Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » S4 (B6 Platform) Discussion
Old 08-01-2008, 05:33 PM   #1
S4iowa
Member
Account #: 36175
Default Hawk Brake Pad Update!
As most of you know, Hawk pads for the S4 came with the wrong clip. This required you to zip tie your caliper spring or use the method in my sig to modify the pads to use the proper clip. Or ECS was modifying them the same way I was and you could buy from them already done.
The Hawk part number that was used for the S4 was the same as the A6 since they share the same size and shape. But unfortunately, the wrong clip.
Example of bad clip on the left that Hawk came with, correct OEM clip on the right.
Many places were selling the following part numbers as the S4 fitment. Including TireRack where I originally bought my first set of Hawk pads. Tire Rack have since pulled the Hawk pads from the S4 application. But other places still have these listed.
Part numbers include:
Front HPS HB515F.760
Front HP+ HB515N.760
I contacted Hawk and asked them if they had any intention to update the application list and to correct the pads with the proper clip. They responded saying they wanted to correct this and had a pad that was very similar in size (off by thousands on the backing plate, big deal that looked like it had the proper clip. So they were going to send me out a set to try.
Well... they work! I installed and bed them in today and drove on them around town with no issues.
So we now have updated part numbers!!
I've been in contact with Hawk and they will be updating their application list to include the S4. Which means vendors will probably be selling the older part numbers for a while until that's changed.
New Hawk part numbers:
HB538F.760 HPS (includes wear sensors)
HB538N.760 HP + (no wear sensors)
New part number Hawk HPS with wear sensors and proper clips.
How to read Hawk Part Numbers
Hawk Compound Codes
Current:
2004 S4
No Warranty:
66K Fuel filter $45
67K Motor mount $200
67K Coil pack(s) $40*2
67K Window regulator $100
71K Battery $135
2003 TT 1.8T
No Warranty:
50K Hazard Switch $50
Past:
1998 A4 1.8TQMS
B6/7 S4 Hawk Pad part number update!
Should no longer need to do the below anymore:
How to modify C5 A6 Hawk pads for use in the B6/B7 S4 or B7 A4
S4iowa is offline   Reply With Quote
Old 08-01-2008, 07:05 PM   #2
littleredwagen
Junior Member
Account #: 142412
littleredwagen's Avatar
Send a message via AIM to littleredwagen
Default yep they work I have those pads in my car and for some time
since early spring
2005 S4 Avant: 6spd, Brillant Red
littleredwagen is offline   Reply With Quote
Old 08-01-2008, 07:18 PM   #3
S4iowa
Member
Account #: 36175
Default That same part number? HB538?
Who tipped you off that it would work? It's not listed as an application for the S4 and no one sells them as such...
Current:
2004 S4
No Warranty:
66K Fuel filter $45
71K Battery $135
2003 TT 1.8T
No Warranty:
Past:
1998 A4 1.8TQMS
Old 08-01-2008, 09:32 PM   #4
i_eat_staples
Junior Member
Account #: 71675
Default how's the noise level on the HP+ for daily driving/wknd track use?
i toasted my front rotors out at PIR this weekend, this a month after i roasted my rears lol
need a more track oriented pad that can double for weekend track duty
i dont mind a little squeek, dont want something annoyingly loud though
for reference on my acceptable noise levels...i used to have a fullback non-res milltek that i loved
"tugging a rhythm to the vision that's in my head"
'04 s4
NWQuattro - NW Premier Audi Club
i_eat_staples is offline   Reply With Quote
Old 08-02-2008, 03:52 AM   #5
littleredwagen
Junior Member
Account #: 142412
Default Not sure the p/n anymore tossed the box, i got mine from ecstuning same with the S4 Bridge clips...
I did the HAWK HPS pads all around, painted the calipers, and mounted my spacers and wheels, and the S4 clips just snapped right in and the pads had the OEM mounting clip.
edit reread ur post and i believe they are the ones modified by ecs
Old 08-02-2008, 05:06 AM   #6
The Mystro S4
Member
Account #: 9514
Default Very good post. Very informative.
2004 S4..MT6,Alcantara,Loaded (19" Polished Forged DTM 7 spoke)
German engineering at its finest
The Mystro S4 is offline   Reply With Quote
Old 08-02-2008, 08:47 AM   #7
S4iowa
Member
Account #: 36175
Default The noise isn't too bad, but I don't drive on the street with them.
It's very fast to swap them out, so I only put the Plus pads in for the track.
Current:
2004 S4
No Warranty:
66K Fuel filter $45
71K Battery $135
2003 TT 1.8T
No Warranty:
Past:
1998 A4 1.8TQMS
Old 08-02-2008, 11:41 AM   #8
i_eat_staples
Junior Member
Account #: 71675
Default good to know, anyone have a link to the b6 brake pad walkthrough?
'04 s4
Old 08-05-2008, 08:39 AM   #9
deeno20
Junior Member
Account #: 63138
Default I have it as a Word file, so ping me and I'll send it to you.
jdeenihan@kke.com
2006 B7S4
Moro Blue/Silver
H-Sport front and rear sways
DBA slotted rotors
Strat Hyperflow
For the track:
Schroth Rallye 4 harnesses
Nitto NT-01's
Carbotech XP-10 brake pads
Premium package
Premium sound
Premium FUN!
GBNF:
2000 A6 2.7T
2004 B6S4
deeno20 is offline   Reply With Quote
Tags
hb538f760
