| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
New Member
Account #: 127228
I guess its time for me to give back to the forum.
Here is my documentation of remove and replace of the front passenger air spring on a 2002 ar with 6spd. I started by putting the car in jack mode, removing the tire and loosening the air line to the air spring (10mm). I actually disconnected the battery too because I didnt want any power going to the suspension valves to alow air to the open air spring. ![]() While the air was leaking out I removed the pinch bolt and the two upper control arms (16mm). I was lucky because it came out on the first try. ![]() Next i removed the bolt at the bottom of the strut assembly (18mm)..... ![]() but in order to get the bolt all the way out i had to remove the lower ball joint (18mm) ![]() Once the base of the air spring assembly was free i removed the air plenum cover. ![]() With the cover removed i could access the upper air spring mounting bolts (3x16mm) ![]() I found out the hard way but this little washer nut needs to be removed before the whole air spring assembly could be removed. I ended up cutting it off because it wouldnt thread off. ![]() Here is the assembly removed ![]() Next i marked the orientation of the air spring to the shock base to avoid having the new air spring bag being twisted once reinstalled. ![]() I remove the six torx bolts which hold the uper mount to the air spring..... ![]() then I loosened the nut which holds the shock into the air spring... ![]() and removed the collar underneath the rubber mount. ![]() To seperate the shock from the air spring i tapped the base of the air spring lightly with a hammer till it slid off the shock.Here is the shock separated from the air spring. ![]() When installing the new air spring i started by having the new lower o-ring in this position on the shock and I just pushed the air spring down and the o-ring rolled down the shock until it seated at the bottom ridge. ![]() Before i put the upper mount back on, i placed the new o-ring in the upper groove on the air spring (the manual says to coat the o-ring with lithium lubricant)..... ![]() i just made sure the mating surface on the upper mount was super clean and smooth. Also be sure the fitting for the air line is facing out. ![]() At this point installation was the reverse of removal. Once i got to the point of filling the air spring i lowered the vehicle to regualar height with the jack, but still had the jack holding the car up. Then I reconnected the battery and let the computer do the rest. ie) fill the empty air spring. Once the air spring had some air in it i lowered the car down the rest of the way. I did this so the air spring wouldnt get all crumpled if i let it down all at once. |
#2 |
Junior Member
Account #: 54090
1. Thank you, thank you for an excellent article. I know in the future I will need this.
2. I don't know how but somehow you should get your post on the tech section under brakes/suspension: allroad. This way when folks need it in the future they will have an easy time finding it. 3. Take the .T out of all the photo properties so as they aren't so small in your article.
#3 |
Account #: 63325
mustbeaudi's rings: 07 Lava A3 2.0t DSG Prem OpenSky Tech Audio SOLD - 01 allroad (hers) - to a new member of the Audi fold. SOLD - 02 S6 (his) - now with a fellow AW'er in CO. mustbeaudi AT yahoo DOT |
#4 |
Member
Account #: 56080
#5 |
![]() Join Date: Oct 2003
• 2003 audi allroad 2.7t 6 Speed • 177,000 miles; bought new in May 2003 Mods • APR 5.0, Stratmosphere Hyperboost Diverter Valves, AWE DTS, Toy Guy SS, RS6 Exhaust with Borla Tips • HP2 reverse mod, ECS Slotted Rotors, Metal Master Pads, SS lines • 402 down 20MM, RS6 Reps, • Arnott Replacment Air Springs-Front • OEM Trailer Hitch. • New OEM Shocks at 140K. • New OEM Clutch, Flywheel, Pressure Plate, Slave Cyl at 175K • New Upper Control Arms, Tie Rod Ends and other suspension parts at 140k-175k • check www.allroadfaq.com for some allroad information. |
#6 |
Account #: 116884
Could simply replacing the o-rings possibly fix a leaking air spring? My front driver side is leaking and I am looking for a temporary fix until I can get my coilovers on.
