| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
New Member
Account #: 104318
So, I took on the challenge of swapping out my single-DIN, non-BOSE radio to upgrade to double-DIN and Nav+. Huge thanks to Lee @ NSX Jr> and to Dirk (AudiB64US) @ NavPlus.us and here on AW for all their help. Lee was a huge help in getting every little issue sorted out. Definite recommend to all interested in doing this retrofit.
Anyway, I figured that since I was already doing that upgrade, I might as well throw in the OEM Bluetooth module and kill two birds with one stone (as the saying goes...). It always bothered me that I hadn't ordered these two options straight from the factory. So, I took it upon myself to ease my irritation ![]() My camera ended up dying after taking snaps of the parts, so I didn't want to wait until it was charged to do the installation. So, the pics are of the parts, and finished results. I will describe in detail how to do the full install. 1) Full list of needed parts - pictures and part numbers: NOTE: THESE ARE THE ONLY PARTS YOU NEED - don't waste you $ getting other parts that have been posted as necessary: a) Radio removal keys - I got these from eBay - $10 including shipping. ![]() b) Double-DIN cage PART NO: 8P0 858 005 A CAN $95.00 ![]() c) Blanks (non-functional buttons) PART NOS: LEFT: 8P0 941 515 C 5PR RIGHT: 8P0 941 516 C 5PR CAN $10.73 each ESP Switch: PART NO: 8P0 863 321 C 6PS CAN$ 35.00 *YOU DO NOT NEED A NEW HAZARD LIGHT SWITCH - Single-DIN Hazard light fits the same, even though part number is different* ** NONE OF THE OTHER BUTTONS WILL WORK - Single-DIN button, including ESP switch, are all larger** ![]() d) Card Shelf: PART NO: 8P0 941 561 E 5PR CAN $85.00 (What a joke... :sly ![]() *AGAIN, Single-DIN card shelf is too big for the double-DIN cage* ![]() (Sorry for the crappy pic) e) Center trim (Goes around switches - again, double-DIN specific): PART NO: 8P0 863 321 C 6PS CAN $52.65 e1) THIS IS FOR US CARS ONLY: Passenger Airbag Warning Light for double-DIN PART NO: 8P0 919 234 A 5PR e2) FOR THOSE WITH TPMS OR WANTING TO RETROFIT TPMS: TPMS switch for double-DIN PART NO: 8P0 927 121 A 5PR f) RNS-E Unit PART NO: 8P0 035 192 **NEW UNITS HAVE A LETTER AT THE END OF THE PART NO: B, C, F, and G** Bought off eBay for US$900 ![]() ![]() g) RNS-E wiring harness - make sure to get the adapter to work with non-BOSE, w/out telephone (if no BT), w/ CD Changer **Use this harness only if you're not retrofitting the Bluetooth module at the same time - that requires a different harness** Can be had on eBay, or NavParts.com> or Euro-Parts.us>. RNS-E sellers should include this harness though. ![]() h) GPS antenna and Radio antenna adapter *These parts should also be included in your RNS-E purchase ![]() i) Other needed things: Painter's tape (for protection) Double-sided tape (optional) Dremel + flexible add-on (optional) Soft cloth polishing dremel tool Cutting tool Tool kit - Hex nuts, torx bits, strong hands! ![]() ![]() ![]() ![]() Bluetooth Parts - optional (not needed for RNS-E install) *I purchased all these parts from Lee at <a href=""www.nxsjr.com.BT.html"">NSX Jr></a>. He's a great guy, helped me out with everything from the install to coding both my RNS-E and BT unit with VagCom a) Bluetooth Module; RNS-E wiring harness (with mic and BT wires already built in) ![]() b) BT antenna; BT mic ![]() Now, if you have all these parts in hand, you're ready for the install. INSTALLATION: Unfortunately, like I said, I don't have pics from the install itself. It's just a matter of unscrewing and removal and replacing. If you're worried about scratching up your dash, put a towel across your handles, and use painter's tape on the outer trim of the centre console. I didn't do either since I was exceedingly careful... but use your own judgement. 1) Remove Concert II radio Using 2 radio removal keys, remove the old radio. *Insert the keys with the 'hooks' facing inward* Once the keys pop in, you can't remove them until the radio is out. Once removed, disconnect the adapters. Don't worry about not knowing what goes where after - it's a simple puzzle. They are colour coded and are size dependant as well. 2) Once the radio is removed, pull off the upper trim piece. It'll pop out easily. 3) Remove blank switches, ESP switch, Hazard ligh switch, and Card holder. The blanks pop out easily. The ESP and Hazard switches need to be pulled out and unplugged - again don't worry about confusing them later - colour coded white and black. The Card holder requires a fine tool to push down on small clips on the upper right and left side. (Easily seen with the drawer open). 