| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Elder Member
Account #: 2847
After a spirited drive through the winding roads of the Minnesota Farmland on Saturday, I set up Sunday AM to wash off the bugs and dust.
After that, I experienced 2 classic TT problems. Within 5 minutes of each other, and in my driveway, the brake light switch failed, as an intermittent, and the passenger door switch failed. The display showed the passenger door as always `open' I got the brake switch today, and tackled the door switch tonight. I'm proud to say it can be fixed, and dismayed to find out, once again, Audi chose an inferior part, made in France, for this sub-standard switch. Here is the culprit after removing the door latch assembly. Piece of crap small plastic plunger broke apart inside the switch. ![]() ![]() The switch is mounted at the top, open end of the door latch assembly. The switch mounts in those 2 holes. You can see this cam-type acuator here, that pushes the switch button in, as the door is closed. ![]() I rummaged through my parts-bins, and came up with an industry-standard micro-switch that has stood the test of time as my replacement. I'll bet I could take this switch and substitute it in any major factory machine still in use today, and it would work. I'll bet this switch has been in my parts-bin for 20 years. Why Audi chose to use such a cheap switch is beyond me. This one will out-last the car I suspect. I had to drill a new hole to mount it 90 degrees from the Audi one, and them I will epoxy it in place. ![]() Here it is mounted and wired. ![]() Here it shows the cheap-o switch in the same plane as it was orignally installed, with the new one, screwed in and epoxied in place. ![]() ![]() Here it is mounted and in place. ![]() I tested this and it works, and I'm re-installng it now.
#2 |
![]() Join Date: Jun 2000
_____________________________________ Only 29,000 posts to catch SCHWING!!! _____________________________________ TT-East Questions and Answers here TT-East ________________________________________ TT-East 2008 Primary Organizer TT-East 2007 Primary Organizer TT-East 2006 Primary Organizer TT-East 2005 Attendee CT GTG Coordinator CT MOD Day Headquarters "self proclaimed" --------------------------------------- TT-East 2008 courtesy of McPaudiTT ![]() Linky to pics of Mods,Cars and Shows Link to the TT-FAQ's...if it ain't here, then ask!!! "thou shalt not flash a Porsche to get out of the way, or be damned to breathe his exhaust for eternity" - Someone wise TRACK THOUGHT- Don't brake until you see God.... then when you do see God, count to three, then brake! AIM name - EINTT Current Automotive inventory... 2006 Mercedes Benz R350 2001 Audi TT 225 1977 Porsche 911s 1961 Porsche 356b |
#3 |
Senior Member
Account #: 78082
#4 |
Account #: 102013
Soooomeeeewheeeereeee oveeerrr myyyyy HEAD.
#5 |
Elder Member
Account #: 23258
i still wouldn't be able to DIY like you did.
Bill '01 Atlas Gray Tip allroad : winter package : Dahlback chip : H-Sport sway bars '01 225 TTQC : Brilliant Black TT : Ebony : Premium : Heated Seats : Bose —| Engine |— :: Dahlback chip :: Dahlback intake manifold :: 42 Draft Designs 3" downpipe with test pipe :: EVOshield intake gasket :: Bosch Super Copper spark plugs :: N75 K valve :: Modshack VTDA :: Modshack MoFo v.2 with Tyrol adjustable FPR :: Forge SPLTR DV :: relocated :: O.CT FMIC :: Samco hoses [intake, upper and lower] :: VF Engineering side motor and pendulum mounts :: Custom 3" Sheep/Mufflex exhaust :: Optima YellowTop battery —| Suspension/Drivetrain |— :: KW variant 3 coilovers : 8012 spring mod :: DieselGeek Sigma 6 short shifter upgrade :: DEFCON3 with H2S rear spherical bearings :: CPT control arms (lower) | Forge tiebars (upper) :: Haldex race controller :: H-Sport front and rear adjustable sway bars —| Exterior |— :: Blindspot "Euro" mirrors :: Bosch Aerotwin wipers :: OEM roof rack [Thule bike rack] :: Audi OEM 3.2 bumper :: Audi OEM Quattro Sport Phantom Black grilles :: RISO smoke clear corners : o-gas : zero v.3 :: RISO CF arc :: Smoked Euro tail lights <Jon's Tinted Tails> :: Black sidemarkers <Jon's Tinted Tails> :: Wilwood 4-piston, 13" rotor BBK :: Summer Sandals [Toyo T-1Rs on 19" BBS LMs ET25] :: Winter Boots [Nokian WR on 19" LMs] :: ECS 12.1" rear cross drilled slotted rotors :: Hawk HPS brake pads :: StopTech SS brake lines —| Interior |— :: ModShack gadgeTT v.2 :: AWE Tuning boost gauge :: Hardwired Garmin nuvi 360 with gadgeTT2 :: Hardwired V1 :: PIAA H3 Super Plasma foglight and switch mod :: ice>Link v.1.1 : iPod interface :: Audi RS4 perforated steering wheel :: Audi OEM TT winter mats :: Audi OEM S-Line all aluminum shift knob :: RISO O-gas :: Britax Starriser seat in rear —| yard sale |— :: KMD lightweight crank pulley —| Future Mods |— :: Euro dash |
#6 |
![]() Join Date: Nov 2004
#7 |
Junior Member
Account #: 75098
For future reference and for those without a parts bin. Some of these switches from Digikey look like they may work: Cherry snap switches (PDF) Page 1 figure 3, DC water and dust sealed.
#8 |
| Tags |
| audi, audiworld, door, fix, latch, micro, microswitch, optima, switch, tt |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
