Go Back   AudiWorld Forums » Audi Models » Audi allroad
Old 04-25-2005, 08:16 AM   #1
RMcQ
Elder Member
Account #: 2021
Default RMcQ procedure - Clear Corner Mod
There has been quite a bit of content developed across Audiword on this mod (specifically the A6 forum), but I am such a nice guy that I thought I would document my procedure as it may be more specific to the allroad.
Overview: The idea is to get the orange reflectors out of the headlight assemblies. There are two ways to do it: 1. Break the reflector into bits with long needlenose pliers through the blinker bulb mounting hole or 2. Remove the clear plastic covers off the front of the headlight assemblies and easily remove the relector intact which is also nicely reversible if the need should ever arise. I went with #2.
Before you think about getting started you will need to get a T-30 torx that is somehow long enough to reach the elusive 3rd fastener on the headlights. It is well down inside a hole near the fender. My T-30 torx hand driver (shaped like a screwdriver) was nowhere near long enough. My T-30 torx socket driver was too big to fit into the hole. I luckily had a multi-tool set that had a long flexible extension which took a small T-30 torx bit.
So the idea here was to get the lights out of the car, do surgury on them on the workbench, and then put them back in the car. I know now that the only way to get them all the way out of the car is to remove the bumper. I wasn't going to deal with that so I just did the surgery with the lights 'loosened' from the car.
The lights are held in by 3 T-30 torx fasteners. Two are obvious on top and the 3rd is down in this hole near the fender. To effectively work with the 3rd fastener and not loose it into the blackness below I had to get a hand in there. This required removing the air box on the passenger side and moving the power steering fluid reservior on the driver side.
Using my long Torx tool:
With the 3 fasteners out the light will feel very loose, but doesn't come right out. On the inboard side of each housing there is a pin that engages a small bracket. You have to work the pin out of the bracket to be able to move the light housing very far.
At this point I was planning to take the lights out, but they simply don't fit (I'd love to have someone prove me wrong.) So I pulled them out as far as I could to continue the job. At this point I removed the 4 metal clips around the perimeter where the front clear plastic cover is connected to the black housing. Also, I didn't get it in this picture but there is a rubber sealing strip that goes around the top of the assembly. It engages into the housing with clips into the circled slots. It is easy to pop it out and peel it out of the way. I didn't totally disconnect it. It hung down outside of the car during the procedure.
The only thing holding the clear cover on now is some black, sticky adhesive. You could probably fight it open without heat, but if you warm the black stuff it gets much easier to pull apart. I used a simple hair dryer and patience.
Once the clear cover is off simply pop the orange reflector out from the inside.
And I am going to stick you at this point with the dreaded "installation is the reverse of removal" instruction.
Now I am turning my attention to the corner bulbs. The OEM bulbs are dual filament amber bulbs. This means that they have two separate "lights" inside. One is for the blinking blinker. The other is not as bright and is used as the running light when headlights are on. To make the corner fully clear we can't have that ugly orange bulb in there so we have a couple options. Osram/Sylvania make a "silverstar" bulb which is somewhat expensive (>$20/set) that some have used, but it is single filament. You have to take additional steps to get it to fit.
What I decided to do was to "silverize" some OEM bulbs myself. I bought a pair of new ones in case I botched it.
Masked the bases and hung them in my paint booth.
I tried to put a very thin, very even coat of silver paint on the bulbs. In hindsight I might have gone a little too thick with paint as the running lights are very dim but I must evaluate at night to know for sure.
If you are going to replace the amber bulbs it is much easier to do it while you have the airbox and power steering fluid reservoir removed. Once I got the ghetto painted bulbs in there it looked like this.
The bulb still illuminates amber so functionality is retained and it doesn't look ricey.
+ + = 451whp/472 ft-lb
Full RS6 bastardized allroad quattro alive and on the road.
RMcQ is offline   Reply With Quote
Old 04-25-2005, 08:36 AM   #2
pyite20v
Junior Member
Account #: 33213
Default Great write up! few follow up questions
How hard is it to take out the power steering resivoir?....
If all you are doing is ungluing the cover do you think it might be possible to get the cover off without taking the light out? Maybe just getting the top part unglued and opening the light enough to get to the reflector?
Also a tip, when painting the orange turn singnals, cover up the bottom 1/4 to 1/2" (by the screw in part) with tape so it doesn't get painted. This will help the bulbs to glow orange.
pyite20v is offline   Reply With Quote
Old 04-25-2005, 08:42 AM   #3
RMcQ
Elder Member
Account #: 2021
Default Answers
I did not completely remove the power steering reservoir. Just 1 10mm nut to dismount it an push it out of the way.
It would not be possible to remove the lens covers without taking the assembly partially out as shown for numerous reasons. The biggest reason is that there are metal clips holding it on that you have to get to and remove.
Old 04-25-2005, 09:12 AM   #4
arob
Account #: 73217
Default Another great write up, Ryan. :o)
arob is offline   Reply With Quote
Old 04-25-2005, 09:16 AM   #5
RMcQ
Elder Member
Account #: 2021
Default Thx. I didn't put all the formatting in that I usually do. Getting lazy :-(
Old 04-25-2005, 09:29 AM   #6
gragravar
Account #: 55347
Default great write up - much better than the pliers method!
gragravar is offline   Reply With Quote
Old 04-25-2005, 09:43 AM   #7
XYTOPOK
New Member
Account #: 62206
Default Hate any kind of mods with the lights.
What about others who will be blind when paint fall down and you finally find time to fix it.
