Go Back   AudiWorld Forums » Regional & ACNA Discussion » Mid Atlantic Discussion
Old 12-22-2007, 09:58 PM   #1
Roger @ CA
Member
Account #: 72595
Default Time to update the mod list for the new year...
Plenty of new and upcoming mods, so I wanted to make a new version to keep track of everything better... All mods, including those on the car, in storage in the workshop, and planned are in one list.
-BOLD shows they are actively installed on the car. Footnotes are included to show whether they were purchased or given as mod gifts.
-RED shows mods that are waiting to get installed but are in possession.
-ORANGE shows mods that have a D.I.Y. status, so parts aren't needed, but labor is.
-SILVER shows mods that are planned, but not yet purchased/acquired, some may be further down the road than others.
As always, refer to this list if you have questions about the car. If there's something you see that you have questions about, feel free to ask. I love to help out other potential modders.
Cheers,
Roger
_______________________________________________
Roger @ CapitalAudi
AudiWorld.com Member #18954 & #72595
Background Info:
1999.5 (06/99) Audi A4 1.8TQM
Â*Â*Â*-Exterior: Light Silver Metallic/Brilliant Black
Â*Â*Â*-Interior: Onyx/Elephant
Â*Â*Â*-AEB Head #269,272
Â*Â*Â*-DWM Transmission #18090
Â*Â*Â*-Currently with 110k miles
Â*Â*Â*-Bought with 45k miles in 2001
Engine/Drivetrain/Exhaust - Motor/Getriebe/Abgasanlage
-AWE Tuning K04-15 Kit with ECU
Â*Â*Â*-BorgWarner Turbo Systems Gmbh K04-015HF Turbo (BOUGHT from Tim's Turbos)
Â*Â*Â*-Garrett (GIAC) Custom KO4 Programming (PC.16.01.03a File) (GIFT from Chris P.)
Â*Â*Â*-Adjustable FPR (Set at 2.7 BAR) (GIFT from Chris P.)
Â*Â*Â*-Bosch Red Top Injectors (#280 150 945 30lb/310cc) (GIFT from Chris P.)
Â*Â*Â*-NGK BKR7E Spark Plugs gapped at 0.030"
-APR Stage 3 Turbo Kit (GT28R Build in Progress) (Bought from Eduardo)
-APR Motorsports Turbo Inlet Hose (Bought from Eduardo)
-034 Motorsports Standalone (if and when the time comes...) :-)
-5-Speed Manual DWM Transmission (01A 300 046G #18090) with taller gearing
-STaSIS Engineering High-Bias (4:1) Torsen Center Differential (Bought from AXIS Motorsport)
-Evolution Motorsports Ver. 1 Front Mount Intercooler (GIFT from Chris P.)
-Precision Turbo 350hp Intercooler
-APR/aasco Motorsports 12 lb Aluminum Flywheel w/ High-Carbon Steel Friction Surface
-Southbend Clutches DXD Stage 4 6-Puck Racing Clutch (GIFT from Southbend Clutches)
-Samco Sport #TCS264 Black 4-piece Boost Hose Kit (Bought from Anthony)
-IDEAL T-Bolt Clamps on all pressure hoses
-APR/Carbonio Intake Box (Modded) (Gift From APR)
-Cool-It Heat Insulating Mat forming true Intake Box
-Swappable Second Intake Duct: Lower Bumper for Street, Headlight for Track
-Steel Turbo Heatshield and Gold Foil/Aluminized Heat Barrier
-Gold reflective mat insulated oil feed line and coolant feed line
-Power Steering Cooler - B&M Supercooler #70255 Kit (Bought from Andrew)
-Mocal Oil Cooler Sandwich Plate with Thermostat and DANA 24-Row Cooler using XRP AN fittings (GIFT from Chris P.)
