Go Back   AudiWorld Forums » Audi Models » Audi A3 / S3
Old 06-05-2008, 09:04 AM   #1
jwa9681
Account #: 113749
Default Oil consumption and RPM's...again.
So I know most of this is discussed about once a week, but a few more questions that I'm not sure have been thrown out there:
I have 27k on the car. It was serviced at 25k, and I'm almost certain the oil level was perfect a month ago after the service. It's now a quart low.
Question is: Does going into the redline by a few hundred rpm's every once in a while (read rarely) affect the oil consumption exponentially? Is it possible that this would be my issue and I don't have a leak/burn? And second, is there a way for the service department to check my maximum rpm? and could this void a warranty in any way? and if that is the case, is there a way to wipe that info out/reset it with a VAG-COM?
Before my 25k service, I was using about a quart per 10k give or take.
2007, 2.0T, 6M
jwa9681 is offline   Reply With Quote
Old 06-05-2008, 10:01 AM   #2
danham
Member
Account #: 36981
Default warranty will never cover 1 qt/2k miles
In the bad old days, Audi would not pay for work on an engine that was consuming less than a quart in 600 miles.
Not sure what the modern warranty threshold is, but I'd be shocked if they would pay to go after your consumption, which is only slightly on the bad side of normal as far as I know.
My A3 with more than 25k on the clock uses approx. a quart to a quart and a half in 3k, depending on a lot of factors, including RPM, how hard it is driven (throttle opening regardless of RPM), engine and outside temps.
-dan
A3 2.0, garnet red/light gray leather, 6-spd manual,
sport, sky, cold, convenience, Valentine One,
DICE I-AUDI-T2 iPod adapter via CD port,
Garmin nuvi 760 GPS w/ProClip console mount.
Previous rides: '98 A4 1.8TQ chipped; '92 Corrado VR6;
'90 Corrado G-60; '87 GTI 16v; '83 GTI; '71 914-4;
'67 Volvo 122S; '66 Porsche 912
danham is offline   Reply With Quote
Old 06-05-2008, 10:39 AM   #3
jwa9681
Account #: 113749
Default But, if it does need work...
will they be able to check for red-lining? and will that void my warranty?
Old 06-05-2008, 01:19 PM   #4
ABarthol
Account #: 58209
Default My 2.0T burns oil like a 2 cycle
Since its only 1 quart per 2k miles, it's "within spec"
Complained about it at 35k service (and 25k service, and 15k service). Was told "It's within spec and there were no visible leaks. Sorry."
A3 6MT Silver- Premium Package, Cold Weather, Open Sky
<br/>
ABarthol is offline   Reply With Quote
Old 06-05-2008, 01:39 PM   #5
danham
Member
Account #: 36981
Default Re: But, if it does need work...
My =guess= is that they cannot detect red-lining through any stored data - but I don't know for sure.
But the warranty question is more complicated. If (and I'm def not accusing you of this) someone acted like a mega-jerk, the dealer would perhaps look very hard at whatever evidence emerged during engine teardown to see if the owner abused the car.
Back in the day, if we found things like bent valve stems or odd scoring patterns in cylinders, for example, on a warranty claim like this, we would begin to suspect high-rev abuse and would make a judgment whether to call in an Audi rep (remember, the dealer can get hosed too, if Audi bounces the claim).
-dan
Old 06-05-2008, 03:38 PM   #6
jefex
Member
Account #: 114130
Default My buddy was a tech at Mazda and had a customer that said there engine blue up for no reason...
Then there computer readouts for the last 5 minutes of the engines life said he was doing about 130mph at 8000 rpms. Are you talking about jerks like that?
jefex is offline   Reply With Quote
Old 06-05-2008, 04:24 PM   #7
jwa9681
Account #: 113749
Default interesting...
next question is, can you vag-com it out?
this is all hypothetical, I'm sure my car is fine...I don't abuse it too badly. I definitely drive it hard, and hit redline once or twice every 1000 miles, but nothing serious...and it's always for about 1 second before the shift...
Old 06-05-2008, 05:48 PM   #8
Deus Ex Machina
Junior Member
Account #: 82334
Default Burning 1 qt per 10K miles is not bad at all. Audi/VW says 1 qt/1K mils is within the factory specs.
My 2005 S4 4.2 burned alot of oil. At least 1 qt per 1.5K miles. My 2.0T has been great and I haven't added 1 drop in the 4500 miles I've owned it. I have had a problem with fuel sensors.
2005 S4 6 spd:Full LaBree exhaust/KW Variant 3 Coilovers/Matrix-Alta CAI/BBS LM's 19x8.5/30% Tint/V1/Clearbra.
Winter Mode: 235/40 18" Dunlop M3's on Stock Avus Rims.
TRADED FOR 2008 LAVA GREY A3 2.0T S-LINE WITH DSG APR STAGE II+ on 18" B7 RS4 wheels ET 42....PICS SOON.
Deus Ex Machina is offline   Reply With Quote
Old 06-05-2008, 07:41 PM   #9
Gettysburg
Account #: 89897
Default The ECU on my BMW motorcycle records if the bike has tipped over while running... DAMHIK :(
I would suspect at least the MAX RPMs achieved would be stored.
_________________________________
Used to have:
- '01 Audi TT Coupe(180hp quattro)
- '93 VW Corrado SLC (still my favorite)
- '82 VW Scirocco
Gettysburg is offline   Reply With Quote
Old 06-05-2008, 11:32 PM   #10
Q5Steve
Member
Account #: 144613
Default That sounds average for this engine and as for RPMs
My A3 does all motorway (freeway) work and my wife has a Golf GTi (same engine) which is mainly town and she boots it (read constantly). Both cars go through oil at same rate for what its worth (and that rate is rapid by standards of other engines I know)
2006 A3 (3dr) 2.0T quattro S line SE Avus Silver
Coming Soon - Q5 3.0 TDi STronic Tungsten Grey
Q5Steve is offline   Reply With Quote
