| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Elder Member
Account #: 2021
Like many others my allroad's blinkers started going crazy and then pretty much stopped all together. I am out of warranty and am the self designated forum no warranty guinnea pig to assess the viability of ownership without warranty. I will note that this failure occured at about 80,000 miles and almost exactly one year after my last unscheduled repair.
The relay just craps out. I was able to revive it for a while by disassembling it and cleaning the contacts, but in the end I just ordered one for $23.67 from Impexfap.com (FKA vwparts.com) This brings my grand total of non-scheduled out of warranty costs to $260.58 at 80,000 miles. This represents 30,000 miles out of warranty and a total of 3.75 years of ownership. 3/1/03 - Fan Control Module $180.22 7/20/03 - Oxygen Sensors $53.95 9/4/03 - Warning triangle hatch latch 9/1/2004 - Turn signal relay If you have the turn signal problem out of warranty the fix is very easy. Pop off the trim that surrounds the hazard light button, level controls, and cupholder. I used a flat screwdriver under a single fold of thick cloth (not terry cloth, but a dense cloth). Others have used a plastic putty knife with success. Start at the bottom and pry at the location of the clips labeled "4" in the following pic from the Bentley manual. Once you pop one clip out your should be able to use your fingers to do the rest. ![]() Once the trim is off grap the edge of the hazard switch body with some needle nose pliers and pull it out of the dash: You will then unplug the thing as a unit from the car. This unit is part number 4B0941509DB98 available for under $25. when you get the new one plug it in and insert it into the dash until it locks in place. Pop trim back and and forget about it for another 3-4 years. If you choose to mess with it like I did you can pull the thing apart by prying the cover off the unit and revealing the separate parts: My degree is in Civil Engineering so forgive the poor explanation of the electronics, but the copper coil on the bottom of the following picture is the relay that opens and closes the circuit for the blinker lights. That clicking you hear is literally that switch being snapped opened and closed on the side of that coil. You can see the contacts down where the very end of my hooked pick is in the following picture. The other coil on the top of this picture is for the hazard lights. More than likely your hazards will work fine because that switch does not wear out. So I revived mine by scraping the contacts clean with my pick. This allowed me to use my blinkers while I waited for the new assembly to arrive. I could have pushed it to see how much longer they would have worked after my repair, but for $23 I figured I'd just put the new one in and forget about it.
Full RS6 bastardized allroad quattro alive and on the road. |
#2 |
New Member
Account #: 2358
RmcQ you are the man. A few weeks ago I had my oxygen sensor fail, and I got my problem solved with your helpful post. Now, by blinker relay is on the fritz. Your post helped me again. And, guess what, I need a new latch for my road hazard triangle. Incredible! My 2001 allroad (69K miles) has had the exact three problems out of warranty as yours. You seem to be a few months ahead of me in each case.
Next time you have a problem, make sure to contact me, so I know mine will fail before it does. Thanks Mike F |
#3 |
New Member
Account #: 11025
Thanks RMcQ, for posting this info. I have 2001 A6 Avant, my blinker was going south. I used your info and took it out, used contact cleaner, topped up the blinker fluid
and all is well.I was looking into buying a new one but will hold off for now. |
#4 |
Member
Account #: 92374
Thanks for the write up, very useful as I did this last week wit the guidance. The only thing I would add is that getting the old relay out with the needlenosers was not easy. I found it easiest once I had broken off the orange button on the front, then I got a decent grip.
black/black 335xi coupe Old car: ![]() '01 A6 4.2 - RS6 sound enhanced exhaust, VAG mods, H-Sport Sway bars (front and rear) Formerly '99 A4 1.8TQT w/KO4, Borla etc. BDI/LMS |
#5 |
New Member
Account #: 114036
Thank You
#6 |
Member
Account #: 118147
Thanks so much for this write up!!
#7 |
New Member
Account #: 121154
you pictures are not working in this post and I am having the same problem on 2001 A4 Q. I think the fix should work and i want to try it.
#8 |
New Member
Account #: 10280
Awesome - this worked for my '00 A4 also, in about 5 minutes. Probably would have cost $200 for the dealer to do.
A tip for getting the trim off without scraping it (at least for the A4): open the cupholder partway, and put the screwdriver BEHIND the trim piece and pry it off from there. There's a perfect sized gap behind the trim. Then you don't have to worry about scraping the visible side. |
#9 |
New Member
Account #: 157574
hi , i am a Chinese , i am live in China now . i'm come here from the Google.
my English is bad(poor?) , so i don't know can you see me , i hope you can... i have an a6 2.8Q(c5 1999) , it is broken now , it look likes this one : http://forums.audiworld.com/a6/msgs/533681.phtml i want to fix it DIY , so i find this article(http://forums.audiworld.com/allroad/msgs/91515.phtml) , the article was very meaty , but i can't see the pic , you know , i need the pic , because i don't know which parts is broken , and location is where ? i hope somebody can help me , thank you , my friends... you can put the pic here , or send to my Email:touhaorenwu000@126.com long after(not long after?) , i will show you some pic , my car and my country :-) |
| Tags |
| 200, 4b0941509db98, audi, audiworld, blinker, blinkers, brokehow, clicking, fix, grand, hazard, pontiac, relay, s4, sound, write |
Previous Thread
Next Thread
| Display Modes | |
and all is well.
Linear Mode
