| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Account #: 120574
So got the injectors back today. Turns out RC Engineering completely reconditions the injectors. (aside from the flow test and cleaning) you get new O-rings, They replace the nozzle (i wasn't aware of this) and repaint the housing (this was news too). They looked BRAND NEW when i opened them, i almost thought they weren't the same injectors I sent them.
Regardless, i'm sure they work as tested, but unsure of the replaced tips seeing that the stock ones had a pit that flares out more. See pics below you'll see what i mean. Not sure if that would affect spray pattern? Take a look, tell me what you think. Injectors before: ![]() INjectors after: ![]() Angle 1 before: ![]() Angle 1 after: ![]() Angle 2 before: ![]() Angle 2 after:
Thanks, Brian - www.djbriancabalic.com ------------------------ 1993 UrS4 Pearl/Black, Pastore 1+, Relayed Walbro 255, 70mm throttle, Forge DV, LS2 coils, Apikol+034 SSK, 3" DP to Magnaflow exhaust, Eibach/Bilstein, 18x8 ET30 RS4 reps, and a bunch of 034 stuff. 1983 UrQuattro - Restoring... iLoveHouseMusic.com - DEEP | SOULFUL | FUNKY | HOUSE www.ez-disc.com - Affordable disc duplication ---------------------- |
#2 |
Member
Account #: 37962
#3 |
![]() Join Date: Feb 2001
Naturally, IMHHEO(tm), Dave F. aka the Librarian Car and Mods: 93 S4, 1.8t coil pack conversion (First in world using integral POS coil packs (??)), CF (OE), S6 steering wheel, RS2'd, Samcos, MRC, TDS-1, Apikol FMIC, Eibach/Bilstein, BIRA Sys 1, relayed FP Click here to link to the UrS FAQ Thread Start Uncle Dave says "You want my 'high horse, elitist' opinion ?(IMHHEO(tm))Then just post something stupid." Unofficial Chief Cat-herder Vancouver UrS-car club |
#4 |
Member
Account #: 43547
and did mine. The nozzles in the kit are the same as the ones on your's except they're yellow. I too noticed the change, it's quite significant. I think if it did change them, it'd make the spray cone less wide. However, I don't know much about the injectors so can't say for sure. I guess you can tell us how they run.
![]() <U>Project '93 Urs4</U> -8/'92 Build Date ~Rear Sway/Suspension~ -Suspicion of a chip (cut carpet) ON THE BED: H&R's, '92 trip computer cluster, Sport Wheel, TDS-1, E-code Headlights, Euro Bumper, A8 Interior Auto-Dim Mirror <U>'90 20v 90q:</U> -RS2 Headlights -16" Borbets -Manual Climate Swap -Concert Headunit -Quattro Scripts (Auto to manual swap) -034 Injectors -B4 Hood Conversion <U>'93 100CS:</U> -Bad Headgaskets/leaky steering rack -FWD/Auto Garbage |
#5 |
Member
Account #: 58573
Send them via email, give them a call.
I found the Bosch Inj data sheet on the internet before. That has the parameters for the spray cone.
++++++++++++++++++++++++++++++++++++++++++++++ IM me in the garage via AIM: VRlifeIM Thanks AW for mucking up my signature and old posts. Can't say I'm going to miss all the Tip-hater posts you let thru. Gone to Quattro World dot com |
#6 |
Account #: 93821
IF this is the case then the tip wouldn't need to
be flared out. |
#7 |
I am sure that they will put your mind at ease. Its not like this is the first set of Bosch injectors that they have ever done.
#8 |
#9 |
Account #: 114659
Dan Hussey Atlanta, GA '95.5 Audi S6 Sedan (Silver/Platinum) '87 BMW E30 track slut "Der Warsteiner!" '03 Land Rover Discovery 'S' 4.6 FOR SALE, PLEASE BUY ME "Middle class is defined as a subsection of the population which includes everybody." |
#10 |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
