Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B6 Platform) Discussion
Old 04-25-2005, 06:41 AM   #1
akula-ssh
Member
Account #: 70933
Default Did a bit of rear suspension work over the weekend...
I've been running my Koni/Neuspeed Sport for a while now, and the rear of my car has always been sitting uncharacteristically low at around 24-3/4" ground to fender:
Since it's actually low enough that I rub the liner every now and then, I decided I have to do something about it. Short of buying a set of coilovers, which I might well do in the future, I thought I'd experiment a little, and made myself a couple "spacers" at a mech shop...
The stainless steel spacers were dimensioned to sit in between the car and the upper spring seat (which is the rubber piece). Since I know I've been sitting on the bumpstops, I had to take a guess as to how thick to make the spacer. Lucky for me, the 2cm (about 3/4") I decided upon worked perfectly and brought my car up to 25" ground to fender now...
O, and did I say the handling has improved? As well, the rear suspension now soaks up bumps better than when I was sitting on the stops?
List of 3.0 owners on AW compiled by A4AdMan
<big>2002 Audi A4 Avant 3.0 Quattro Tiptronic</big>
Premium package, sport package, xenon headlights
Modifications to date:
Neuspeed Sport springs
Koni shocks (50% all around)
H-Sport anti-roll bars
custom stainless steel rear upper spring seat spacer
Silver OZ Superleggera 18x8
Sumitomo HTR Z III 235/40-18 95Y XL (current summer)
Toyo T1R 235/40-18 95Y (previous summer)
Falken GRB FK-451 235/40-18 91Y (previous summer)
Dunlop SP WinterSport M2 235/45-17 94H (winter)
Supersprint resonator and mufflers (quick video clip here)
BMC CDA intake
Alcon B Type calipers
Coleman Racing 13x1.25" 2-piece rotors
Carbotech XP8 brake pads
aluminum interior trim
black bumper grill
opened driver side foglight grill (from 1.8T)
auto-dimming blind-spot Euro side mirrors
bi-xenon E-code headlights
Ultraleds (ultraleds.co.uk) 1W LED H6W bulbs
Sylvania SilverStar H7 (high beams)
Stealth blinker bulbs 7507 (front and rear)
Hüper Optik Ceramic 60 and Sech (metal) tint
My alignment specs
Writeup on load equalizers mounted inside e-code housing
akula-ssh is offline   Reply With Quote
Old 04-25-2005, 07:08 AM   #2
Matt Devo
Senior Member
Account #: 52813
Default I'd pay $$ for a set of those - sent you an email
2002 A4 1.8T 5M. 130k miles and counting
AIM/Gamertag: denimA4turbo
Matt Devo is offline   Reply With Quote
Old 04-25-2005, 07:08 AM   #3
WinnerAudi18
New Member
Account #: 87413
Default Im having the same problem. Where did you get those?
WinnerAudi18 is offline   Reply With Quote
Old 04-25-2005, 07:11 AM   #4
akula-ssh
Member
Account #: 70933
Default I just had them made at a mechanical shop I have access to
BMC CDA intake
black bumper grill
My alignment specs
Old 04-25-2005, 07:19 AM   #5
WinnerAudi18
New Member
Account #: 87413
Default Dude how much .. I would buy a set
Old 04-25-2005, 07:20 AM   #6
Eddie Man
Member
Account #: 10568
Eddie Man's Avatar
Default That's a one fine piece of custom work and very ingenious:)...
One question though; In your pic, you have the rubber base sitting on your custom spacer...
But doesn't the spacer actually fit/sit upside down as you've shown it?
What I mean, spacer female pocket on male coil arm nub, then rubber base female pocket on custom spacer male nub?
2006 S4 Avant: dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
Performance: Milltek.50%NonResonated | Milltek.DPw/HFC | ECS.2PieceRotors | EBC.RedStuff | H-Sport.RS4Sways
Strat.CAI | JHM.SolidSS | SSBrakeLines | ECS.Snub | Bridgestone.RE050A | Bilstein.PSS9 | LaunchVidClips | ServotronicMod
Cosmetic: CF.Splitter | RS4Knob | Debadged"V8" | RS4Pedals | VMR.19"B7.RS4s | Eurolites | Armourfend.Bra | 5400kD1S
XenonFogs | PennyMod | SmokedReflectors | S4CaliperSpring | RS4Grille | OEM.EngineCovers | LOSTLINKS :(
Eddie Man is offline   Reply With Quote
Old 04-25-2005, 07:46 AM   #7
Frank1
New Member
Account #: 52054
Default Re: That's a one fine piece of custom work and very ingenious:)...
Eddie Man,
Just lookin at your pictures of the rear spring and shock and notice you can't adjust them for height like you can the front coilover, is this the norm, I thought coilovers came the same all round like your front ones and if any height adjustment is required you have to use a spanner?
Thanks.
Frank1 is offline   Reply With Quote
Old 04-25-2005, 07:54 AM   #8
Bob Loblaw
Senior Member
Account #: 42205
Default !
akula-ssh uncovered!!
plus
j/k!
Nice work!
Bob Loblaw is offline   Reply With Quote
Old 04-25-2005, 08:18 AM   #9
shadyraven
Senior Member
Account #: 37283
Default LOL!
shadyraven is offline   Reply With Quote
Old 04-25-2005, 08:24 AM   #10
Eddie Man
Member
Account #: 10568
Eddie Man's Avatar
Default Yes & no...
Rears are indeed adjustable...
In this pic, the gray circular pieces in the box are the spring base purches (they take the place of the OEM rubber bases) and they have height adjustable collars by spinning the collared thread to the desired height.
The suspension design of the B6s are considerably different when it comes to the spring/damper setup...
Some other cars, they are similar where both front & back concentric spring/damper setups can be used.
For example, Miata's Spring/Damper Configuration:
One thing however that is a detriment IMO, is that the range of adjustablility is much larger for the fronts as it is for the rears...
Rears is approx. +/- 0.75"
Fronts is approx. +/- 2".
But anyways, that's a minor point in that the 2" range is really not useable.
