Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 09-30-2006, 04:41 AM   #1
BoschTT
New Member
Account #: 68123
Default front sway bar- squeek, plastic sleeve removal
Hey all, question for you. Went to my mechanic to have the bushings replaced on my front sway bar due to the infamous squeek. They said they can't just replace the bushings, but need to order the entire bar. Isn't it just a plastic piece, is it possible to rip it off and just replace the bushings? Or if the plastic sleeve is removed, won't the noise go away, so do i even need new bushings? 2000 TT Quattro, obviously no warrenty. Thanks,
BoschTT is offline   Reply With Quote
Old 09-30-2006, 04:56 AM   #2
TTschwing
AudiWorld Uber User
Account #: 13940
Default Just knock this bushing off..>>
with a chisel or something. You'll need smaller (20mm) bushings when it goes back together. Get the Poly Powerflex ones from:
no sig
TTschwing is offline   Reply With Quote
Old 09-30-2006, 05:10 AM   #3
SpongeBobTT
Account #: 99420
SpongeBobTT's Avatar
Default My squeak is gone...
...now that the temps have droppped. Perfectly timed with my last visit to the dealer - ugh.
I just need one warm day over the next two weeks before warranty is up. Or I may use a blow torch : )
- Randy
My Fotki
TTC 2006
TTE 2007
TTE 2008
SpongeBobTT is offline   Reply With Quote
Old 09-30-2006, 10:04 AM   #4
MCPaudiTT - DEFCON 1
Account #: 83654
Default The dealer won't replace bushings only, they will do the whole bar.
Got a question about your TT? Try searching the TT-FAQ!
Got DEFCON?
My FOTKI
MCPaudiTT - DEFCON 1 is offline   Reply With Quote