-APR R1 Diaphram-based Diverter Valve (Gift From APR)
-Forge Motorsports Polished 007 Diverter Valve (Backup, BOUGHT from Zodiak)
-LaBree Stainless Steel High Flow Catalyst
-LaBree Stainless Steel 2.5" Downpipe
-GReddy #10106803 2.4" Downpipe-back Exhaust
-Side-Exit Exhaust for Track-use only
-034 Motorsports Brushed Stainless Steel Coilpack Cover with 034 badge
-034 Motorsports In-line Fuel Pressure Gauge
-AXIS Motorsports Billet Crankcase Breather Block-off Plate and PCV-Delete Kit
-034 Motorsports Crankcase Breather/Seperator Canister
-Black Wrinkle Finished Valve Cover
-OEM "CASTROL Recommended" Oil Cap (06B 103 485B)
-Aluminized Intake Manifold and Throttle Body
-034 Motorsports Phenolic Intake Manifold Spacer (Bought from AXIS Motorsports)
-Black Wrinkle Finished Coolant Cross-over pipe
-Audi Q7 Coolant Reservoir Cap (1C9 121 321)
-VW Passat B5.5 Power Steering Reservoir Trim Cover (3B0 422 569A)
-V&S Short Shifter
-JHM Solid Shift Linkage
-JHM Delrin shifter stabilizer bushing
-034 EGT Gauge
-Wego or PLX Wideband O2
-SPAL Electric Fan (Arrived)
Chassis : Fahrgestell
-AWE Tuning Drivetrain Stabilizer (DTS) (GIFT from Zodiak)
-DTS Urethane Mount Upgrade-Energy Suspension #3-1108G
-034 Motorsports Street-Density Motor Mounts
-034 Motorsports Street-Density Transmission Mounts
-STERN Rear Differential PolyUrethane Bushings (Bought from PureMotorsports)
-STERN Rear Differential Power Ring (Bought from PureMotorsports)
-APR Snub Mount
-034 Motorsports/APIKOL Rear Differential PolyUrethane Mount
-Special Projects Motorsports P1-Spec Splitter Brackets
-Alumalite underbody panels with brake and transmission ducting
-OEM TT Jacking Points (8N0-804-583 (x4) 8N0-803-855 (x4))
-Splitter materials- (High Density Polyethylene HDPE Sheet, Alumalite, Dibond)
Exterior : Karosserie
-Tri-Xenon Front End:
Â*Â*Â*-Xenon kit for low beams (OEM Subaru STI D2R Xenons)
Â*Â*Â*-Xenon kit for high beams (OEM B6 Passat D2S Xenons)
Â*Â*Â*-Xenon kit for fogs w/ custom B5.5 Passat Projectors (OEM VW Touareg D2S Xenons)
-OEM S4 Xenon Headlights with: (DIY)
Â*Â*Â*-Custom molded dual Projectors,
Â*Â*Â*-Painted body-color
Â*Â*Â*-Audi B6 A4 beam cutoffs and
Â*Â*Â*-Audi R10-type 15-LED city-lighting
-Swappable Front Bumpers:
Â*Â*Â*-Custom Molded A4 Bumper with Oettinger Lower Lip (Summer Bumper) (Originally BOUGHT from SimplyJ)
Â*Â*Â*-OEM RS4 bumper with Racex quick fasteners (Winter/Track work in progress)
-Fiber Images OEM Style Carbon Fiber Hood #2276
-AeroCatch Top-Mount Locking Hood Catches (Ordered from Axis Motorsports)
-Silver Headlight Shells with built-in 3.5" velocity stack (TRACK USE)
-Custom paintwork done by American Service Center in Arlington, VA
-Extreme-rolled fenders on all 4 corners
-Custom HDPE Front Adjustable Splitter w/ Brake Ducting using OMP adjusters (SUMMER USE)
-Custom Alumalite Front Adjustable Splitter w/ Brake Ducting using OMP adjusters (TRACK USE)
-Foglight protective covers (Gift from Rfan)
-RENNLINE Race Tow Hook
-OEM RS4 Front Grille
-DIY Brushed Aluminum Mirror Caps w/ Clearcoat
-Hella Supertone Horn Kit
-Dual S4 Fender liners
-Painted TrimGard 1" Smooth Side Door Moldings (GIFT from Rfan)
-OEM S4 Sideskirts
-Brilliant Black (LY9B) Roofline (Gift from Stan's Collision)
