Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 04-02-2008, 07:16 PM   #1
..o_O..
Senior Member
Account #: 88983
Default Update on my 19 gallon fill up
I'm at 150 miles so far and haven't even made it past the first quarter mark!
Revo | Phatnoise | Auto Aesthetics | HN Concepts | OSIR | 3.2 rear valance | ECS | H&R
..o_O.. is offline   Reply With Quote
Old 04-02-2008, 07:43 PM   #2
panTTera
New Member
Account #: 115012
Default Money saving tips on pumping gas...
This is from a recent news article that some might find helpful...Kinda long, but informative.
"I don't know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every gallon.
Here at the Kinder Morgan Pipeline where I work in San Jose, CA we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some other liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom. Hope this will help you get the most value for your money.
DO SHARE THESE TIPS WITH OTHERS!
WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
Gas rationing in the 80's worked even though we grumbled about it. It might even be good for us! The Saudis are boycotting American goods. We should return the favor. An interesting thought is to boycott their GAS.
Every time you fill up the car, you can avoid putting more money into the coffers of Saudi Arabia.
I thought it might be interesting for you to know which oil companies are the best to buy gas from and which major companies import Middle Eastern oil.
These companies import Middle Eastern oil:
Shell.......................... 205,742,000 barrels
Chevron/Texaco......... 144,332,000 barrels
Exxon /Mobil............... 130,082,000 barrels
Marathon/Speedway... 117,740,000 barrels
Amoco............................62,231,000 barrels
Citgo gas is from South America, from a Dictator. If you do the math at $30/barrel, these imports amount to over $18 BILLION! (oil is now $90 - $100 a barrel)
Here are some large companies that do not import Middle Eastern oil:
Sunoco.................0 barrels
Conoco..................0 barrels
Sinclair.................0 barrels
BP/Phillips............0 barrels
Hess.......................0 barrels
ARCO....................0 barrels
If you go to Sunoco.com, you will get a list of the station locations near you.
All of this information is available from the Department of Energy and each is required to state where they get their oil and how much they are importing."
And remember..NO CHECKING W/A LIGHTER !
2000 180 QTC Denim/Aviator - stock+Audi TT valve stem caps
1973 DeTomaso Pantera Yellow/Black - mostly showroom stock
panTTera is offline   Reply With Quote
Old 04-02-2008, 08:02 PM   #3
CincySpeed
Member
Account #: 108369
Send a message via AIM to CincySpeed
Default Think a gallon of gas is expensive?
This makes one think, and also puts things in perspective.
Diet Snapple 16 oz $1.29 ... $10.32 per gallon
Lipton Ice Tea 16 oz $1.19 ..........$9.52 per gallon
Gatorade 20 oz $1.59 ..... $10.17 per gallon
Ocean Spray 16 oz $1.25 ......... $10.00 per gallon
Brake Fluid 12 oz $3.15 ...... $33.60 per gallon
Vick's Nyquil 6 oz $8.35 ... $178.13 per gallon
Pepto Bismol 4 oz $3.85 .. $123.20 per gallon
Whiteout 7 oz $1.39 ....... . $25.42 per gallon
Scope 1.5 oz $0.99 .....$84.48 per gallon
And this is the REAL KICKER...
Evian water 9 oz $1.49..$21.19 per gallon! $21.19 for WATER and
the buyers don't even know the source
(Evian spelled backwards is Naive.)
Ever wonder why printers are so cheap?
so they have you hooked for the ink.
Someone calculated the cost of the ink at...............
(you won't believe it....but it is true........)
$5,200 a gal. (five thousand two hundred dollars)
So, the next time you're at the pump,be glad your car doesn't run on water, Scope, or Whiteout, Pepto Bismol, Nyquil or Printer Ink!
2001 Audi TT Roadster 225
1.8l Turbo AWD 6sp manual
CincySpeed is offline   Reply With Quote
Old 04-02-2008, 08:03 PM   #4
blueprinTT
Member
Account #: 47675
blueprinTT's Avatar
Default Hard to believe the temp of gas in underground tanks would vary that much....
....throughout the day....and be much warmer (expand) in the afternoon. Around here (midwest) the ground typically stays around 50 degrees, deeper than 4 feet below the surface, year-round.
Good info though!
|2002 lake silver 225 qc|revo sps3|forge 007p|bilstein hd|eibach pro kit springs|1/2 kmac|neuspeed 19mm rear sway|
|h&r spacers 15mm-front 25mm-rear|fat fives|modshack gadgeTT v1|blitzsafe mp3 adapter|
|defcon 4|
|TT-east 2005 attendee - chaTTanooga, tennessee| |TT-west 2007 attendee - ashland, oregon|
blueprinTT is offline   Reply With Quote
Old 04-02-2008, 08:10 PM   #5
|everso!|
Account #: 53740
Default *stops drinking ice tea...reaches for gasoline*
IEDEI BLOG
|everso!| is offline   Reply With Quote
Old 04-02-2008, 08:16 PM   #6
Horch it
Member
Account #: 8309
Default good to see 100octane and Conoco Philips is Saudi free oil
"Truth In 24" airs nationally on ESPN Friday March 20 8:00 EST
blueflame ~ press ~
...aka: ColTTrane
Freikorps - Right wing armed bands that roamed the streets of Germany in the 20's, forming the roots of the SA and AWOT
...only TT with ABT
Horch it is offline   Reply With Quote
Old 04-02-2008, 08:33 PM   #7
The Chad (VaultPSU)
Junior Member
Account #: 118264
Default I refill water bottles with toilet water.....
that source is endless, no matter how many times I flush it, it always fills right back up!!! AMAZING!
The Chad (VaultPSU) is offline   Reply With Quote
Old 04-02-2008, 08:58 PM   #8
Horch it
Member
Account #: 8309
Default make it gasahol and you won't ever need to fix your senders
blueflame ~ press ~
...aka: ColTTrane
...only TT with ABT
Old 04-02-2008, 09:20 PM   #9
TTEUER
Junior Member
Account #: 137187
Send a message via AIM to TTEUER
Default It's coming from a guy in California...
we're the king of environmentalists and hippies.
I'd take everything with a grain of salt. I would think the tanks are deep enough to not change much temperature since the ground pretty much stays the same temperature year round.
Brandon
TTEUER is offline   Reply With Quote
Old 04-02-2008, 09:42 PM   #10
Horch it
Member
Account #: 8309
Default lol, Al's from Tennessee
blueflame ~ press ~
...aka: ColTTrane
...only TT with ABT
