Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 01-23-2005, 06:25 PM   #1
Andy_FL
Account #: 12690
Default -= Quick write-up for the archives: Checking compression (1.8T) =-
How to check compression on my 1.8T? There's plenty of info in various posts in the archives--thought I'd just sum it up into one. Nothing new here, just a concise post for the archives..
You'll obviously need a compression test kit, which can be found at Sears or your local SnapOn truck. The one pictured below was from Harbor Freight (my local Sears had none in stock), and I would not recommend it. So, consider the picture for reference only.
On a warm engine....
1) Pull all coilpacks and plugs
2) Pull 15A fuel pump fuse (#28)
3) Ideally, you'd want to hook up your battery to an external charger so that it doesn't drain--which might affect your readings. It's not crucial IMO (I didn't use one and my readings seem fine). But if your readings seem to drop off a cliff like this: 180, 175, 170, 160....you might blame the battery and not your cylinders. Just depends on the condition of your battery I suppose.
4) Screw in the hose carefully, then connect to the gauge.
5) Start cranking. [For nDBW, hold the gas pedal to the floor while turning over for each cylinder. For DBW, you could pull the intake hose and prop the throttle plate open] I turned the engine over exactly 6 times per cylinder, as the reading had leveled off at that point. (The most important thing here is to treat all cylinders exactly the same. If you don't, then you may get inaccurate readings.) Repeat for all cylinders. That's it!
So what's a normal reading? Well, Bentley claims anywhere from 144-190psi is within spec. The more important, general rule of thumb is that all cylinders should be within 10% of each other.
On my '97, with 122K, the readings were: 168, 165, 175, and 172.
Oh, why don't I recommend the HF compression tester? It was just plain inaccurate. My initial readings with the HF gauge were: 147, 149, 137, 145. I went back with a SnapOn gauge and got consistently higher numbers.
Good luck.
Andy
Search keywords: compression checker gauge tester test compression readings cylinders.
Andy_FL is offline   Reply With Quote
Old 01-23-2005, 06:29 PM   #2
RNO.Audi
Senior Member
Account #: 42725
Default Nice write-up, add some search keywords to the bottom so it'll be easy to search for.
AIM: SantorinTim
I heart Audis...
K04 Santorin Blue
APR Stg. 3 Brilliant Black
But sedans were too impractical for me...
Now driving a 4runner, Sport (I want an Avant!)
RNO.Audi is offline   Reply With Quote
Old 01-23-2005, 06:32 PM   #3
Andy_FL
Account #: 12690
Default Good call, done. Did I leave any out?
Old 01-23-2005, 06:38 PM   #4
SpeedyDTP247 CQ+UrS4
Member
Account #: 69531
Default nice write-up...anyone have a nice write-up for the 30v 2.8 with nDBW?
rice belongs in a bowl not on cars!!
My CQ project thread and My S4 project thread
Gone but not forgotten Supercharged and Intercooled A4
MI's Audi Enthusiast Forum
Who I cheer for in sports (in no particular order) with some stats.
Tiger Woods
14 Major Championship as a professional, 65 PGA Tour wins, 7 consecutive PGA Tour wins and 9 PGA Tour wins in one year. 1st ever winner of the FedEx Cup. People have to stop putting Phil Mickelson's name in the same sentance with Tiger Woods. Rory Sabbatini needs to keep his BIG MOUTH SHUT!!
Red Wings
11 Stanley Cup championships and 17 consecutive playoff appearences. 8 consecutive 100+ point season.
Pistions
3 NBA championships and 6 consecutive Eastern Conference Finals.
Tigers
4 World Series titles and 10 AL pennants.
U of M Football
11 National Championships, 42 Big Ten championships, 33 consecutive Bowl Game, 170 consecutive crowds of 100,000+, spectators in record attendance of 112,118.
U of M Hockey
9 NCAA, 5 Big Ten, 8 CCHA tournament championships.
U of M Basketball
3 National Invitional Tournament, 11 Big Ten, and 1 Big Ten tournament championships.
Packers
9 NFL, 3 Super Bowl, 8 conference, and 13 division championships. Soon to be Hall of Famer Brett Favre, Thank you for the Great Memories Brett!!! Also cheer on Ruvell Martin (my high school alumni classmate) #82.
SpeedyDTP247 CQ+UrS4 is offline   Reply With Quote
Old 01-23-2005, 06:39 PM   #5
EGainer
Account #: 59163
Default nice nice nice, bookmarking
EGainer is offline   Reply With Quote
Old 01-23-2005, 06:40 PM   #6
EGainer
Account #: 59163
Default hmm ya know what, someone turn this into a tech article...
im takin care of it
Old 01-23-2005, 06:44 PM   #7
ModifiedA4
AudiWorld Expert
Account #: 143
Default nice.
umm those screws sitting on the valve cover make me nervous :P
www.modifieda4.com
ModifiedA4 is offline   Reply With Quote
Old 01-23-2005, 06:56 PM   #8
Silver Streakin'
Member
Account #: 10901
Default and what would you do differently for a DBW?
-Jeff
2001.5 A4 1.8TQMSCC with APR SIII, EVO FMIC, Stoptech-less, STaSIS Tracksports 600F/750R
ACNA MidOhio video
Montreal race school and PDA Pocono video
Silver Streakin' is offline   Reply With Quote
Old 01-23-2005, 07:01 PM   #9
bestbuy489
New Member
Account #: 86583
Default Don't forget...
Firstly write engine (and oil to be really precise) temp down, and write down what readings you get because that will be the only true test on YOUR car. Also Snap-On sells a leak down adapter for little less than price of comp-tester so if you do have loss you can see where it is coming from.
bestbuy489 is offline   Reply With Quote
Old 01-23-2005, 07:07 PM   #10
Digit@lex
Elder Member
Account #: 1308
Default Great write-up Andy!
Digit@lex is offline   Reply With Quote
Tags
100, 18, 18t, a4, audi, checking, compresion, compression, evo, fuse28, gauge, leak, spec, test, vw, write