-Carbonio Carbon Fiber M3 Lip Spoiler (BOUGHT from Andrew)
-Painted Rear Valance
-OEM BMW Ground lighting LED's located inside of exterior door handles (63-31-7-163-511x2 and 63-31-7-163-512x2)
-Euro/Aero Wiper blades and matching arms(3B1 955 409C/3B1 955 410C) (GIFT From Zodiak)
-Rear Plate Mount Delete w/ Raised plate mount
-Front/Rear Independent Foglight Mod
-One-Touch Rear Windows
-Full Exterior LED Lighting including 3 Watt Luxeon turn signals, brake lights, reverse lights. (13 bulbs total)
-35% Tint (Johnson Films Silhouette Charcoal SP35) (Custom Installed By Eduardo)
-Debadged/Destripped
-Audi Sport Plate Frame In Carbon Fiber Look (BOUGHT from Andrew)
-Audi R10 Polished Plate Frame (Gift From HBL)
-"Just Dave" Audi Sport Badge with Audi Sport colors
-Custom Rear Valence/Diffuser Tray
-Fiber Images B5 Carbon Fiber Sunroof Delete
-Or JE Design Rear Valance with Diffusers
-Etched vinyl graphics (Audi rings, etc.) (For Summer...)
-More CARBON FIBER!
Interior - Innenausstattung
-Corbeau TRS Black Leather Racing Seats and Airbag Resistors
-Wedge Engineering Audi A4 seat brackets
-Graphite Autopower Industries #60711 4-Point Bolt-in Rollcage w/ Harness bar and camera mount
-Teamtech Motorsports 3" 6-point Harnesses with Cam-Locks (Silver #5002 w/ Black #9001 Pull and Release Loops)
-Teamtech Motorsports Helmet Support and Track Bag
-Full Alcantara Interior in Light Silver Grey: (Material Bought From Andrew)
Â*Â*Â*-A-Pillars
Â*Â*Â*-Headliner
Â*Â*Â*-C-Pillars
Â*Â*Â*-Rear Deck Trim
-OEM S4 B-Pillars in Onyx
-Rear Seatbench Delete in Alumium paneling, possibly with suede covering incorporating Audi logos.
-Leather/Aluminum Mk5 GTI Shifter with Alcantara insert (DIY GIFT from Stohlman)
-Black Alcantara Shifter Surround (BOUGHT From Andrew)
-Black Alcantara Shift Boot by Tycoon (GIFT from Zach)
-Black Alcantara OEM Shifter (Backup) (GIFT from Stealth4)
-DIY Brushed Aluminum Beltline Trim w/ Clearcoat
-GReddy III Turbo Timer (GIFT from SimplyJ)
-Omori 52mm Mechanical Center Vent Boost Gauge
-Omori 60mm Electrical Center Vent Boost Gauge (Bought from Eduardo)
-Nordskog Digital Ambient Temperature Gauge w/ sensor in intake
-OEM 2001.5 A4 Double-DIN Center Dash with 3 gauge positions
-METRA 99-9105 Fitment Kit
-empeg (#3813 of 4300) 120Gb Mk.2a Red w/ GreenLights upgrade
-Diamond Audio S500s HEX Front speakers
-Diamond Audio S12.4 HEX Shallow-Mount Subwoofer
-Diamond Audio D6 450.2 Component Amplifier (125w x 2 @ 4 ohm)
-Diamond Audio D6 450.2 Subwoofer Amplifier (450w x 1 @ 4 ohm)
-NEUTRIK Powercon and Speakon quick-disconnect connections (For TRACK Use) (Bought From Allied)
-Valentine One V1.8--POP2 with Euro Mode with superstealth install
-Full White LED Interior Lighting (11 bulbs total)
-OEM Homelink Visor (BOUGHT From William)
-SPARCO Aluminum Pedal set (GIFT from OldManTan)
-BMW Battery Trunk Relocation (w/ BMW/HELLA Kill Switch and PowerMotive b.v. remote switch) (BOUGHT from John Wise)
-Optima Sealed Spiral-Cell Battery with Aluminum machined bracket
-Hardwired 175 Watt DC to AC Power Inverter for In-Car Laptop
-OEM Tie-Down Hook for Trunk (6Y5 867 615 B41)
-OEM Zippered Trunk Net (3C5 065 110)
-OEM Audi Sport Monster Mats (GIFT From Chris P.)
