| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Member
Account #: 29024
This writeup will show you how to remove the bulb out warning in the cluster if you have purchased KaTuning's LED Tail lamps (sold by TMTuning.com). Not sure if Topauto.de's tails are the same, but I suspect they are.
The skill level is about a 5/10 with soldering ability needed. 10 = Master tech 5 = Average Garage monkey 1 = 10yr old son's ability The equipment you'll need is: +Wire Cutters +Pliers +Soldering Iron +Solder +18-20 Guage wire (12 inches total) +2 100ohm-150ohm 5W-10W ceramic coated resistors +Heat shrink (various sizes) +4 Squeeze Connectors ![]() ![]() ![]() ![]() Start off by cutting four 3" wires. Strip only one end of each wire to expose about 1/2" of wire. Then trim the resistors so that only about 1/2" of the wire coming out of each end of the resistor is showing. Next wrap the wires around the ends of each resistor. ![]() Next solder the wires to the resistors. ![]() Next cut some heatshrink and use the base of the soldering iron to heat up the heatshrink. ![]() Next cut some larger heatshrink and shrink it over the Resistor. ![]() Next use the pliers to clamp the wire squeeze connectors onto the BLACK and GREEN/WhiteStripe wire on the LED Tail Lamp. The Black wire is the ground wire and the Green/WhiteStripe wire leads to the LED's for the running light. The wires are the same for each tail lamp. ![]() ![]() Now you're done. Here's what the Running Lights look like installed on the car with NO Bulb Out Error. ![]() With Brake Lights on: ![]() With Hazards on:
#2 |
Junior Member
Account #: 86230
#3 |
Junior Member
Account #: 75221
![]() GIAC FX ~ AWE exhaust ~ APR TIP w/ samco boost hoses ~ K&N ~ Koni/neuspeed suspension ~ 18" fliks/BF Gdrch SS A/S ~ APR snub mount ~ B&M SS ~ podi ~ RS4 pedals ~ 3.0 front brakes ~ hawk pads all around ~ european xenon headlights ~ black out grill trims ~ painted front bumper w/ zender add-ons ~ S4 door blades and rear bumper ~ ebay spoiler ~ 40% tint <a href="http://www.dvagonline.com/forums/showthread.php?t=507">the history of my car </a> |
#4 |
Junior Member
Account #: 63072
#5 |
Member
Account #: 39591
#6 |
Senior Member
Account #: 52813
------------- 2002 A4 1.8T 5M. 130k miles and counting AIM/Gamertag: denimA4turbo |
#7 |
Member
Account #: 29024
stripping so that it doesn't stick out.
They fit well, there was never an issue there. I think the water issue is due to the trunk and how it's designed. It's designed to allow the water to flow down the sides near the seam. The stock tails and the LED tails both have the stock wire harness exposed to water. The LED tail is sealed up very nicely in the rear and I don't see how water can get into the wiring. The bottom line is that the stock tails let water in too, I've seen it, so it's not an issue for me. The trimmed weather stripping is still an issue for me because if you look at it up close you can see where it was trimmed. That look was not meant for an Audi, it's got to be perfect. |
#8 |
Junior Member
Account #: 63072
#9 |
Member
Account #: 29024
#10 |
Senior Member
Account #: 61481
Bronze 2002 A4 1.8T M/T quattro Brilliant Black/Ebony APR Stage 1, snub, TIP, 710N DV Neuspeed Short Shifter Koni FSD/Eibach/H-sport S4 sways B5 S4 front brakes, Porterfield R4S Stoptech SS lines Dunlop SP Sport 01/Yokohama AVID H4S |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
