Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 05-25-2006, 10:55 PM   #1
ImpellerCDN
New Member
Account #: 61441
Default "Too many communication errors" connecting to HVAC on A4
I can rarely connect to the HVAC controller on both my B5 A4 and S4. Typically I time out with a "too many errors..." message.
3rd party cable (usb). vag-com 409.11.
Any wisdom out there? STFA but no answers...
Many thanks.
ImpellerCDN is offline   Reply With Quote
Old 05-26-2006, 03:38 AM   #2
Theresias
Account #: 77434
Theresias's Avatar
Default Not the 1st time I see that with 3rd party hardware - doesn't happen with real Ross-Tech hardware.
Sebastian @ Ross-Tech.com
Theresias is offline   Reply With Quote
Old 05-26-2006, 04:40 AM   #3
Uwe@Ross-Tech.com
Account #: 9886
Default Those HVAC controllers are pretty fussy about timing
and 3rd party USB interfaces are quite poor at maintaining precise timing because they emulate a serial port and this emulation tends to slow things down.
-Uwe-
Uwe@Ross-Tech.com is offline   Reply With Quote
Old 05-26-2006, 10:15 AM   #4
ImpellerCDN
New Member
Account #: 61441
Default As I feared. I'll try with my laptop on AC...
...which ups the clockrate by 2x. Since you mention,
it might help with the com timing precision.
Let you know.
Cheers.
Old 05-26-2006, 08:21 PM   #5
ImpellerCDN
New Member
Account #: 61441
Default Fixed: tweaked usb->serial latency value...
From 16ms to 12ms. HVAC now responds on both my B5 cars. Other controllers seem happy too.
Cheers
Old 05-27-2006, 08:03 AM   #6
Bracketracer
Elder Member
Account #: 1718
Default actually, I've got to disagree here...
I've got the real thing (Hex-USB with 512.4), and have a LOT of problems connecting, or maintaining a solid connection with HVAC controllers in late '90s and early '00s cars. Flaky enough that I can rarely perform basic settings.
Bracketracer is offline   Reply With Quote
Old 05-27-2006, 09:00 AM   #7
Uwe@Ross-Tech.com
Account #: 9886
Default As I said, those modules are quite fussy.
But the HEX-USB should be able to do it without any problem, *if* there's no other issues with the PC.
What kind of PC? What version of Windows? Have you been to the link below?
-Uwe-
Old 05-29-2006, 11:29 AM   #8
nasdaqer
New Member
Account #: 97057
Default how did you fixt the serial latency value?
I am having the same problem
thanks
nasdaqer is offline   Reply With Quote
Old 08-19-2008, 06:03 PM   #9
Maini
Account #: 38404
Default Try this....
2001 A6 2.7T Black/Black 89,000 miles
Previous faithful Audi
1996 A6 quattro Sold 95,000 miles 01/05
Maini is offline   Reply With Quote
Tags
5124, a4, a5, audi, b7, communication, communications, comunication, continue, errors, erros, forum, hvac, party, vag, vagcom
HTML code is Off
