Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 4000 / Coupe GT Discussion
Old 09-30-2001, 02:09 PM   #1
rocketaudi
Member
Account #: 25765
Default engine swap
i read all about 2bennets swap for the 4000 with a turbo motor and thats probably the way i wanna go except i dont have 9 grand for the job... if i buy a cgt for a few thousand id have the donor engine and a few other parts im looking for.. could i just take it somewhere and have the swap done cheaper?
Never Follow
rocketaudi is offline   Reply With Quote
Old 09-30-2001, 07:00 PM   #2
Evilclown
Member
Account #: 13879
Default CGT was never turbo. Get a 5kt or 200t.
The turbo swap is a lot more involved than remove NA engine, install turbo engine, close hood, go fast. From what I gather, you have to cut the battery box out and relocate it to the trunk, either remove or relocate the A/C, I think the alternator needs to be moved(not sure about this one), etc. It's definitely a job that should be handled by someone with some real Audi skills and a lot of time, neither of which does the average Joe Mechanic have. Your best bet is to get an NG motor(2.3 liter, 130hp) from an 80q or 90 and tune that. It won't be as powerful, but it's a straight bolt-in, and it will still have good power.
Evilclown is offline   Reply With Quote
Old 10-01-2001, 11:49 AM   #3
4KS NJ
New Member
Account #: 24154
Default Re: CGT was never turbo. Get a 5kt or 200t.
Would it be possible to have this done to a 4-cyl non-quatt or would it require extensive mods? Just wondering...
4KS NJ is offline   Reply With Quote
Old 10-01-2001, 08:34 PM   #4
Evilclown
Member
Account #: 13879
Default I'm not sure. I think the trans might not bolt up, I'm thinking the clutches are different.
The best bet for a 4-cyl. turbo kit is ATP. I don't know if they have anything for the longitudinal Audi 8v motors, but they do a lot of early VWs, as well as late-model VW and Audi(1.8T).
Old 10-02-2001, 05:14 AM   #5
Red Baron
New Member
Account #: 25735
Default Has anyone sucessfully installed a turbo on a NG 2.3 /130hp?
Ive got some cheap tires I would like to vaporize!
Red Baron is offline   Reply With Quote
Old 10-02-2001, 09:45 AM   #6
MikTip
Member
Account #: 6607
Default Re: engine swap-Look here!
2004 A4 1.8t USP Quattro 6MT
27 years of driving, modifying & DIY repair of Audi's
Spec's Stage 2+ with OEM DMFW
HJS Tuning HFC
Jet-Hot Cermi-coated & ported exhaust manifold.
K04-15/GIAC/TT 225 Injectors/Thermal Race/710N/Ecodes/RaceTec FMIC
Neuspeed TIP/Neuspeed Snub/Optima 75-35/AFE Pro-Dry
AMS Short-shift @ %40 redux(Sweet!)
H&R Sport Springs/Bilstein Sport Shocks
H-Sport Anti-Sway bars
19x9.5 RS6's/Falken St115 Skins
365mm B7 RS4 brakes
Sirius Satellite Radio
Ross-Tech HEX-USB+CAN Equipped
Escort 8500 X50
MikTip is offline   Reply With Quote
Old 10-02-2001, 10:33 AM   #7
Evol
Member
Account #: 12421
Default Turbo installs are not generally done on NG motors due to their high compression ratios.
95 A6q 5speed
98 VW GTi Vr6
81 VW Rabbit Pickup
Evol is offline   Reply With Quote
