Go Back   AudiWorld Forums » Audi Models » Audi A3 / S3
Old 04-19-2003, 03:45 AM   #1
The_circle
New Member
Account #: 54777
Default need to tune my a3..up to 350 hp,any ideas?
I want to tune my a3,i want it somhow to reach from 320-350hp,what is the proper engine i should install as a begining for this project?although i have a problem,which is i think i will stick to a tiptronic or automatic gear box..any ideas?
The_circle is offline   Reply With Quote
Old 04-22-2003, 04:24 AM   #2
RichA3Turbo
New Member
Account #: 42645
Default Re: need to tune my a3..up to 350 hp,any ideas?
ITs going to be cheaper to buy and S3! and tune that...and will be quattro too!
Rich
Audi A3/IHI VF-34 / 330bhp / 300lbft / ECS Stage2v2 / Stage1Rear / RS3 Kit / Racelogic
RichA3Turbo is offline   Reply With Quote
Old 04-22-2003, 07:43 PM   #3
Lwen
Member
Account #: 25698
It depends on where you are.
Here in Brazil we can reach almost 330 bh changing the OE turbo to a KKK .16, exaust system, remaping the ECU and some other changes to reach 280 bh on dyno.
My previous A3 1.8T was tuned with 220 bh on dyno whith OE muffler, but with a bigger turbo, K&N filter, chip, sparks, etc.
Lwen is offline   Reply With Quote
Old 04-23-2003, 05:26 AM   #4
lost it
New Member
Account #: 17906
sell the a3 and buy an RS4, methinks it will be cheaper in the long run, to get an s3 to this sort of figure (with some suspension and brake changes to suit) costs as much as another s3.
Check out AMD's web site for the one they upgraded to similar specs.
plus 350 hp and front wheel drive will be interesting in terms of torque steer to say the least.
lost it is offline   Reply With Quote
Old 04-24-2003, 04:04 AM   #5
Feuerstein
Member
Account #: 36276
Default Torque steer
I tested an A4 1.8T FWD tuned to 270 hp. Torque steer was horrible.
Yes, you probably should buy a car designed around more power than the A3.
resident Norwegian
Feuerstein is offline   Reply With Quote
Old 04-25-2003, 02:17 AM   #6
Gambba
New Member
Account #: 43870
Default The standard A3 isn't the best platform to start on........
Jabbasport can do a 350-400 Bhp job for around the 3.5K (GBP) mark, but you can't even lay 200 hp down effectively enough in the FWD A3. An A3 tuned to S3 specs cannot beat the S3 off the line purely due to traction, as RichA3Turbo will confirm.
To lay 200+ hoursepower down in the A3 chassis you need to have quattro, but check out the below link detailing Jabbasports mods on a Golf 1.8T....and as you'll note it definately needs the brakes upgrading.
But I would still say that the minimum car to start with is a Quattro preferably with a six speed box, but this can be fitted later.[list][*]http://www.jabbasport.com/Audi/Jabbachips/Press_Release/performance_vw_May_02_p1/performance_vw_may_02_p1.html
Oettinger A3T
0-60 6.49 Secs
Gambba is offline   Reply With Quote
Old 04-26-2003, 02:18 AM   #7
Khufu
New Member
Account #: 47158
Default Re: The standard A3 isn't the best platform to start on........
out of interest, I take it you couldn't fit 4WD to a non quattro body? (apart from obvious cost) I've looked at the ETKA and seen the different ways the rear suspension is attached, and how the bodies of the cars have different chassis codes too. From that I assume that the rear of the car doesn't have the choice of mounting points for the rear subframe depending on what application it is to be used for.
Khufu is offline   Reply With Quote
Old 05-07-2003, 08:20 AM   #8
RichA3Turbo
New Member
Account #: 42645
Indeed i can! I've got 192bhp and it is very difficult to get a *fast* start. My best 0-60ft was 2.6seconds... and an S3 was 1.99 or something.
I wouldnt waste your money on more power... Get quattro first.
Rich
