| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Senior Member
Account #: 15175
Hi Everyone,
The new TFSi system for the VAG product line brings quite a few new challenges to the table and the learning curve is / and will be steep! One of the problem areas that seems to be cropping up is the ability of the original "Rail" pump to sustain the spec'd pressure (about 110 BAR) under high torque conditions. This is a problem that has been known to GIAC for some time and has been checked during the development of the programs that are now being released. The data group that shows pump rail pressure is 205; I suggest that you log this in conjunction with another group that shows RPM. Also please note that this should be checked under high load conditions. I.e. The problem is more pronounced in a 5th gear pull than a 2nd gear pull (this also relates to dynos that do not have enough load). Some examples below: SF's B7 A4 stock ![]() SF's B7 A4 GIAC "03b" ![]() JT's B7 A4 "Brand X" ![]() JT's B7 A4 GIAC "03ba" ![]() The normal range appears to be about 110 BAR at wide open throttle. And from my understanding there is a fault code that pops up when pressure drops below about 90ish bar. The car shown above with the dropping pressure did not have a code, and it is suspected that some are turning off this feature. GIAC does not. Before everyone panics! There is a replacement pump that will be available to GIAC dealers shortly that will help with this problem. If you see this problem, please call regardless of the brand of chip that you have. We do not want to create an environment of fear in tuning these excellent motors, and, surely when all of the tuner take a look and correct this, it will no longer be an issue. Please note that the fuel delivery system operates in a range of 725 to about 1750 psi. This can SEVERELY injure you if the system is not bled down properly before removal of the original pump. So if in doubt, DO NOT DO IT! If any of you are in the Los Angeles area and are interested in the GIAC product I hope to hear from you. Take care, and have fun all! Jeff Moss Torque Factory, Inc. 2304 Zeno place Venice, CA 90291 310-466-4296 Moss@torque-factory.com Torque Factory To find a local GIAC dealer: GIAC
Sport Compact Car 2007 Ultimate Street Car Challenge Winner Jeff Moss, ASE Certified (A1, A3, A4, A5, A6, A8) <a href="http://www.torque-factory.com">Los Angeles area GIAC dealer for Audi, Bentley, BMW, Mini, Porsche and VW. ![]() Torque-Factory, Inc.</a> Torque-Factory Support Forum |
#2 |
Elder Member
Account #: 38083
I'm still waiting for a GIAC chip for the A3... ETA?
#3 |
Senior Member
Account #: 15175
NP Mike. Good luck with the S BTW.
Jeff
#4 |
Member
Account #: 55719
#5 |
Junior Member
Account #: 32092
#6 |
Elder Member
Account #: 38083
![]() S4 is back up to 445whp snuff, even in conservative trim
#7 |
Senior Member
Account #: 15175
Would be curious to see some testing with comparable conditions.
I.e. Same dyno. AWE is ready to go. Are you close to Shimon? He should have a cable coming soon. Jeff
#8 |
Senior Member
Account #: 15175
#9 |
Elder Member
Account #: 38083
The last dyno I was on was pretty brutal, I'm sure it'd do much better on a more normal dyno. It's so bad the dyno owner made ME drive the car on the dyno so if it blew up it wouldn't be on him, lol.
I'm closest to AWE. Their website doesn't indicate the A3 Xchip being ready. I'll give them a call tomorrow and make an appointment to have some 1's and 0's installed
Previous Thread
Next Thread
| Display Modes | |
</a>
Linear Mode
