Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B6 Platform) Discussion
Old 12-13-2005, 09:39 PM   #1
akula-ssh
Member
Account #: 70933
Default A far as I know new implementation of fitting city LED lights: no LE's outside of housing...
Preamble:
I've always hated the idea of having to run LE's when putting in LED's. I bought a pair a while ago, which are rated at 35 ohms, but haven't put them in for 2 reasons: 1) I didn't want to have wire running under the hood for routing the LE's; 2) I don't like the idea of a hot LE's sitting somewhere. A fellow AW'er, MC Hammered, thought of using a city light bulb as a current drain, which got me thinking: how high a resistor can I go without triggering the bulb-out warning? This is what I ended up with:
That's right, a 220 ohm resistor rated at 5W (for a good bit of over-engineering)! The idea is that at this resistance, the power dissipation is around 0.9W assuming a running voltage of 14V on the car. Such a power rating would mean a cool LE that can be placed inside the housing. Indeed, after 6 minutes the surface of the resistor is barely as warm as the ambient temperature on a hot sunny day.
Tabs are then placed inside the housing:
Now with the resistor connected (a bit of electrical tape for good measure):
And one last shot: a comparison between Philips Blue Vision city bulb and the 5-LED matrix bulb from autolumination.com (recommended by Eddie Man):
Cost of resistors plus tabs and connectors: ~CAD$10, which IIRC is cheaper than the corresponding LE's, which are arguably less elegant a solution
Big thanks to MC Hammered who sourced the resistors and connectors pictured! By the way, for those who care, I actually tried resistances up to 250 ohms for that's the max of the variable resistor I've got sitting around, but it was decided we err a bit on the safe side and get resistors that draw a bit more current instead of the other way around (evidently 250 ohms isn't a common commercially available resistor).
List of 3.0 owners on AW compiled by A4AdMan
<big>2002 Audi A4 Avant 3.0 Quattro Tiptronic</big>
Premium package, sport package, xenon headlights
Modifications to date:
Neuspeed Sport springs
Koni shocks (50% all around)
H-Sport anti-roll bars
custom stainless steel rear upper spring seat spacer
Silver OZ Superleggera 18x8
Sumitomo HTR Z III 235/40-18 95Y XL (current summer)
Toyo T1R 235/40-18 95Y (previous summer)
Falken GRB FK-451 235/40-18 91Y (previous summer)
Dunlop SP WinterSport M2 235/45-17 94H (winter)
Supersprint resonator and mufflers (quick video clip here)
BMC CDA intake
Alcon B Type calipers
Coleman Racing 13x1.25" 2-piece rotors
Carbotech XP8 brake pads
aluminum interior trim
black bumper grill
opened driver side foglight grill (from 1.8T)
auto-dimming blind-spot Euro side mirrors
bi-xenon E-code headlights
Ultraleds (ultraleds.co.uk) 1W LED H6W bulbs
Sylvania SilverStar H7 (high beams)
Stealth blinker bulbs 7507 (front and rear)
Hüper Optik Ceramic 60 and Sech (metal) tint
My alignment specs
Writeup on load equalizers mounted inside e-code housing
akula-ssh is offline   Reply With Quote
Old 12-13-2005, 10:08 PM   #2
shadyraven
Senior Member
Account #: 37283
Default The amount of member R&D that goes into these city light mods is mind-blowing!
shadyraven is offline   Reply With Quote
Old 12-13-2005, 10:43 PM   #3
MC Hammered
Member
Account #: 91797
Default This is what happens when 2 Audigeeks want an 'elegant' solution. =)
And we were bored. =P
2004 Audi A4 Avant 1.8t Quattro 6sp - slightly modified
Click the pic for the details
MC Hammered is offline   Reply With Quote
Old 12-13-2005, 10:53 PM   #4
MC Hammered
Member
Account #: 91797
Default Next task?? A cupholder that works for the B6!!!! =)
Old 12-13-2005, 11:29 PM   #5
shadyraven
Senior Member
Account #: 37283
Default If you two are bored, why don't you make another trip to the island and we'll do a run to PR.
Old 12-14-2005, 02:35 AM   #6
MuRaN0Daddy
Member
Account #: 35713
Default OK, so now, where do I buy them?
Gone....but never forgotten....
ENJOY.............2006 A3 2.0t DSG Murano on Plat Prem Cold Nav Bi-X Sirius
Stuff: REVO. Akebono pads (front)Carbotech Bobcats(rear).Carbonio CAI. Michelin X-Ice snows.NGK BKR7E IX ECS dogbone. Forge Motorsport Replacement Vacuum Operated Piston Diverter Valve. Drop(Neuspeed springs, Koni sports, H&amp;R sway).Vag-Com mods. Nav update.Pro-Form Clear Bra. Color-match front grille trim/Euro plate holder.ECS black-out S Line grille.Custom Euro plate.Air shifter knob.Trunk monkey. ECS smoked repeater turn signals, bumper side markers.City lights wired. Black arm rest. Black net. Piano door trim.Black Bose boxen. GLI pedals. TT DP. Monster Mats. Lloyd custom boot mat. Toerag torch. Euro-split mirrors. Hagus S4 mirror covers(matte). Vibrant 1305's. Llumar 30%. Pro-Clip phone mount/IPod mount. DICE. Ashtray insert. Audi OEM Base Carrier Bars/Baracuda.
Not coming: GIAC. Coming: Exhaust. Velvet steering wheel cover.
Currently aboard: 2008 Subaru OBS Obsidian Black.
Lots of show, no go.
<a href="http://forums.audiworld.com/s4/msgs/2007784.phtml">
Maybe the best post ever</a>
Retired:
2002 A4 1.8t Avant Tip
2005 A4 1.8t Saloon Tip USP
2006 A3 DSG
MuRaN0Daddy is offline   Reply With Quote
Old 12-14-2005, 06:41 AM   #7
forced induxion
Member
Account #: 98177
Default is this way over anyone else's head?
forced induxion is offline   Reply With Quote
Old 12-14-2005, 07:25 AM   #8
akula-ssh
Member
Account #: 70933
Default I think they'e just from a local Radioshack. I'm sure MC Hammered would chime in later :)
BMC CDA intake
black bumper grill
My alignment specs
Old 12-14-2005, 07:26 AM   #9
Steve Sherwood
Account #: 5
Default No..
But then I am a brain surgeon...so..its all relative... :-)
Steve S
Audiworld, Contributing Editor/Moderator
07 BMW 335i
Previous Audis...
05 Audi A4 1.8TQ Ultrasport (AW project car)
01 Audi S4
99 Audi A4 1.8TQM
00 Audi A4 1.8TQM
01 Audi S4 Avant
83 Audi 4000E
00 Audi S4
97 Audi A4 2.8QM
Steve Sherwood is offline   Reply With Quote
Old 12-14-2005, 07:26 AM   #10
akula-ssh
Member
Account #: 70933
Default I wouldn't mind that; maybe in the new year?
BMC CDA intake
black bumper grill
My alignment specs
