Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 01-30-2005, 04:36 PM   #1
BIGNOAH
New Member
Account #: 87444
Default "No response from controller"
I'm using the serial port on a Dell Latitude laptop. The test seems to work, but I can't actually do anything. I'm getting "NO RESPONSE FROM CONTROLLER" whenever I try to select a control module.
Anyone know how to fix this?
BIGNOAH is offline   Reply With Quote
Old 01-30-2005, 05:15 PM   #2
BIGNOAH
New Member
Account #: 87444
Default Re: "No response from controller"
BTW, I'm trying to use this with my 2001 A6 2.7T Quatro.
Thanks in advance!
Old 01-30-2005, 05:25 PM   #3
Andy@Ross-Tech
Member
Account #: 34479
Default Details needed:
What brand and model of hardware are you using? What version of VAG-COM. What exactly shows up when you Test on the Options screen?
Andy
Andy@Ross-Tech is offline   Reply With Quote
Old 01-30-2005, 07:34 PM   #4
BIGNOAH
New Member
Account #: 87444
Default Re: Details needed:
VAG COM 409-1 (though I did try an earlier version as well to no avail). The test results are for Com 3:
Port status: OK
Interface: found!
Type: Serial/Pass through
Opto/Iso: Yes
Ross-Tech Design: No
The cable is just a third-party cable that a friend is no longer using (he swears it worked on his VW). Once I get this working I'm going to buy the software and probably the kit as well.
THANKS!!
Old 01-31-2005, 12:57 AM   #5
Theresias
Account #: 77434
Theresias's Avatar
Default Are you using an USB/serial converter? Which control modules did you try?
Sebastian @ Ross-Tech.com
Theresias is offline   Reply With Quote
Old 01-31-2005, 04:03 AM   #6
BIGNOAH
New Member
Account #: 87444
Default Re: Are you using an USB/serial converter? Which control modules did you try?
No...I'm using the serial port that's built in to my laptop. I've tried the auto-scan feature as well as the individual modules for engine, transmission, locks, and radio...all have the same problem. VAG-COM makes 4 attempts and then reports "NO RESPONSE FROM CONTROLLER."
Old 01-31-2005, 04:56 AM   #7
want
Member
Account #: 56080
Default The download page of Ross-Tech say "If you're using an older SERIAL Interface based on Opto-Couplers
You'll need to use Release 311.2".
http://www.ross-tech.com/vag-com/download/index.html
want is offline   Reply With Quote
Old 01-31-2005, 07:02 AM   #8
Andy@Ross-Tech
Member
Account #: 34479
Default Bingo!
Andy
Old 01-31-2005, 09:03 AM   #9
BIGNOAH
New Member
Account #: 87444
Default Re: Bingo!
OK...so do I need to uninstall 409 before loading the earlier verison?
THANKS!
Old 01-31-2005, 09:40 AM   #10
Andy@Ross-Tech
Member
Account #: 34479
Default Just download and install 311.2. It should overwrite 409.1.
Andy
Tags
3112, a5, audi, b5, contloler, contriller, controller, interfaces, no, optocouplers, response, s4, serial, vag, vagcom
HTML code is Off
