| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Account #: 46176
What does your car run at as a temp. I just put in a new thermo. and it seems to work but i just wanna be sure. Do you guy's cars go to the first solid line and not really move at all? I jsut wanan be sure, my g20 does that and it is fine know it(4cyl) but my 90 (2.8) fluxuates a little when on the highway it goes down and what not, like showing it works.
__________________________________________________ ______________________________ Do you know where? ![]() AIM: quattro90S6_______________________________________ ___Trek OCLV 9700, nothings original |
#2 |
Junior Member
Account #: 30264
After my new thermostat, that is. I don't see any fluctuation once that temp is obtained... however, I've been driving in cooler weather and pretty much all highway for short stints... no traffic or high ambient heat.
Before that and a new MFTS, it'd be below the bar, then peg the gauge to the left.
'93 UrS4 20vtq | Dahlback ECU | RS2 Manifold | RS2 Turbo | RS2 Injectors | Apikol FMIC | South Bend Stage 3 clutch | 034 Motorsport Aluminum Flywheel | ASW Camber Plates | Dahlback BPV | APR Snub Mount | Samco Silicone Hose Set w/Constant Torque clamps | VDO Boost Gauge - ashtray removal option | 17x8 Oettinger RE/Falken GRB Fk452 245/40/17 | Stromung 3" SS DP + exhaust | Intrax/Bilstein | 993 TT calipers | 314x30 Euro A8 slotted cad plated rotors | SS lines, Mintex Blue Ctech 1144, DOT4 | Carbon Knob | Amsoil 2 Stage Air Filter | Clear Corners
#3 |
![]() Join Date: Feb 2001
I just did the thermostat and MFTS in my 93 S4. With the new thermostat but old MFTS, it went to "90" degree C, and then dropped like a stone (bad MFTS). With the new MFTS, it goes up to just under "90" and pretty well stays there, at least around town, in 10 deg C weather (Vancouver, Canada). If you have the automatic climate control you can check this through the on board HVAC diagnostic system:
With the car ignitiion on (and presumably running), hit the UP arrow and RECIRC buttons at the same time. You should see 01c in the display. This is the first diagnostic channel. Hit the temp up (+) button until you scroll to channel 51 (51c). Then hit the recirculation button. The display will show you the coolant temp. The whole procedure can be found at the URL attached.
Naturally, IMHHEO(tm), Dave F. aka the Librarian Car and Mods: 93 S4, 1.8t coil pack conversion (First in world using integral POS coil packs (??)), CF (OE), S6 steering wheel, RS2'd, Samcos, MRC, TDS-1, Apikol FMIC, Eibach/Bilstein, BIRA Sys 1, relayed FP Click here to link to the UrS FAQ Thread Start Uncle Dave says "You want my 'high horse, elitist' opinion ?(IMHHEO(tm))Then just post something stupid." Unofficial Chief Cat-herder Vancouver UrS-car club |
#4 |
Junior Member
Account #: 30264
are apparently too dumb... we only get C, H and a few ticks in between :-(
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
