Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 5000 / 200 / V8 Discussion
Old 06-12-2003, 07:53 PM   #1
Avant Sport
Junior Member
Account #: 51307
Default Radio volume control knob cutting out
The volume control on my radio is acting up. It cuts out when trying to lower volume and acts if I turned the radio off. Wiggle or tap the knob and it turns back on. If I adjust volume with a little side load on the knob, everything seems fine. Does this sound like dust in the switch(alot of little league games recently) or something else? Would some kind of tuner cleaner do the trick and if so would I need to pull a fuse before I clean(radio turns on with or without ignition on)?? Any ideas??
Thanks, Tom
'04 A4 1.8tq Avant - GIAC/Debadged/Sport All Weather Mats
'89 200tq Avant (Sold)
Avant Sport is offline   Reply With Quote
Old 06-12-2003, 10:26 PM   #2
tonyj
Member
Account #: 49727
Default Re: Radio volume control knob cutting out
Mine had loud static when it was turned. Had no luck ad disassembling radio and the switch was probably not servicable. Figured I would replace the part but tried to spray DOxit (Caig Labs) in the side of the knob. Static stopped and has been fine for months since.
Tuner cleaned should work about the same.
I would just have the radio off when spraying.
Can't hurt, Might help.
Tony
'91 100Q 5spd
tonyj is offline   Reply With Quote
Old 06-13-2003, 03:14 PM   #3
Jim Bush
Junior Member
Account #: 28827
Default I have an extra radio in good working order if you can not get it to work but I would try...
...to clean the connection as was listed. Should work. $40 for the radio (1989 200 radio)
Thanks,
Jim Bush
Holland, MI
Jim Bush
Holland, MI
1995 A6 Quattro Avant
1990 Coupe Quattro
1991 80 Quattro
Jim Bush is online now   Reply With Quote
Tags
audi, knob, volume