-MacNeil WeatherTech Full Rubber Cargo Liner (Great for carrying tools!) (GIFT From Chris P.)
-APR ECMS Home Programmer (Bought from Eduardo)
-VAG-COM Cable/Software (GIFT from SimplyJ and Rfan)
-Audi/Dell Inspiron 8200 Laptop w/ ETKA, VAG-COM, and Bentley (GIFT from Jason)
-Clutch Pedal Stop (DIY)
-Lidatek Laser Jammer
-Carbon Fiber interior trim once I learn to lay my own.
Suspension/Wheels - Fahrwerk/Felgen
-18x9" CCW (Complete Custom Wheels) C14 Corsair
Â*Â*Â*-235/40/18 Kumho MX
Â*Â*Â*-Forged 6061-T6 CNC'ed Monopiece Wheels
Â*Â*Â*-Clear Anodized
Â*Â*Â*-Custom offset (ET 32F/40R) using 1/2" spacers
Â*Â*Â*-21 lb's, 1.2 oz's each
Â*Â*Â*-They look like REs sex0red the SLs. - TwinTurboTerror
-18x8" Crimson Japan K6 Wheels (Winters)
Â*Â*Â*-225/40/18 Dunlop SP Wintersport 3D
Â*Â*Â*-Lightweight cast aluminum, polished lip
Â*Â*Â*-Wheels bought from Zodiak
-Vogtland A4/S4 Coilovers - Spring Rates are Front (375-677.2lb/in) and Rear (236.3-627.4lb/in) (Bought From Pure Motorsports)
-STaSIS Engineering/Ohlins Motorsport Coilovers (700/800lb)
-Anti-Sway Bars-Hotchkis #22801 35MM Front (Hollow) & 22MM Rear (Hollow) (Bought From Pure Motorsports)
-Upgraded Rear OEM Metal Swaybar Links (8D0 505 465/466) (BOUGHT From Pure Motorsports)
-Strut Tower Brace Bar (B5 S4 w/ A6 Brackets)
-Full Febi-Bilstein Control Arm Replacement Kit W/ Lemfoerder Tie Rod Ends (Bought from PureMotorsport)
-Chicago Performance Tuning (CPT) Anodized aluminum Upper Control Arms
-Prestige Wheel Custom 2.5" Studs with custom locking nuts
-TireRack Tire Totes
Brakes / Bremsen
-Front Brakes-Porsche 996 4 piston Calipers w/ 321mm x 30mm S4 spec rotors w/ Aluminum caliper carriers. (Evolution Motorsports Stage 3 Kit)
-Front Brakes-Porsche 993 Turbo/GT3 4 piston Calipers w/ 322mm x 32mm 2-Piece rotors w/ Aluminum caliper carriers. (Modified ECS Tuning Stage III Kit) (BOUGHT from Eduardo)
-RoadRaceTechnology/Bimmerworld Modified Aluminum Brake Duct Backing Plates
-Front Pads-Hawk Performance HPS 996 Carrera (HB291F.642)
-Front Pads-Carbotech Performance XP12 CT776
(TRACK USE)
-Rear Brakes-Red Polished OEM Calipers w/ 245mm x 10mm A4 rotors
-Rear Pads-Hawk Performance HPS A4 (HB271F.635) (Gift From Zach)
-Rear Brake upgrade-300x22mm B7 S4 rotors (8E0 615 601R) + B5 S4 Calipers + 034 caliper carriers.
