Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 01-28-2005, 05:15 PM   #1
qfrog Ti20
Elder Member
Account #: 26
Default Audi parts 101... lesson 1 ((wiki))
A part number has several sections... we don't have run-on sentence part numbers with random characters in them. Actually our parts numbering system is very neat and tells a lot about the item usually. The system is very logical too, numbers aren't much different looking than phone numbers. Everything has a meaning and this post should help you decipher some of that encrypted information.
Prefix is the first 3 alphanumeric characters of the part number string. This tells the user what the item was meant for use on originally. This applies to engines, platforms, differentials, gearboxes etc. Prefix examples.
A prefix of 01A tells us that a part was originally intended for use with the 01A gearbox.
078 indicates the part was for use with the Audi V6
058 indicates a 1.8T engine usually
034 indicates a in line 5 engine
8D0 indicates intended use with a B5 A4
3B0 indicates intended use with a B5 passat
There are dozens of prefixes, each has its own meaning.
Next is the middle 3 numeric characters... This indicates what the item is used for on the car... and usually where its found in ETKA.
The catalogue is divided into 10 groups.
Group 1 is engine
Group 2 is fuel/exhaust systems
Group 3 is gearbox
Group 4 is front suspension and drive
Group 5 is rear suspension and drive
Group 6 is wheels and brakes
Group 7 is shifter assembly
Group 8 is body
Group 9 is electrical
Group 0 is accessories
3b7-955-681 is a headlight washer pump
The first digit of the second section tells what main group the item should be classified under. The 2nd and 3rd digits detail the sub-group where the item is found. 9-55 in ETKA is the wiper system which includes the jets pumps and nozzles.
8D0-805-110-L-3FZ is the lower front b5A4 spoiler
110 is the item number however if it were an item that has a Left and Right version there would be two similar part numbers for example.. 8n0-615-125-A and 8n0-615-126-A. The odd number is meant to be the lower of the two and is also the LEFT side... where as the RIGHT side is the higher and even number.
8d0 tells its for the B5A4
805 indicates its in the body section and located in the bumpers sub-group.
The 110 is the actual item number
The "L" is the version or revision of the given part.
The "3FZ" is the color code
There can be multiple revisions of a given part number that are only differentiated by a single character. A 8d0-955-408-A wiper arm is not the same as an 8d0-955-408 wiper arm. The two might be completely incompatible even tho the part number is similar. Avoid making assumptions about cross compatibility just because part numbers look similar. If the number is different, something about the part is different.
Color codes are usually the last section of a given part number... they can be a miserable pain. Numbers like 5pk, 3fz, 01c and several others... all mean black, but different shades of black or different textures.
GRU means primered for painting
7DL means its grey
For things like C5A6 seat covers... there can be upwards of 15 pages of part numbers in etka. Each and every different part number indicates a different item. The A6 seat covers are one of the most annoying items to research since there are so many colors and different versions of each color...
This numbering system is the same for Audi, VW, Seat and Skoda. Porsche uses a similar system with periods instead of dashes... Porsche also has different categories 3 in Porsche is brakes where as it would be 6 for VAG. However Porsche uses the same XXX.XXX.XXX basic structure that Audi does, most likely because it came from Dr.Porsche if I remember correctly.
My screen name.. 8D5 means b5 A4 sedan. 8D9 would be for an avant.
More to come....
qfrog Ti20 is offline   Reply With Quote
Old 01-28-2005, 05:21 PM   #2
starting ...
Member
Account #: 74942
Default good to know
starting ... is offline   Reply With Quote
Old 01-28-2005, 05:32 PM   #3
Audi4orce
Member
Account #: 13510
Default Good work Mr. 8D5
I do have the Audi parts bible book
Now, if I only could re-install my ETKA on this ****ty PC(temporary) would be great!!
AW Member since:3/27/99
A4 1.8tqm, 99.5 (born on date 3/99)
Mileage as of 2/06/09: 71K miles
<sunroof delete>
Mods: GIAC 1.0bar chip, BBS CH 18"s,
TT 710N valve, S4 oil cooler,
OEM A6 strut bar, A8 brake upgrade,
B6 rear brake upgrade, Snub mount, S4 engine mount, AWE boost gauge, Fog light mod, S4 grill, S4 wheel liners, Arm rest LED light+coin holder, Sunglass holder, Debadged, Lic plate mod w/t Audisport lic frame, Exhaust tips,
Oils: Amsoil/Motul/German Castrol(engine). RedLine MT90 (Trans/Axle), GL5 Oem (rear diff).
-2004 Jeep Grand Cherokee V8-For Sale
-2002 Ducati 998- Superbike
Previous own cars:
97 Gti-vr6 DE--88 Scirocco 16v--
86 Scirocco 8v--86 240 Volvo
Audi4orce is offline   Reply With Quote
Old 01-28-2005, 05:35 PM   #4
qfrog Ti20
Elder Member
Account #: 26
Default I've got that book too....
newer ones at work too.
However I also have access to something else on the internet that tells me even more info than that book.
Old 01-28-2005, 05:58 PM   #5
Andy_FL
Account #: 12690
Default ^^^^^^^^^^ Our very own "Audi Parts Consultant" ^^^^^ Nice post.
Andy_FL is offline   Reply With Quote
Old 01-28-2005, 06:06 PM   #6
Devious27t
Member
Account #: 59293
Default i havent been able to find a working link to get the damn ETKA.
all show. no go.
stock 2001.5 S4 6 speed (12,400 miles)
333hp 2000 A4 1.8t quattro manual (sold)
formerly Devious18t (retired 3/3/2006)
Devious27t is offline   Reply With Quote
Old 01-28-2005, 06:06 PM   #7
ModifiedA4
AudiWorld Expert
Account #: 143
Default great...so whats the mystery behind the DIN and Class columns?
www.modifieda4.com
ModifiedA4 is offline   Reply With Quote
Old 01-28-2005, 06:18 PM   #8
BSK
Account #: 54666
Default torrentspy.com
aim: afastgerman
BSK is offline   Reply With Quote
Old 01-28-2005, 06:32 PM   #9
qfrog Ti20
Elder Member
Account #: 26
Default maybe I'll eventually get to that.
Old 01-28-2005, 07:42 PM   #10
Carson (K03x2)
Member
Account #: 51556
Default Yeah, that you do.
Too bad I don't have VW Parts-On-Command access.
Carson
'01 VW GTI VR6 12V - SOLD!
'01 S4 Tip Brilliant Black - will be sold for/converted to a 6MT, just a means to an end
'06 A4 2.0TQT Arctic White (leased for wife)
Audi Parts Consultant/ex-Certified VW/Audi Technician
ACNA/NJ Chapter Vice President
Next track event: ACNA/NJ Chapter NJMP, Thunderbolt Circuit, May 2009
ACNA/NJ Chapter Karting @ V-17, Feb. 25 7PM
Carson (K03x2) is offline   Reply With Quote
Tags
025, 151, 451, 4b0, 4e0, 601, 698, 8d0, 8d0955408a, audi, b, number, pads, part, vw
