 98458
Default I should have confirmed before, what model and model year?
Old 02-17-2008, 11:38 AM   #8
nasonov
New Member
Account #: 140713
Default a4 b5, 98 Jul, 1.8se adr. UK reg
Old 02-19-2008, 07:55 PM   #9
diagnosticator1
Account #: 98458
Default Something is blocking the alarm activation.
Make sure all swithces are working, and the central locking module is coded properly.
Old 02-21-2008, 04:16 PM   #10
nasonov
New Member
Account #: 140713
Default Thanks, ll work on that.
HTML code is Off