-Crown Performance Custom Stainless Steel Brake Line Kit (BOUGHT from Mat Reid)
Current Spring To-Do List
-Compound/Buff hood and prep for paint. (Done) (0)
-Order Aerocatches and 034 stuff (Done) (100)
-Finalize stereo plans and order (Done) (550)
-Start repairing/sanding RS4 bumper (Started)
-Order Hood stickers and new hardware (Done) (20)
-Freshen engine bay (paint intake manifold, throttle, alternator, phenolic spacer) (Done)
-Radio shack run for mute button (3) (Done)
-Stealth V1 conversion with on/off switch (0) (Done)
-Nordskog Intake Temperature gauge (0) (Done)
-Windshield replacement (Done)(275)
-Order Dzus fasteners (Done)(55)
-Order Trim for divider (Here)(50)
-Find 1 3/8"x7" Red Plexi for dash (Done)
-Convert dash (Cage, Empeg, Temp Gauge, Alcantara) (Done)
-Audi Futon (Done)
-Secure axle heatshield (Done)(0)
-Re-install DTS (Done)
-Bled Slave Cylinder (Done)
-MTL/MT90 Trans flush
-Swap on Winter Tires
-Low beam redo
-Swap street pads on (Done)
-Remove track splitter (Done)
-Permanently mount extra ballasts (0)
-Continuity test on headlight (0)
-Get and mod rear seat side bolsters
-Design graphics inserts for Audi display (20-30)
-Start on Concours To-Fix list (0)
-Retune FPR for street gas mileage (Started) (0)
-Finish building stereo (Sand wood, reassemble, side covers, upholstery) (70% Done) (100)
-Finish bumper repair and skinning (0)
-Get fender rolled/prepped. (100)
-Fog light brake ducts (After WF)(30-50)
-Remove seat sliders (After WF)(0)
-Door Handle Lighting (After WF)(0)
-Friggin resistors? (4.7ohm 1/4w) (Postponed)
-ITG Maxogen JC60/78 3" Air Filter (Gift From Jeproks)
Upcoming events and track schools:
-Some past track pictures...
-09/15/07 ACNA @ Summit Jefferson (Driving (1))
-04/19-20/08 BMWCCA @ VIR Main (Crewing)
-04/21-22/08 ACNA @ VIR Main (Driving (2-3))
-05/16-18/08 Carlisle Imports in PA (Drinking/Show)
-05/25/08 Summit Point Raceway - US Drift Championship (Crew)
-06/08/08 Old Dominion Speedway in Manassas - US Drift Championship (Crew)
-06/14/08 HIN @ FedEx Field - US Drift Exhibition (Crew)
-06/20-21/08 Hyperfest at Summit Point - US Drift Championship (Crew)
-07/14-15/08 TrackDaze @ Summit Main (Driving (4-5))
-07/19-20/08 WaterFest 14 in NJ (Showing)
-08/09/08 Audi Driving Experience @ Summit Point (11am) (Driving)
-08/25-26 ACNA NEQ @ Watkins Glen II (CANCELLED)
-09/27-28 H2O International in OC, MD (CANCELLED)
-11/15-16/08 ACNA @ VIR Main (Driving (6-7))
Regular Maintenance List:
-Oil Filter (Large OEM, 108,900)
-Oil (Castrol Syntec 5W-30, 108,900)
-Air Filter (Carbonio Dry Foam, 98,000, 01/13/08)
-Pollen Filter (OEM, 87,000)
-Fuel Filter (OEM, 89,000, 06/10/07)
-Spark Plugs (NGK BKR7E #6097 @ 0.30", 108,900, 06/15/08)
-Clutch Disc (Southbend Clutch DXD Stage 4, 108,115, 10/11/08)
-Transmission Oil (Castrol 75w/90 for Break-in, then REDLINE MTL/MT-90 2:1 Mix, 108,115)
