Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 100 / A6 (C4 Platform) Discussion
Old 01-21-2002, 07:10 AM   #1
Muhammad
Account #: 153
Default GAMMA Radio Information & Unlocking Procedure
GAMMA HEAD UNIT
The radio goes into SAFE mode to prevent theft. While I think it's a useless feature (who steals car radios anymore, anyway?) that just makes more work for everybody including you, the owner, you will probably have to deal with this, and Audi still has the feature in new cars today.
To unlock your radio, you will need your RADIO CODE ... this is a 4-digit number that is assigned to your radio head unit.
If you don't have this number, your fate is in the hands of your local area Audi dealer. Good luck? (They can look it up based on your radio head unit serial number.)
GAMMA Head Unit Information
(Gamma head unit with Bose face plate)
The Gamma head unit is found in the following Audi models:
1993-1995 Audi 90
1994-1995 Cabriolet
1992-1994 Audi 100, S4, V8
1995 Audi A6, S6
The part numbers for the Gamma are...
Audi # 4A0 035 093
Audi # 4A0 035 192
Gamma Features
Different face plates for Bose vs. standard versions
Cassette player with auto-reverse
AM/FM tuner, 4 AM presets, 8 FM presets, DX/Local, Seek/Scan
Controls for 6-disc or 10-disc CD changer (CD changer optional)
Bass, Treble, Fader
Dolby noise reduction
Telephone mode auto volume attenuation
Dual-diversity antenna system
Anti-theft coding
Mode display in instrument cluster
Made by Blaupunkt
Two versions of Audi OEM CD changers are compatible with the Gamma radio (in Bose-equipped systems), one is 6-disc, one is 10-disc. The 6-disc version part # is 4A0 035 111. The 10-disc version is no longer available. CD changers were not available as an option on the Audi 90 or the Cabriolet.
SAFE mode unlock procedure for Gamma head unit
1) Park car. (Note: Experienced radio unlockers have been known to perform this task while driving, but it is extremely dangerous and may result in a fatal crash. Not advised.)
2) Turn radio on. SAFE will show in the display. (Note: The car does not have to be on, nor does the key have to be in the ignition or in any position.)
3) Press the hold the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
Photo of step 3:
4) Enter your radio code. Use the radio station preset buttons (1, 2, 3, 4) to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1. So for example, if your code was 1927 you would press...
- 1 0 times
- 2 9 times
- 3 2 times
- 4 7 times
Which would show 1927 in the display.
Photo for step 4:
5) Once you have your code entered in the display, repeat step 3 until 'SAFE' displays again. Once 'SAFE' displays, release the buttons. The radio should return to the station it was on when it went into safe mode. Your radio is now unlocked.
If your radio is still locked then you entered the incorrect code.
When an incorrect code is entered, the word 'SAFE' appears in the display again, first flashing and then continuously. You can repeat the above steps to unlock the radio once more. If an incorrect code is entered again, the radio will be locked for about an hour. After one hour, you may try again twice before it locks again for an hour.
Muhammad
'06 A4 3.2Q
Brilliant Black/Ebony
Premium, Sunroof, Shades, Sport
Muhammad is offline   Reply With Quote
Old 01-21-2002, 08:09 AM   #2
Scott Long
Junior Member
Account #: 25726
Default Anyone want a Gamma BOSE head unit, I'll sell mine, but its locked, have to figure out the code...
Scott
U.S. Air Force
2k2 S4 tip, black on gray
Join the Dayton-Cincinnati-Columbus Audi Group
Scott Long is offline   Reply With Quote
Old 01-21-2002, 06:55 PM   #3
Seattle Scott
Member
Account #: 12414
Default Do you still have the car? A trip to the dealer is needed.They don't give codes to guys w/radio only
Seattle Scott is offline   Reply With Quote
Old 01-22-2002, 03:27 PM   #4
Scott Long
Junior Member
Account #: 25726
Default Yes I still have the car, but replaced the stock head unit, maybe the prev. owner knows the code?
Anyways its for sale if anyone wants it, I'll try to find out the code for it. Email me if interested.
Scott
U.S. Air Force
Old 03-27-2002, 05:24 AM   #5
Jeffrey K.
New Member
Account #: 34684
Default Re: GAMMA Radio Information & Unlocking Procedure
Thank-you, Muhammad. By the way, how would I locate a 6-CD changer, now that I know one is available for this '93 100cs?
Jeffrey K. is offline   Reply With Quote
Old 01-10-2003, 11:26 AM   #6
Solarant
New Member
Account #: 47301
I got a replacement radio, got the code off guy i bought it off, turned out the code was wrong.
Anyway I put the code in twice and "Safe" flashed and then stayed on, so i waited a about three hours and went to try again
pressed FM1 and AM and nothing happened
It wont let me retry.
So i waited 24 hours and tried again nothing happened,.. radio is lit up still saying SAFE.
Any Ideas
I have a gamma and a 93 100s.
Solarant is offline   Reply With Quote
Tags
100, 1993, 90, 93, a6, audi, car, code, gamma, iv, key, mode, radio, safe, stereo, unlock
