| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Member
Account #: 70933
I've finally decided I want to have better turn-in on my car, so I went in for an alignment. I've been reasonably happy with how my car has been behaving, but thought some experimenting won't hurt. I don't have CPP arms, so there aren't so much to adjust, but anyways, these are my initial spec (all in degrees):
Camber: -1.41 (LF), -1.47 (RF), -1.30 (LR), -1.06 (RR) Caster: 4.32 (LF), 4.41 (RF) Toe: 0.24 (LF), 0.26 (RF), 0.34 (LR), 0.22 (RR) Specs after the first alignment (no change in caster): Camber: -1.38 (LF), -1.46 (RF), -2.10 (LR), -2.06 (RR) Toe: 0.04 (LF), 0.05 (RF), 0.16 (LR), 0.21 (RR) What I asked the shop to do was to reduce toe, which they did to about the same amount front and rear for me. The guy who worked on my car told me that in stock form there's about 0.5 degree more negative camber at the rear than the front, thus the setting. The turn-in improved quite noticeably, but I had a bit more understeer than before. So what do I do? I went back for an adjustment to the rear: Camber: -1.35 (LR), -1.33 (RR) Toe: 0.29 (LR), 0.27 (RR) The unfortunate thing is that for whatever reason camber simply has to be quite negative for close to 0 toe, thus this spec. This brought me to settings that are close to what I began with (except now the toe's not wonky like before). Impression: to be honest, not a whole lot different than before I started with this experiment. That's of course unacceptable after having spent money, so a 3rd adjustment... Camber: -1.94 (LR), -1.89 (RR) Toe: 0.17 (LR), 0.17 (RR) The guy at the shop managed to get the toe back to similar specs as after the 1st alignment, but reduced the amount of camber by ~0.2 degree. And now I'm happy: sharper turn-in, and a good neutral handling balance
List of 3.0 owners on AW compiled by A4AdMan ![]() <big>2002 Audi A4 Avant 3.0 Quattro Tiptronic</big> Premium package, sport package, xenon headlights Modifications to date: Neuspeed Sport springs Koni shocks (50% all around) H-Sport anti-roll bars custom stainless steel rear upper spring seat spacer Silver OZ Superleggera 18x8 Sumitomo HTR Z III 235/40-18 95Y XL (current summer) Toyo T1R 235/40-18 95Y (previous summer) Falken GRB FK-451 235/40-18 91Y (previous summer) Dunlop SP WinterSport M2 235/45-17 94H (winter) Supersprint resonator and mufflers (quick video clip here) BMC CDA intake Alcon B Type calipers Coleman Racing 13x1.25" 2-piece rotors Carbotech XP8 brake pads aluminum interior trim black bumper grill opened driver side foglight grill (from 1.8T) auto-dimming blind-spot Euro side mirrors bi-xenon E-code headlights Ultraleds (ultraleds.co.uk) 1W LED H6W bulbs Sylvania SilverStar H7 (high beams) Stealth blinker bulbs 7507 (front and rear) Hüper Optik Ceramic 60 and Sech (metal) tint My alignment specs Writeup on load equalizers mounted inside e-code housing |
#2 |
Account #: 1060
#3 |
Account #: 45523
A4 is essentially a pig, as much as I like it..
To get it to rotate, you want to REDUCE the grip in the rear, namely, less rear camber, less rear toe, increased roll stiffness in the rear (I put on the S4 rear bar)... I'm going to have mine aligned pretty soon, and put the rear camber to stock (-2 now) and around 0 toe.
2002A4 1.8TQMSPX w/o sunroof and a bunch of (functional) mods... |
#4 |
New Member
Account #: 67442
Did you ever install the BMC CDA?
#5 |
Member
Account #: 70933
#6 |
Member
Account #: 70933
I agree with what you said, which is why I've got the H-sport at stiff, and wanted to have less camber than I seem to be able to dial in, and the lowered toe.
#7 |
Member
Account #: 70933
#8 |
Member
Account #: 43387
my alignment guy said that without a camber kit, i cannot reduce my camber of -2 in the front b/c my suspension is so low. is this true?
#9 |
Member
Account #: 70933
#10 |
Account #: 45523
Now it just so happens, that 2 degrees is what I wanted...
I am getting bad wear though.. Gonna raise the car just a tad to reduce the front camber a bit. If you want stock type alignment, you have to get adjustable arms for the front..
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