#7 |
New Member
Account #: 122245
potential buyers. I replaced timing belts before on volkswagens as well as struts. This looks easier than that.
#8 |
Member
Account #: 19949
-------------------------- Signature Begins ------------------------ PUBLIC NOTICE: After 29,998 posts and seven+ years, this party has moved to quattroworld.com... it looks and works just like AudiWorld did before the IB loons destroyed it. And most of your old friends are already there. |
#9 |
Yeah, I have a Porsche
![]() Join Date: Jul 2004
PSA - Don't post angry "Just living the dream" Autobahn Country Club (North-South-Full), Blackhawk Farms, Daytona International Speedway, GingerMan, Grattan, Mid-Ohio, Nurburgring, Road America, VIRginia International Raceway, Watkins Glen International "The most fun you can have in a car with your pants on"™ RIP Zipper 08/03/1999 - 05/09/2009 TeamJanicaRacing.com 2004 A4 3.0 USP Avant 1989 Porsche 951 2001 A6 4.2 |
#10 |
Junior Member
Account #: 68521
- My guess is that the spring nut that you cut off is a factory assembly aid, so it serves no purpose and can be discarded.
- How did you remove the shock-to-spring nut without having the bolt turn? Most people need to apply a socket to the nut and insert an allen wrench through the socket. - As another poster mentioned, you didn't mention applying grease to the top O-ring. Dunno how much difference that makes in the real world, but I'd rather not skip it.
- glidar ---------------------------------------- ![]() My fuel log | Factory trailer hitch installation guide | VAG Locator | allroad FAQ | Where is we? Repair/Mod Log 11/2008 111000 mi: Replaced window lockout switch block in armrest. Replaced power steering pump. 7/2008 108000 mi: Steering pump bolts left loose after TB change caused bolt to shear and bracket to break, causing ribbed belt to come off. Drilled out & replaced bolt, reinstalled belt. Replaced rotted BPV control hoses. 3/2008: Replaced front axles (Raxles) 12/2007: Continental Winter Contact 225/55-17. 6/2007: Cleared recurring ABS code (by SCR). 4/2007: Replaced turn signal stalk, hazard relay, and clock-spring connector. 2/2007: Replaced EGT sensors. 2/2007: Replaced broken mirror switch. 12/2006: Replaced left front CV boot. 10/2006: Replaced right front air spring. 9/2006: APR. 8/2006: Kumho ECSTA ASX 225/55-17. 7/2006: Changed timing belt, water pump, etc. 4/2006: Replaced leaking coolant expansion tank. 2/2006: Replaced front rotors & pads (Zimmerman plain & Mintex RB) 11/2005: Falken Ziex 512 trashed at 15,000 miles 3/2005: Left front air spring, compressor & control unit replaced under warranty. 2/2005: Installed H-sport sway bars. 8-12/2004: Left front fully deflates 50% of the time; remains inflated 50% of the time. 8/2004: First suspension deflation (left front). Reinflated fine; no codes. 7/2004: Replaced tie rod ends with ECS heavy duty. Installed trailer hitch. 6/2004: Falken Ziex 512 225/55-17. Front lower left control arm replaced by dealer -- didn't fix squeek. 4/2004: Front mud flaps 3/2004: 710N BPVs 3/2004: VAG-COM 2/2004: Servotronic 605 relay removed 1/2004: 2001 allroad 2.7T 6-speed Highland Green with third-row seat Squawk List as of 10/2007 Lumbar adjustment inop on driver's side Safety switch on armrest for rear windows won't stay down. Missing lines in DIL. Instrument panel/glareshield squeek. Intermittent HVAC fan noise. Peeling passenger armrest. Erratic rear wiper. Fart sound from (yes) the rear. A/C smell. Rear bumper paint chipped by backing into sign. Sun visor plastic bearing broken off. Clunk from rear suspension. Windshield washer doesn't spray driver's side much. Slight on-center play in steering. Speaker in both driver-side doors cut out intermittently. |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