4) Remove the climate control unit. It'll pull out easily with the rest gone. Unhook all the cables - again colour coded and size dependant for later. Now it gets fun. 5) Removal of ash tray. Open the ashtray. Hook your fingers underneath where the ashtray meets the shift boot. Lift up firmly. The shift boot trim should pop up. There are two clips in the front and two in the back. Pull the boot up all the way over the gear shift (for 6MT) and put the car in 4th or 6th to get the stick out of the way. 6) Remove glove box and cover underneath steering wheel. This is a simple process of removing bolts. There are many. Under steering wheel: a) Push light switch in, and twist to the right. It should pop out. Disconnect the two connections, and put switch away for later. b) Remove fuse box panel cover. c) Unscrew all the bolts underneath the fuse panel. It's obvious which ones are holding the lower dash on. d) There are two bolts in the foot well. One on the right and one on the left. Unscrew both of those and the lower dash should come off. e) The top will tilt down. With the top part down, pull outward and the rest of it should come off. Glove Box: a) Remove side panel b) Open glove box and remove everything. c) Unscrew all bolts - 3 or 4 on side by panel, another 6 or so found after opening the glove box. d) After all the bolts are removed, the glove box will fall downward. Unhook the pass. airbag connection, the CD changer cable, and the in-box light cable. 7) Remove center console handles. In the picture below, see the four circles in the shift boot area. Those need to be undone. On the underside of the handles, in the middle, is a hole reaching to a HEX bolt. From memory, I think it was an 8mm bolt (could be 6mm...). Those two bolts need to be undone. ![]() 8) Unscrew the single-DIN cage Where the red circles are, are torx screws. Unscrew all of them and another two screws on the side (glove box and driver foot well lower dash) and this should completely loosen the single-DIN. Loosening all these screws will also allow the handle bars to completely come off. ![]() ![]() ![]() 9) Remove the single-DIN cage This sounds easier than it is. It's not meant to come out this way, but it will come. Pull out and twist down to the right. That worked for me. **At this point, I had everything out. The ashtray and the "storage" area behind it were out. The entire dash had been taken out.** Alright, very nice. The removing aspect of the job is done.... now it's time for the good stuff. Installing. 10) Install the double-DIN cage Again, sounds easier than it is. Just keep working it, and it will eventually go in. This is the part when I started sweating - taping the area would have been a great idea, but I managed not to scratch anything. 11) Line up the RNS-E unit in the cage. Once the double-DIN cage is in, screw in the torx screws, but don't tighten. 12) Slide in the RNS-E unit, but not all the way in. Don't re-attach the cables. This is check to make sure that the Nav+ will sit straight. If it's straight, remove the RNS-E and then go hard with the torx screws. ![]() 13) Once all the torx screws have been tightened, install the RNS-E unit. Attach the new cable harness, GPS antenna, Radio antenna, and push the unit all the way until it clicks. 14) Install the blanks, the two switches, and the new card tray. 15) Install the trim surround. Now the sensitive part... cutting the climate control unit. I didn't feel like shelling out $1,000 to buy a double-DIN climate control. So, I used a Dremel to shave down the sides so that it would fit. 16) Make a template of the shape of the new climate control. I took a piece of cardboard and kept cutting it until it fit into the climate control area (on the bottom) like the actual unit would. Once I had the exact shape, I centered it on my climate control and cut two rectangles for the knobs. With the template centered on the climate unit, I traced the outline on it as the marks for cutting. 17) Using a dremel, shave down the sides of the climate control unit. Take your time with this... keep shaving and testing, shaving and testing. 18) Once the fit is perfect, using a soft cloth polisher, buff the sides of the unit so that it's smooth and not jagged from the sanding. Hardest part is over! 19) Attach all the cables to climate control unit. 20) Wire your GPS antenna to a good location. I wired mine to the driver side fuse box. I get 4-8 satellites there all the time. A lot of people have wired their antenna's up in the instrument cluster. It's magnetic so it'll attach just about anywhere. If you're really bold, you can get a FAKRA extension and wire it up to the existing sharkfin antenna on the roof... totally not necessary though. 