Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 07-24-2003, 05:34 PM   #1
MarTT
Member
Account #: 20368
MarTT's Avatar
Default Battery died - jump started car - are these codes normal?
Car (2001 Audi TTC 225) runs fine after jump start but the following codes are shown after AutoScan: Normal? OK to clear? Thanks in advance.
VAG-COM Version: Release 303.1
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 17 -------------------------------------------------------
Controller: 8N1 920 930 J
Component: KOMBI+WEGFAHRS. M73 D54
Coding: 07244
Shop #: WSC 03325
XXXXXXXXXXXXXXXXX
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
27-10 - Implausible Signal - Intermittent
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Address 35 -------------------------------------------------------
Controller: 8N8 962 267 A
Component: Central Lock/Alarm D05
Coding: 15980
Shop #: WSC 40320
1 Faults Found:
MarTT is offline   Reply With Quote
Old 07-24-2003, 06:57 PM   #2
Uwe@Ross-Tech.com
Account #: 9886
Default Yes, except..
The supply voltage codes are normal given the dead battery.
The 00562 - Sensor for Oil Level/Temperature (G266) is not.
I would clear them all and see if the latter one comes back.
-Uwe-
Uwe@Ross-Tech.com is offline   Reply With Quote
Old 07-25-2003, 04:05 AM   #3
MarTT
Member
Account #: 20368
MarTT's Avatar
Default Thanks - much appreciated!
HTML code is Off
