Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 5000 / 200 / V8 Discussion
Old 08-06-2005, 03:52 PM   #1
MarkPan
Account #: 74227
Default anyone have specs on the oil pressure, temp, etc senders?
I'm going to have to rig up some bargraph stuff i think.
or if i work on my code, i can use an LCD display deal.. sont see that going ove too well though.
any graphs of the senders would be great
MarkPan is offline   Reply With Quote
Old 08-06-2005, 04:41 PM   #2
RussB
Account #: 49589
Default Specs on 5000/100/200 oil pressure SWITCHES (not senders)
Senders are transducers: they convert a physical phenomenon (heat, pressure, speed) into an electrical analog (voltage or resistance). In the 5000, we have only oil pressure switches.
I'm aware that the 100s and 200s have an oil pressure sender that's located on the passenger side of the engine block. I'm sorry that I have no idea of its spec, other than this, published by Audi: With connector G removed from sender, using tool VW1301, with ignition ON, gauge should read:
Dial setting: 350; Gauge should read: 5 bar
Dial setting: 150; Gauge should read: 2 bar
Dial setting: 010; Gauge should read: 0 bar
Though I haven't checked the schematic, I can only guess that the oil pressure sender's resistance changes as a function of oil pressure. Assuming that the VW1301's dial settings are linear, it appears that within this range the output resistance change of the sender vs oil pressure is fairly linear.
If you have a 100 or 200 maybe you can hang a high impedance DVM on the oil pressure sender's G terminal and record its voltage vs oil pressure as indicated by your oil pressure gauge.
I *can* help regarding oil pressure switches, which are located on the driver's side of the engine block.
Low pressure switch: When the oil pressure is too low (below 0.3 bar), the low pressure switch closes and sends a ground signal to the oil pressure control module. When the oil pressure is above 0.3 bar, the switch is open.
The high pressure switch works the opposite of the low pressure switch. When the oil pressure is sufficient (above 1.8 bar), the switch closes and sends a ground signal to the oil pressure control module. When the oil pressure is too low, the switch opens to ground.
The oil pressure control module is integrated into the autocheck control module.
Below 2000 RPM, only the low pressure switch is used to determine low oil pressure.
Above 2000 RPM, the high pressure switch is used to determine low oil pressure.
http://russbellew.com
RussB is offline   Reply With Quote
Old 08-06-2005, 07:14 PM   #3
MarkPan
Account #: 74227
Default thanks russ
I was just thinking I would like the oil temp/pressure gauges like a 200 has, but i'd have to make them bargraphs so i could find somewhere to put them in the 5000.
I guess the 200 must have aditional sensors?.. i guess i should take a look at my audi schematics
Old 08-07-2005, 07:14 AM   #4
a-talk
Account #: 76987
Default Put gauges in the ashtray spot
I've successfully put a pair of VDO oil pressure and oil temp gauges in the ashtray location (see thread - http://forums.audiworld.com/v8/msgs/81197.phtml)
I used an oil pressure sender from an '89 100, and put it in the spot where the low pressure sender was on my 5000s. Having some problems with getting the 2nd terminal to work, but it may be just an incompatibility with the terminal and the autocheck system.
VDO oil pressure sender (the one that can feed an actual gauge) looks like this -
'90 200 TQA - 'redhead wagon'
'89 Audi 200 TQA - "partsvagen"
'84 Porsche 944 NA - Mathilda
SOLD :(
'83 Audi 5KTD - Higgins
a-talk is offline   Reply With Quote
Old 08-07-2005, 11:32 AM   #5
MarkPan
Account #: 74227
Default Good idea! won't work for me though, I smoke.