21) Do not turn on car yet! If this is the end of the install, make sure you reinstall all the cables - light switch, pass. airbag, cd changer etc. or you'll get a bunch of vag-com codes. 22) Put everything back together. Power on car. Hopefully everything should work - normal satellite reception is > 3. 23) For the ashtray area, I ended up doing a little bit of crude modifying. Since the double-DIN sits so much lower than the single-DIN, the storage area behind the ashtray is essentially eliminated. I didn't want to get a new bezel and trim that would be stuck in a hole I'd never see. After removing the existing storage area trim, you'll see four tabs at the back. The two in the middle don't line up with the double-DIN. I snapped them off. The result... the same flooring of the storage area behind the ashtray, and more $$ in my pocket. 24) ADMIRE YOUR HANDYWORK!! :thumbup: 25) Get your Vag Com cable out to do the necessary coding. If you don't have one, your dealer should be able to do the necessary coding for you. ---------------------------------------------- FOR BLUETOOTH RETROFIT, READ ON 1) I installed the module in my glovebox. 2) Run mic wire to preferred location. I ran the mic wire up the passenger side A-pillar, across the headliner, and pulled it out in the overhead light console. The mic now sits in the light console where those vents are, hidden from view. I get perfect voice reception with it up there. 3) Re-install everything. 4) Vag Com coding changes. -------------------------------------------------------- Vag Com coding: 1) Select 19 - CAN gateway" and go into the Long Coding helper Check on Byte 03, bit 7 (for telephone) - IF APPLICABLE, Bluetooth only Check on Byte 03, bit 3 (for navigation) 2) Select 16 - Steering wheel: current coding 02022, new coding 04022 3) Select 37 - Navigation: current coding 0209217, new coding 0205617 4) Select 77 - telephone: current coding 0000000, new coding 0011477 - BLUETOOTH ONLY **NOTE: 1) Since 6MT sports don't have DIS (in dash display), we'll always get an instrument cluster fault code. There's no way to get rid of that fault. 2) Since there is no diversity antenna, all will get a "ZF Antenna" fault code in RNS-E (Select 77). For example: Steering Wheel: 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication Nav: 2 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal Radio: 2 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal --------------------------------------------------------------------------- Well, that should do it, for this DIY. BEFORE: ![]() And some pics of the end result: AFTER: ![]() ![]() ![]() ![]() ![]() Oh, and what's this? Engineering Mode... very cool, if you're into a little bit more technical info: Location, Altitude, Road Speed... ![]() ![]() EDITED TO INCLUDE PART NUMBERS FOR 1) Double-DIN Passenger Airbag Warning Light - for US A3's 2) Double-DIN TPMS Switch
--------------------------- ![]() '06 A3 2.0T 6MT|Arctic White|Sport|Bi-Xenons|Open Sky|Debadged|Tint|Detailing|18" Flik Hornets w/ Falken 452's|Votex Side Sills|Votex Front lip Spoiler|S-Line Rear Valence|S-Line Grille|Gloss black|JSP SS|PIE ipod|LlTEK Custom Mats|Euro Tailight activated|AWE Boost Gauge|Neuspeed RSB|VagCom|APR TBE|GIAC X+|Neuspeed Power Pulley|Nav+ RETROFIT|BlueTooth RETROFIT| |
#3 |
Account #: 107075
#4 |
Member
Account #: 7684
This should go into the tech articles...
Former: Shame what happened to AW, KAWF lives |
#5 |
New Member
Account #: 104455
#6 |
Junior Member
Account #: 109202
#8 |
Account #: 76
With Nav powered on, push "NAV". Then push and hold the upper left quadrant switch for 5 seconds. Then press the upper right quadrant switch until the screen changes. If nothing happens, start over and be sure to hold button for at least 5 seconds.
2006 A3 2.0T 2006 M3 99.5 A4 1.8T qms, retired |
#9 |
Elder Member
Account #: 29210
Very nice.
Total cost in parts looked like it would be around $1500. Is that about right?
.................................................. .................................................. ................................................ 06 A4 2.0T QT, Brilliant Black, S-Line, Premium, Sunroof, Technology, Navigation, Power & Manual Sunshades, XM, APR (91 Octane) 09 PBM G8GT Premium & Sport, VMS ECM & TCM Tune (91 Octane) |
| Tags |
| a4, adapter, audi, bluetooth, din, double, engineering, install, mode, number, part, q7, retrofit, rnse, single |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