I plan to clear 2 lights above rear lic. plate and point them to a face of car driver behind me. Gonna be some kind of fun to see my mode against his.
AR 2.7T (tip) '03
H-Sport (soft)
Winter: Vredestein WINTRAC XTREME
Summer: Avon Tech M500
XYTOPOK is offline   Reply With Quote
Old 04-25-2005, 09:52 AM   #8
mk4=audi?
Junior Member
Account #: 75723
Default Ummmm.... yeah...
mk4=audi? is offline   Reply With Quote
Old 04-25-2005, 10:05 AM   #9
TeddyBGame
Member
Account #: 32631
Default well done. great pix...ideas.
TeddyBGame
- C5 Avant - "the Beast" (Ha!!)
- 2005 Chrysler Pacifica Touring (Nav, Sirius, Bluetooth, Xenon, TPMS, ParkSense, DVD Changer - basically loaded)
- 2003 Vespa ET2 (modified exhaust and carb -- so I can max out at 45MPH)
- John Deere Gator (4x2) for the boy
As of November 2006:
Accessory Add-ons:
(Definition: An item that provides a specific function - in a cyclical nature - and can be removed very..very easily.)
1) OEM winter floor mats
2) OEM rubber trunk mat and cargo net
3) VW Touareg cigarette lighter flashlight
4) Thule roof bars with Evolution 1200 roof box
Upgrades:
(Definition: A [bolt-on/bolt-off] item that enhances the appearance, performance or misc function of your car.)
1) OEM front/rear Euro black Recaro Seats (from a Euro 2003 S6 Avant)
http://forums.audiworld.com/a6/msgs/618112.phtml
2) OEM HID/Xenon (complete) housings (car never came with the Xenon option from the factory)
3) OEM Euro front/rear (avant) beam-style wiper blades/arms (available via www.vagparts.com)
4) OEM B6 S4 Interior auto-dimming black mirror with compass and on/off button
5) OEM Euro blindspot exterior mirrors
6) OEM S6/4.2 exterior lower door trim
7) OEM S4/S6/S8 aluminum mirror housings
8) OEM Euro rear license plate panel from 2002+ facelift avant (slight MODification to US plate required)
9) ?
10) OEM Euro RNS-E DVD Navigation system with MP3, SAT control and TV input
11) Dietz 1417 A/V input to RNS-E
12) Blaupunkt ME3 DVD/CD/MP3/TV Tuner with aftermarket amplified TV antenna in windshield
13) OEM Sirius tuner (special version to work with RNS-E)
14) OEM Phatnoise Phatbox MP3 player (trunk mounted) with custom interface cable to allow Sirius tuner and Phatbox to work together -- cool!!
15) ?
16) BBS RC 17x8 ET35 with Michelin Pilot Sports (summer tires)
17) 2002+ Rear bumper with valance openings for Magnaflow 3" exhaust tips
18) OEM submarine fin roof antenna for SAT / GPS / Cellphone (GSM)
19) OEM Euro gunmetal black avant roof rails
20) 2002+ Climate control faceplate to match faceplate color of RNS-E
21) Walnut wood trim near hazard button (above RNS-E) to match rest of interior wood scheme
22) OEM Euro Avant door panels with integrated sunshades (imported from Germany to match the black leather in my Euro Recaro interior)
23) OEM Euro blacked out front grille (no chrome perimeter)
24) OEM gunmetal black lower rear hatch strip (specific part# for avant vs. sedan)
25) OEM RS6 gunmetal black interior door latches; no need to add any RS6 badges in my car (Thanks Nelson!!!)
26) OEM Euro four spoke walnut wood and black leather (special order via Audi GmbH) multi-function wheel with tip buttons and OEM phone (BT) control
27) Upgraded "618" MF/Tip control module
Coming soon:
- rear mounted removable 7" LCD panel
MODifications:
(Definition: Any permenant change to a part or component of your car that you cannot reverse)
1) Tray under armrest to add aux. cigarette lighter
2) OEM avant CD changer bracket MODified (to fit two large CD changers etc) - now I just use it for Phatbox, OEM SAT tuner and OEM BT module.
3) Exhaust tips MODified to add Magna Flow (#35163) 3" dual walled tip
4) Factory wiring behind Sym I to simplify installation/removal of RNS-E
5) MODified glovebox to support fitment of Blaupunkt ME3 (a biatch to install!!)
6) MODified headlight switch bezel for fitment of GALA switch for "video-in-motion" for playing Blaupunkt ME3 through RNSE
7) MODified stock exhaust and had magnaflow 3" tips welded on (see above)
8) MODified rear Euro license plate surround to house 2nd rear foglight (2001 model only came with one from the factory); US license plate needed to be MODified a bit to fit inside the narrow Euro opening.
RNS-E for C5 A6/S6/allroad/RS6 - your quest starts here - (regularly updated)
<a href="http://forums.audiworld.com/a6/msgs/607331.phtml">OEM submarine fin installed on
TeddyBGame is offline   Reply With Quote
Old 04-25-2005, 10:19 AM   #10
RMcQ
Elder Member
Account #: 2021
Default Uhhhh. OK.
If the paint comes off it is still the same amber OEM bulb that was in there in the first place. Taking the side reflector off does nothing to increase the light output of the bulbs - especially to cars in front.
Maybe you don't understand the mod. If you need me to clarify anything in particular let me know.
Tags
allroad, audiword, c5, clear, corner, headlight, install, lenses, mk1, modification, rs4, s4, steering, tt, wheel