-Rear Differential Oil (REDLINE 75w90 Gear Oil, 99,500)
-Tires (235/40/18 Kumho MX, 88,000, 04/20/07)
-Tires (225/40/18 Dunlop Winter 3D, 97,000, 12/13/07)
-Front Brake Pads (Hawk Hawk Performance HPS, 8?,000)
-Front Track Brake Pads (Carbotech Performance XP12 CT776, 100,000, 04/15/08)
-Rear Brake Pads (Hawk Performance HPS, 8?,000)
-Brake Fluid (ATE Super Blue, 109,150, 11/14/08)
-Valve Cover and Intake Manifold Gaskets (OEM, 90,000, 07/07/07)
-Front CV Joint and Boot Overhaul (OEM, 98,500, 02/17/08)
-Rear CV Joint and Boot Overhaul (OEM, 110,000, 02/17/08)
-Turbocharger (BorgWarner Turbo Systems Gmbh K04-015HF Turbo with complete hardware, 100,454, 04/25/08)
-Timing Belt/Tensioner
-Water Pump
-Coolant Flush (Custom Red G12 Mix, 100,000, 04/2008)
Previous Mod list Version
Check out what I'm selling in the classifieds for B5 A4's and S4's!
1999.5 Light Silver A4 1.8TQM (Winter Massaging)
1993 Emerald Green 90 CS 2.8QSM (SOLD)
1993 Crystal Silver Metallic 90 CS 2.8FM (RIP)
What I use to make the Audi look so fresh and so clean...
'Mein Audi ist meine entspannung.'
If it ain't modded I don't want it on my car. "NEVER FOLLOW!" - My Audi philosophy
Roger @ CA is offline   Reply With Quote
Old 12-23-2007, 04:24 AM   #2
Giggles::Go 'cuse
Member
Account #: 90854
Default that was like reading a book....
in german.
Giggles::Go 'cuse is offline   Reply With Quote
Old 12-23-2007, 05:12 AM   #3
Roger @ CA
Member
Account #: 72595
Default It's good to brush up on your native tongue from time to time.
Old 12-23-2007, 06:28 AM   #4
apk-S4
Account #: 94109
Default Which control arm kit are you buying? I need to do the same...
apk-S4 is offline   Reply With Quote
Old 12-23-2007, 06:33 AM   #5
M3 Ninja
Junior Member
Account #: 84935
Default Where did you put down all your track time?
M3 Ninja is offline   Reply With Quote
Old 12-23-2007, 07:39 AM   #6
Roger @ CA
Member
Account #: 72595
Default The febi-bilstein s4 kit with the upgraded Lemfoerder tie rod ends....
PureMS has it, I can get wholesale.
Old 12-23-2007, 07:40 AM   #7
Roger @ CA
Member
Account #: 72595
Default Very good point, I'll make a section.
Old 12-23-2007, 07:57 AM   #8
genxguy:gettingclose
Member
Account #: 40642
Default So is this the longest mod list you've ever done?
The most modded car?
Burning My Wallet
Wanted: Real estate clients for my wife so she can feed my track habit.
For all your brake and tire needs
genxguy:gettingclose is offline   Reply With Quote
Old 12-23-2007, 08:00 AM   #9
Tailspin
Elder Member
Account #: 42380
Default That's a lot of stuff, 2.0 stroker kit coming soon?
Tailspin is offline   Reply With Quote
Old 12-23-2007, 08:02 AM   #10
Roger @ CA
Member
Account #: 72595
Default Planning on buying a spare longblock to build up slowly... plenty around for ~700.
Just need a place to keep it...
