Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 09-19-2003, 12:35 PM   #1
Keyna
Member
Account #: 26314
Default Help - Hood release cable disconnected somewhere, any ideas how to open hood?
Keyna is offline   Reply With Quote
Old 09-19-2003, 12:39 PM   #2
BOOSTD
Elder Member
Account #: 6443
Default do you wanna keep the hood?
Please read.
BOOSTD is offline   Reply With Quote
Old 09-19-2003, 12:46 PM   #3
Keyna
Member
Account #: 26314
Default I'd like too, thanks for the help.
Old 09-19-2003, 12:49 PM   #4
BOOSTD
Elder Member
Account #: 6443
Default sorry, wish I could help. it's been posted before though, see if a search turns up anything.
Please read.
Old 09-19-2003, 12:53 PM   #5
Silv3rMoto
Elder Member
Account #: 54049
Default I was going to suggest pry bar...
seriously, check right by the lever, its possible the cable became detached right there... if not , then you can get at the lever under the hood by removing the grill...
I warn you I did this on a car with front end damage, and didnt care how I got the grill off...
No More Audimoto
3rd silver awd turbo car = Silv3rMoto
Gone But Not Forgotten:
2001.5 1.8tqms. Tastefully Modded, Untastefully Stolen.
2001 1.8tqm Avant. Tastefully Modded, sold.
Silv3rMoto is offline   Reply With Quote
Old 09-19-2003, 12:58 PM   #6
Keyna
Member
Account #: 26314
Default It's disconnected at the hood. I think I'll wait through the weekend and take it to a body shop.
Old 09-19-2003, 01:00 PM   #7
iNfiNkC
Member
Account #: 29191
Default think the only way opening it now is removing the front grill, it might break the tabs
but will give you very easy access to the hood lock itself, alot cheaper than using a pry bar on the hood =) gives you an excuse to get a new grill
iNfiNkC is offline   Reply With Quote
Old 09-19-2003, 01:40 PM   #8
optimus prime
Member
Account #: 29460
Default same happened to me at the track, here's how.
Get the front of the car up on ramps or jack stands. I used a big f-ing screwdriver / pry-bar (24") and went from underneath straight up to the release lever catch that the (hood release) wire ball attaches to. You will need to move a clip (with the prybar) that is obstructing your way to the lever. It also helps to have a friend with a flash light. Look at a friends A4 hood release mechanism to see what I am talking about regarding the clip and the path near the radiator the pry bar needs to go.
And remember you are upside down when moving the lever to release the hood. It goes toward the drivers side to release.
OP - baby daddy
Tracks: Blackhawk Farms, Gingerman, Grattan, Mid-Ohio, Autobahn Country Club [N,S,C], Road America, Waterford Hills, Nurburgring F1, Nordschleife, Seefeld Austria [Audi Ice Driving Course], Chicago Motor Speedway
optimus prime is offline   Reply With Quote
Old 09-19-2003, 01:41 PM   #9
optimus prime
Member
Account #: 29460
Default No access, radiator is in the way.
OP - baby daddy
Old 09-19-2003, 01:45 PM   #10
kam1200
New Member
Account #: 23636
Default This happened to me before. You gotta use get your grill off by
using something to reach the tabs and try to disconnect the tabs from the hood. Your grill will pop out and you can see the hood latch and cable. Pull hard as hell on it and it should unlatch it.
Then go down to the "stealer" and get a new cable for about $45 IIRC.
kam1200 is offline   Reply With Quote
Tags
a4, b5, break, cable, hood, open, release
